Question about Apple iPhone 3G
My Iphone doesn't turn on
After installing winterboard iphone doesn't turn on
Remove battery and then put it back in should doit pal
Posted on Jan 16, 2009
If my iPhone is jailbroken or merely unlocked?
Your iPhone is both jailbroken and unlocked because to discover an iPhone you'll need to jailbreak it first unlocked iphone
Mar 27, 2013 | Cell Phones
Tip
How to Add a Theme / Change Icons on your iPhone / iPad in iOS 7
I. Jailbreak your iPhone/iPad
To do this procedure you must be jailbroken. If you aren't, you can head to our Jailbreak How To's section and pick the jailbreak for your version of iOS (currently at the time of writing this is 7.0.4). Once done with that procedure and you have Cydia installed, head back here to continue.
*Don't be scared, it's easy to unjailbreak your device.
II. Install Winterboard
1. Open Cydia (if it isn't still open from the section above).
2. Tap Search in the bottom right corner.
3. Type in Winterboard.
4. Tap on Winterboard when it shows up.
5. Tap Install in the top right corner.
6. Tap Restart.
III. Use Winterboard
1. Open Cydia.
2. Search Cydia (either by searching using the search tab on the bottom right, or by tapping the section tab and then Themes (Springboard/Winterboard) icon).
3. Once you find the Theme you want and it says it's compatible with iOS 7, tap Install.
4. Tap Return to Cydia.
5. Open Winterboard.
6. Tap on Themes.
7. Select the theme you want to use.
8. Tap the home button and wait for it to respring the device
9. Repeat steps 1-8 to apply a different theme.
IV. Revert to the Original Apple Theme
1. Open Cydia.
2. Tap on Manage.
3. Tap on Packages.
4. Tap on Winterboard.
5. Tap Modify.
6. Tap Remove.
7. Tap Restart.
on Nov 21, 2014 | Cell Phones
Tip
How To Install Themes On Your iPhone Using iPhone Explorer
To be able to access the root directory of your iPhone without using wifi, you need to download iPhone Explorer. It's a free app that is the equivalent of Winscp for people with wifi connection. With this, you just need an iPhone usb cable. <br /> <br /> <br /> <p><a href="https://lh5.googleusercontent.com/-Jlid0TixI9I/TW3MWsgV-tI/AAAAAAAAABo/SAQz81Wn038/s1600/Picture12.png"><img src="Picture12.png" /></a><br /><br />1. Download iPhone Explorer from <a href="http://www.macroplant.com/iphoneexplorer/">Macroplant.com</a>.<br /> 2. Install it on your computer. <br /> 3. Plug the phone using the usb cable. <br /> 4. Assuming you already have the folder of the theme you just downloaded, just copy and paste it on the themes directory of the iPhone located in Root/Var/Stash/Themes<br /> 5. Once done, open Winterboard to install the theme, select then Respring. <br /><br />
on Mar 05, 2011 | Apple iPhone 3GS Black (16 GB)
How can i installed a themes in my iphone
jailbreak your iphone.
download and use quickpwn.
look up good well known repositories on the internet and and find winterboard. and download the themes along with it. in winterboard is where you apply them.
Mar 19, 2011 | iPhone Apps
How to download the winterboard?
to install the winterboard you first need to jaibreak your iphone after you have jailbreak your iphone go to cydia n search for winterboard and install it the winterboard will then appear on your iphone
Jan 12, 2011 | Apple iPhone Smartphone
Whatis the application for iphone themes
you have to be jailbroken and the app in cydia is winter board
Jan 01, 2011 | Apple iPhone 3G
Themes iphone 3gs ?
If you are creating a theme – Create a folder somewhere on your computer that is the title of the theme you would like to add (ex…Chalkwork) then inside of the Chalkwork folder create another folder called Icons (with a capital “I”). Inside the Icons folder put all of the icon images that you would like to have. They must be named the same as the Title of the app, starting with a capital (Ex…Calendar.png, WinterBoard.png, AppStore.pgn, Stocks.png….). You can also add a Dock and Wallpaper to the Chalkwork folder, they also need to be capitalized (do not put them in the Icons folder…just in the main Chalkwork folder). Once you have a folder of the theme with a folder of icons inside it you just drag the whole folder, Chalkwork, into the Library/Themes folder on your iPhone or iPod Touch via WinSCP and hit Copy. Once it is done transferring you can go on your iPhone into WinterBoard and select the theme you just added. Note: your iPhone has to be on for the file to transfer!
If you are downloading a theme that is in a zip file – you will have to open the zip file and then create a folder on your computer that is the same name as the theme you are trying to download. Then copy the Icons folder from the zip file into the folder you created on your computer. This unzips the file so that you can add it to WinterBoard through WinSCP. You can also copy the wallpaper and dock out of the zip file into the file you created if you would like them too. If you are looking for some themes to download, check out our Downloadable Themes page.
If you have any further questions, you can email help@appleiphoneschool.com
Oct 09, 2009 | Apple iPhone 3G
Apple iphone
it will install search winterboard in cydia
Mar 13, 2009 | Apple iPhone 3G
Apple iPhone 3G Logo
49 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
