Question about Dayton Electric Heater
Not burning with top on
I have a Dayton heater that was given to me. The person before me said it quit burning and I think they may have worked on it some. I took the top off and it will ignite and burn as long as the top is off, then while it is running you can put the top on and the flame will go out and after just a couple of seconds the the fan will shut off.
    Guru:
  • 462 Answers
Ignite =Burn? I assume its gas. Sounds like its starved for combustion air and while open it is getting plenty of air. Check for obstruction to the burner inlet area and maybe a hornet built a mud nest during the off season in it so look closely. Also maybe the shutter (if so equipped) is not open. You don't mention any miscolored parts of the flame. It should be blue for the most part unless its a kerosene heater.
Posted on Mar 04, 2009
Got a dayton furnace cuts on and off immediately think limit switch is bad can it be bypassed
stay away from the furnace and call for service,you will burn the house down,,who would try to bypass something that makes a furnace work right??
Jun 05, 2015 | Dayton Heating & Cooling
Have Dayton 3e227a gas heater fan has quit, need new motor, can you supply source to buy? Tim
Dayton is a Graingers Brand. Go to the site below and I'm sure you can find your part. Put in your Part Number...Jim
http://www.grainger.com/Grainger/rp_parts_home.jsp
Feb 18, 2011 | Dayton (3E227) Gas Radiator Heater
I have a dayton 3VE50A oil filled heater runs on multi fuel I am running kerosene. Runs great all day long untill I close the lid on it then it quits. Pressure is at 5 psi on back gauge adjusted it up and...
make sure hoses and fittings are air tight, take some soapy water and spray on fittings and hoses and look for bubbles to appear if there is a leak, any small leak will keep heater from working
May 20, 2010 | Dayton E50 Heater
Dayton g73 electric heater less than two months old and thermostat goes out any ideas
I WOULD TRY TO BYPASS THE THERMOSTAT TO MAKE SURE THE UNIT WORKS AND REPLACE THE THERMOSTAT IF IT DOES , SEE IF IT IS UNDER WARRENTY, MY GUESS WOULD BE THAT IT IS JUST DEFFECTIVE, AND YOU ARE TRYING TO FIND A CAUSE, THIER IS NO REAL CAUSE THAT I CAN THINK OF THAT WOULD BURN UP THE THERMOSTAT IF IT WAS OR HAS BEEN WORKING, GOOD LUCK
Jan 26, 2010 | Dayton G73 Utility Heater
I have a dayton radent tube heater that just quit working... Help
Hi remove the inlet flue and blow out with air line through the fan should help,
or jump out the pressure switch if it light s then its that / the fan might be stuck /bruntout
try this it should help
Dec 08, 2009 | Dayton Gas Lonox Furnace Heater
Flames burn then die down
it sounds like you may have a dirty pilot tube or a weak pressure regulator. I would try blowing out the pilot tube to make sure it is clear and if that does not work then replace the regulator.
Feb 14, 2009 | Dayton Gas Furnace Heater
Dayton kero heater wont fire0
OHH I bet this is the same question I just posted to. So it is a forced air kerosene. The usual is like I said a blocked combustion air hole. It could also be something shorting out the spark ignition to ground when replaces inspect the wires and look for a week or loose ground in this case. Sorry about the confusion.
A Bad ignition proving circuit or something like (what we call here dirt dobbers) hornets nest could be letting the flame hit it and not allowing full flow through the heater. Mice are also notorious for making problems like wires chewed and nests in the wrong place. Given where it may have been stored.
Jan 15, 2009 | Dayton Electric Heater
Dayton 2yu62 doesn't work at all
Need to check heating elements and replace if necessary. If your checks are complete that is the answer I think.I suggest reviewing your findings. The heating elements rarely go bad.
Oct 22, 2008 | Dayton Electric Heater
Dayton 24 inch two speed fan
yes, it will work and not damage your motor.
Nov 28, 2007 | Dayton (1UM44) Fan
Dayton Electric Heater Logo
88 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
