Question about HP VECTRA VLI8 P3 Motherboard (KZM6120)
System memory error - HP VECTRA VLI8 P3 Motherboard (KZM6120)
  • Randy Hough
    Randy Hough May 11, 2010
    More details please.
  • 62 Answers
Almost surely a ram problem
Posted on Jan 19, 2009
What are the dell beep codes for dell inspiron m5010
Table 3-1. POST Beep Codes
Beep CodesErrorProbable Causes
1Memory refresh failure.Defective system board.
2Error occurred in first 64 KB of main memory.Faulty DIMM or defective system board.
3Read or write error occurred in first 64 KB of main memory.Faulty DIMM.
4Timer on system board malfunctioned.Defective system board.
5Microprocessor error.Defective microprocesor.
6Gate A20 failure.Defective system board.
7Microprocessor-execption interrupt error.Defective microprocessor.
8Video memory read/write error.Missing or faulty video adapter.
9ROM checksum value does not match value encoded in system BIOS.Corrupted system BIOS program or defective system BIOS chip.
10NVRAM shutdown register read/write error.Defective system board.
11Cache memory error.Defective microprocessor or cache card.
1-2Video adapter failure.Faulty video adapter.
1-3No monitor connected.Loose video cable connection or defective video cable.
Jun 17, 2014 | Dell Inspiron 15 Laptop Computer- Intel...
Startup 6 beeps
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
Loose video cable connection or defective video cable.Faulty video adapter.
13
May 15, 2013 | Samsung NP-148 NP-150 N148 N150 N128 N145...
Long beep at startup
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Dell 4 beeps
POST Beep Codes
How to fix Dell BIOS 8 beep error.
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Dell Inspiron 1018 Notebook
Ibm 8215 beep codes
Here is a list of beep codes, this may help determine the problem wit your system.
1. Keyboard
2. System Board1-4-X Error detected in first 64 KB of RAM.1. Memory Module
2. System Board2-1-1, 2-1-21. Run Setup
2. System Board2-1-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-2-21. Video Adapter (if installed)
2. System Board2-2-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-3-X1. Memory Module
2. System Board2-4-X1. Run Setup
2. Memory Module
3. System Board3-1-X DMA register failed.1. System Board3-2-4 Keyboard controller failed.1. System Board
2. Keyboard3-3-4 Screen initialization failed.1. Video Adapter (if installed)
2. System Board
3. Display3-4-1 Screen retrace lest detected an error.1. Video Adapter (if installed)
2. System Board
3. Display3-4-2 POST is searching for video ROM.1. Video Adapter (if installed)
2. System Board41. Video Adapter (if installed)
2. System BoardAll other beep code sequences.1. System BoardOne long and one short beep during POST. Base 640 KB memory error or shadow RAM error.1. Memory Module
2. System BoardOne long beep and two or three short beeps during POST.(Video error)1. Video Adapter (if installed)
2. System BoardThree short beeps during POST.1. See "System board memory" on page 62.
2. System BoardContinuous beep.1. System BoardRepeating short beeps.1. Keyboard stuck key?
2. Keyboard Cable
3. System Board
Nov 29, 2011 | IBM ThinkCentre M52 8215 - P4 531 3 GHz...
I have a Dell Inspirion 530, dual core quad processor. It's about 3 years old. I just recently started occasionally getting blue screen error. When I ran the memory test off of the bootable partion, I...
It sounds like you are having memory issues with your computer. The best thing you can do is just replace the memory the computer sounds just fine you just need new memory. If you go to this link http://www.newegg.com/Product/Product.aspx?Item=N82E16820134117&cm_re=DDR2-800-_-20-134-117-_-Product on newegg.com. Order these sticks of memory you would be fine. All you need to do is just open up the dell case. Remove the old memory sticks from the main motherboard. Then install the new sticks and you will be able to reboot your system and should run just fine.
Apr 25, 2011 | Dell Computers & Internet
Lost driver & installer
hello
due to the fact that this memory card is no longer available, Kingston does not have drivers fo this card . As a matter of fact SD cards normally do come with drivers , as they are conformed in a way that operating systems recognise them once you plug them into the SD slot
i hope this inofrmation helps you make a decsion
some background on this particular SD memory card you have
SDCZ2-512-A10-KT (Discontinued) Description: 512MB USB 2.0 DataTraveler I write up to 3MBps Discontinued Additional Info: DataTraveler I USB 2.0 Flash Drive Write up to 1.5MBps Read up to 6MBps Mfgr's System P/N's: SDCZ2-512-A10 (Kingston) Form Factor: USB Flash Memory Warranty: 5 Yrs†
here are some solutions .
When the problem occurs is a clue as to the cause.
For example, your response to a memory error message depends on whether:
  1. You have just bought a new computer.
  2. You have just installed new memory.
  3. You have just installed new software or a new operating system.
  4. You have just installed or removed hardware.
  5. Your computer has been running fine and you've made no other recent changes.
UNEXPECTED PROBLEMS
If your system has been running fine, but suddenly starts to produce memory errors, and crash or lock up frequently, the chance of a hardware failure is more likely, since configuration and installation problems show up as soon as the computer turns on. Sometimes you can get memory problems if your computer is overheating, if you are having a problem with your power supply, or if corrosion has developed between the memory module and the socket, weakening the connection.
HANDLING SPECIFIC PROBLEMS
Here is a list of the most common ways the computer informs you of a memory problem.
  1. The computer won't boot, merely beeps.
  2. Computer boots but doesn't recognize all the installed memory.
  3. The computer boots but the screen is blank.
  4. The computer reports a memory error.
    1. Memory mismatch error
    2. Memory parity interrupt at xxxxx
    3. Memory address error at xxxxx
    4. Memory failure at xxxxx, read xxxxx, expecting xxxxx
    5. Memory verify error at xxxxx
  5. The computer has other problems caused by memory.
    1. The computer intermittently reports errors, crashes frequently, or spontaneously reboots.
    2. Registry Errors
    3. General-protection faults, page faults, and exception errors
Nov 07, 2010 | Kingston (SDCZ2-512-A10-KT)...
My memory card is corrupted how i can repair
Hi
Memory card corrupt errors occur when ejecting without safely removing
from system or from phone which causes some files delay write fail
Your memory card problem can be solved in many ways
Firstly
1.Insert the memory card in card reader and
in windows xp go to the drive properties of memory card by right clicking the drive and select
the tools TAB and select "Check now" as seen in check errors
and tick both " Automatically fix file system errors" and " scan and recover bad sectors "
click start and it will fix all file system errors
and all your data is safe too
2. another method is format your card. but it will erase all data
hope this will solve your problem
Feb 28, 2010 | Computers & Internet
Regarding Memory Parity check
this error is usually associated with bad memory cards......how much amount of memory are you using.....try reseating the memory cards(ram)....if you still get the error msg....try starting the system with jst 1 memory (if thr are 2 memory cards installd) & thn swap it with the other one......
Jul 18, 2008 | Lenovo ThinkPad T61 Notebook
Computers & Internet Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
