Question about Asrock 775VM800 Motherboard
My installer wont load and is stopping my disk drive from working also says wrong configaration settings how do I solve this
  • Anonymous Apr 14, 2009
    i installed 2 Hdd sata and ide, but Hdd not read in bios....
Dear Sir I have a mother board of intel but i not know that how i install this driver
Posted on Jan 16, 2009
Installed new hard drive p105 s6064 now cd drive wont work dont have recovery discs
Dell recovery will not work in a Toshiba Laptop. Just make sure the boot order is set to CD/DVD driver first that will automatically start the CD/DVD driver when disc is loaded.
Apr 22, 2012 | Toshiba Satellite P105-S6104 Notebook
Microsoft streets and trip wont install 2005 version
you might check in MY COMPUTER & see if the drive is showing, if it's not either there's something wrong with the disk or their's something wrong with the drive
Mar 31, 2012 | Microsoft Streets & Trips 2005 for PC
Lost install disk for Mac book pro My 13" Mac book
You will need some install disks to even begin working on your issue.
Your options:
  • Find someone with the same model MacBook Pro and borrow the disks.
  • Buy a copy of Leopard (10.5) or Snow Leopard (10.6) and use them. If you are going to buy a set you might as well update to Snow Leopard (10.6)
  • Check eBay for install disks but make sure they are for the same model MacBook Pro.
  • Contact an Apple service center and purchase a replacement set of install disks.
Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
Apr 23, 2011 | Apple Computers & Internet
My 320gb external hard drive has stopped working. I have used it alot with my laptop, but i hadnt used it for about a month. when i plugged it in it said it needs to install device driver software, but it...
Try connecting it to a different USB port on your computer.
Try connecting it to a different computer.
If the problem persists, either:
* the USB cable is damaged,
* inside the enclosure, the disk-drive is not functioning
(although the lamp indicates that it is getting electrical power)
* inside the enclosure, the USB-to-disk-drive adapter has failed.
If the warranty is still valid, W.D. will replace it, at no cost to you.
If the warranty has expired, W.D. has a "Customer Loyalty" program; buy a new unit from their web-site, and you can get a discount, as a previous customer.
Or, open the enclosure, and remove the disk-drive, and temporarily connect it as a "slave" disk-drive in a desktop computer, to see if it is working at all.
Or, buy a new, compatible, disk-drive, and mount it into the enclosure, to make a "new" external disk-drive.
Oct 29, 2010 | Western Digital 320GB MyBook External USB...
Tried to install a used 20gb working hard drive
I think that you have to reinstall the XP os on the hard drive again.
Nov 30, 2009 | Dell Optiplex GX60 PC Desktop
Set up did not find any hard disk drivers installed on computer
Your notebook has SATA hdd. Got into the bios (keep pressing F2 key on startup) then in the bios screen find HDD and press enter. Select IDE mode. Press f10 to save changes and exit. When this is done install XP.
Alternatively connect external usb floppy drive and unzip sata drivers into that. When booting from xp cd press f6 to load drivers.Follow onscreen instructions to load drivers and continue xp installation.
Please let me know if issue not solved for futher ts steps.
thanx
May 28, 2009 | Fujitsu LIFEBOOK P1510D Tablet PC
Disk drive wont read Ubuntu disk
Make sure you are booting from CD-ROM and not the hard drive, If that doesn't help get out your windows CD...run it until right after it formats your hard drive then stop your computer and boot with the Ubuntu disc...
You will love Ubuntu...it clean not bloated, straight forward, plenty of free help and software, everything you want is available -free and works better.
...good luck (there is a learning curve, but not bad) please leave rating
May 16, 2009 | Computers & Internet
Xp won't load to hard Disk
Your RAM modules could be faulty or needs reseating. If reseating doesn't work, try swapping them around from the other laptop to see if that works.
Apr 22, 2009 | HP Pavilion dv8235nr Notebook
Laptop screen wont work.
Assuming you don't have 2 drives installed in your laptop then you will need to get a windows system disk or install disk and boot up with this in the laptop to load windows whatever into your hard drive and set your laptop up to run on the new drive. Here is Microsoft's tutorial on how to install and set up windows:http://www.microsoft.com/windowsxp/using/setup/winxp/default.mspx
Hope this helps you.
Mar 29, 2009 | Acer Aspire 5315 Notebook
Windows could load installer for disk drive
Change the bios seting to default, check the event and see what it is say about that error and post it here.
Jan 16, 2009 | Asrock 775VM800 Motherboard
Asrock 775VM800 Motherboard Logo
60 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
