Question about Panasonic Home Theater System System
PANASONIC MINI COMPONENT HAS ERROR CODE F61
HI GUYS!I JUST WANT TO KNOW,HOW TO RESET THE CODE?THE CODE IS COMES OUT AFTER SWITCH ON THE COMPONENT. PANASONIC MODEL:SA_AK87 SERIES MINI COMPONENT.
4 Suggested Answers
  • 336 Answers
SOURCE: im having a erorr saying f61
F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.
Posted on Jan 24, 2009
  • 5 Answers
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Posted on Jun 22, 2009
heavyice
  • 374 Answers
SOURCE: panasonic surround sound system model # sa-ht95
Error code ' F61 ' on most Panasonic models indicate that the built-in diagnostics has sensed a fault at the output stage. This would normally refer to a failed output amplifier IC (?P/N RSN704D66P?). In some instances, the fault could also be triggered by:
  • strands of Speaker wires inadvertently touching each other;
  • faulty speakers;
  • failed Cooling Fan of the output IC.
Options then are:
  • consider a DIY (do-it-yourself) repair only if familiar with electronic components & circuitry, use of a DVM/VOM and a soldering iron. Access to a Service manual would be an advanatge;
  • seek the services of an authorized service center specially if the unit is still under warranty;
  • consider other options based on downtime, cost of repair, parts of availability, age of unit and prices of comparable but newer models.
Good luck
Posted on Mar 06, 2010
My panasonic music system (SA VK-960) Is not working properly it shows (F61) error all the components are well attached with music system but there is still F61 error . Help us to resolve this error.
See page 40
Power Supply Error Code Table http://diagramasde.com/diagramas/otros2/panasonic_sa-vk960gc.pdf
Suggest checking power resistors in amp circuits for failed resistor. replace with identical rating in that the power resistors are used in the saftey circuits. Also check around these resistors for failed solder connection.
Hope this helps?
Jun 29, 2017 | Panasonic Audio Players & Recorders
Error code F61
Hi there, Have you checked the unit for dust or dirt, sometimes things like that can cause components to stop working, things like cooling fans can be adversely affected by dust and dirt. It sounds like the cooling fan inside the amplifier unit - clear out as much dust or dirt as you can find and hopefully this should fix the problem, but if the problem persists then the short described in the manual (which I have researched) will most likely be related to the cooling fan and it's power supply - it may be safer to send it to Panasonic for repairs at this point - especially when it comes to electrical faults. Hope this helps.
Kind regards..
Mar 12, 2011 | Panasonic SC-DT310 System
F61 will not come on
F61 is an error code that shows amplifier output chip is defective and need to be replaced in Panasonic SC-AK640 unit.
Amplifier output chip replacement requires soldering work and local repair shop will do this job as it is not user level repair.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Feb 10, 2011 | Panasonic SC-AK640 Shelf System
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
F61 Error message on screen. We can't get the player to even turn on.
Most likly needs an output or voltage IC. Could be other things like a bad fan or other componant. With Panasonic models F61 is a bad voltage code.
Feb 01, 2010 | Panasonic Home Theater System System
F61 code error
Change the audio amplifier IC are damaged that´s the mean of that code
Sep 06, 2009 | Panasonic SC-AK640 Shelf System
Error Message F61
Hi guys,
just had the f61 error code on my home theatre system, now i work with samsung dvds and tv's so the background knowledge is there ( i hope), i dont know if u guys noticed the fans making a noise whenever you switched it on before the fault happened but mine were making a hell of a noise, this prompted me to have a look inside and find 2 fans both of which were very dusty, just a 10 minute clean and a 10 min reassemble and im back up and running on all channels.
hope this helps guys
Aug 08, 2008 | Panasonic Home Theater System System
F61 fault
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
Jun 15, 2008 | Panasonic SC-HT940 System
Panasonic Home Theater System System Logo
225 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
