Question about Nikon Coolpix 4200 Digital Camera
Out of memory
I have a Nikon coolpix 4200 that has a 256mb. The card "contains no images", but the camera displays "out of memory". Do I need to replace the memory card?
  • Deb Gebhardt Jun 19, 2007
    I need to know how to format the card.
    Thanks.
    Genius:
  • 2,985 Answers
Try Reformatting the card in the camera . Then come back
Posted on Jun 18, 2007
  • john ash
    john ash Jun 19, 2007
    Do you have the Manual?
    Read it through
    If you do not have a paper manual
    It may be as a PDF file on the software disk
    Do you have the software disk and a computer?
    Failing that
    Use the menu button on the camera and run through the options that come up on the screen.
    I cannot be exact in what you will see- every camera model is different
    eventually you should see something like -
    'Card Setup' use the up/down L/R button to find the proper command
    just find a quiet corner and settle down to get to grips with the thing.
Stuck on please wait
Check your current firmware version before beginning:
  1. Turn on the camera.
  2. Tap the menu tab at the bottom of the monitor to display the setting controls and tap Setup (wrench icon)
  3. Tap Firmware Version in the Setup menu(wrench icon)
  4. The cameras firmware verison will be displayed.
  5. Turn off the camera.
Basic Download and Installation instructions: (New firmware versions contain all previous versions.)
Windows
  1. Create a new folder with an appropriate name on your computer's hard disk.
  2. Download F-S4300-V12W.exe to the folder created in step 1.
  3. Run F-S4300-V12W.exe to create the folder titled S4300Update, containing the following:
    • firmware: folder containing the firmware.bin file
    • firmware.bin : the firmware located inside the firmware folder.
  4. Insert the memory card containing the firmware folder into the camera and turn on the camera.
  5. Tap Firmware version in the Setup menu and follow the instructions displayed to upgrade the camera's firmware.
  6. After the upgrade is complete, turn the camera off and remove the memory card.
  7. Check the Firmware version item in the setup menu to confirm that the camera's firmware has been upgraded.
For detailed instructions, please see the PDF files below.
Macintosh
  1. Download F-S4300-V12M.dmg.
  2. Double-click the F-S4300-V12M.dmg icon to mount the disk image titled, F-S4300-V12M.
  3. A folder titled S4300Update, containing the following files, will be created inside the disk image:
    • firmware: folder containing the the firmware
    • firmware .bin: the firmware
COOLPIX S4300 1 2 firmware update Nikon Knowledgebase
Mar 28, 2014 | Nikon COOLPIX S4300
Memory contains images
You're in playback mode and haven't taken any pictures. Put the camera in photo mode or video mode.
Jul 25, 2013 | Nikon Inc Nikon Coolpix S9500 - digital...
I have a 4G Sandisk memory card which is compatible and still keep getting file contains no image data
The memory card was setup for your old camera. Try formatting the memory card using the Nikon camera's Menu settings.
Apr 06, 2013 | Nikon COOLPIX S4200 16MP Digital Camera...
Memory contains no images
Is the card inserted properly?At the side of the card take the lock off.When taking a picture check the camera counter after the shot to see if the image registered
Oct 21, 2012 | Nikon Coolpix L110 Digital Camera
Nikon Coolpix S550 memory card problems
Your camera uses a different filing system than the other camera...they are not interchangeable.
Sep 28, 2009 | Nikon Coolpix S550 10 Megapixel Digital...
Out of Memory on Card, but also says: Memory contains no images
I think you may have deleted the folders from your memory card.  The camera could be looking for the folder to put the photo into, and this error comes up instead of one about the folder.
Dec 28, 2008 | Nikon Coolpix S210 Digital Camera
Memory card contains no images after camera turned back on
Are you able to access the images using a card reader on your computer ?
Apr 18, 2017 | Nikon Cameras
Error message: file contains no image data
Hello!
I may be able to add some advice on how to solve this unfortunate problem of "file contains no image data". I have been suffering from the same problem. I have recently been on some amazing vacations and the photos I have lost due to this problem have been invaluable to me! I would pay an insane amount of money to get these photos back, but unfortunately I cannot!
I have a nikon coolpix camera. I contacted the nikon coolpix technical support center. I spoke with a representative who asked me what type of memory card I have. As it turns out I have a generic memory card, which is not compatable with nikon. The only memory cards brands that are indicated to be used with the nikon coolpix camera that I have are as follows: Toshiba, Panasonic, Lexmark, and Sandisk. Those are the only 4!
I was told that if you use another memory card besides the memory cards brands that I have listed... that the camera may communicate incorrectly with your memory card, which results in data that is incomplete to support an image. When this happens you will only see a portion of your image, and you cannot get it back. These bad images with incomplete saved information are called "corrupt files". The representative told me that there are some programs that are available to purchase that may be able to correct corrupt .jpg files, but she believes that they are memory card brand specific.
To put it simply, when you do not have to compatable memory card in your camera, it is as if your camera is speaking english and your memory card is speaking chinese and they are not communicating properly (this was the way the representative explained this problem to me). So check your user manual for your specific type of camera or look it up online to see what type or brand of memory card you should be using! I truly hope this helps someone avoid losing invaluable photos!
Nov 29, 2008 | Nikon COOLPIX L18 Digital Camera
Nikon camera
hello
are you using a removable SD memory card?
check to see if your card is compatible with your camera.
the card maybe corrupt or may need formatting, try that after you back your pictures, movies up.
if the SD card was bought on auction site, may be a counterfeit. (the legit cards have serial numbers on them)
Jan 21, 2008 | Nikon Coolpix L11 Digital Camera
Nikon Coolpix 4200 Digital Camera Logo
88 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
