Question about Microsoft Xbox 360 Console
My disc drive doesnt open
I push eject n it makes noise like it is going to open, but doesnt.
    Sergeant:
    Champion:
  • 378 Answers
Needs to be serviced. It will need a new drive belt inside. This happens when it gets old and begins to slip. email us for a free estimate if intersted.
xbox360fixer@verizon.net
Posted on Jan 16, 2009
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
Dvd drive door stuck
In case you're not able to eject the disc using the eject button, you can try right clicking on the CD/DVD drive under 'My Computer' and clicking on eject. If that fails as well, you can try to eject the disc manually by pushing a straightened paper clip or a pin into the tiny hole on front of the CD/DVD drive. You should be able to eject it using the last method.
GuruAid.com
May 31, 2014 | Gateway 830GM PC Desktop
When I put my game in it makes and crackling noise then does nothing
it sounds like ur disc drive is loose. if you dont get it fixed soon games will start to get stuck in the console. helpful tip when this does happen dont fret when ejecting a disc push down really ******* the console ubove where the disc is at the exact time you push eject and it should come out :)
May 06, 2012 | Sony Playstation 3 (PS3) Console
My dell 1645 disc drive won't open , I burnt a
There should ba a tiny hole on the front of the tray cover on the drive.
Switch off, get a paper clip or something about the same thickness and insert it carefully in to the hole, push it in until the tray opens.
Jan 08, 2012 | Dell Computers & Internet
My xbox 360 disk tray will not open it wont even open a little some one help me
have you tried to open the drive using the xbox dashboard, when you press the eject button does the power light flash? is there any noises coming from the drive when you try to eject.
It could be a faulty drive and the only way to get into the drive is by opening the console up and this could void your warranty. if your hearing noises (motor spinning) from the drive it could be the drive belt has snapped (like a small elastic band) you could have dirt in the gears and cogs jamming the drive. so you wouldnt hear noises (except the disc spinning if there is a disc in it).
if the power light flashes when you press eject more than likely it is the drive belt or dirt in gears.
Oct 31, 2009 | Microsoft Xbox 360 Console
My ps3 won't take the disc it is like there is a lever in the way what do i do?
did you take the drive apart with a disc in it?
There are 2 little white "bars" that pop up when the disc is inserted most the time this happens when a drive is taken apart with a disc still in it and its not in the ejected state.
if you didnt take it apart then there is prolly a cd in there still and there is a problem ejecting, if you did take it apart here is how to reset everything to the right working state. sorry if its hard to follow.
to get it back to normal you need to reset it, if its under warrenty send it in cause the only way to fix this is by taking apart the ps3 and and the blu ray drive.
ussually this happens when a drive is taken apart with cd in and you remove the loading gears cover(the black piece with the levers and the wheels) off.
when you put this cover back on you need to make sure that the wheels are open all the way --- right wheels up and to the right, ..left wheels up and to the left. When its open like that you can see the gaps where those little white bars fit into just put it back on with it open and the bars in the gaps.
usually your looking at more steps though because the rest of the hinges on the lid wont line up. you can try to put the cover back on and eject and try loading an old or blank cd, blank because if something is off it may scratch it.
see if everything works.
if not you need to re-align everything to be in the ejected state. to do that you have to manually move the long black piece on the left side of the drive(with the cd inserting side facing you) and firmly but carefully push it twards the back of the drive and the laser should lower. it may make a poping noise if you go to far but should be fine its just the piece going to far out and poping off the gear. to test it push the cd guide wheels open and it should raise the laser and you can now lower it using the eject button. if it doesnt and you just hear a spinning gear gently nudge that long black piece on the left that you pulled back earlier towards the center of the drive and it should catch itself. after every thing raises and lowers fine make sure its in the ejected state and put the cover back on. should work now.
Sep 24, 2009 | Sony Playstation 3 (PS3) Console
Cd drive won't pull disc into console
Do you have a warranty? If you do, go to the place where you got it and have them check the inside. You may have a broken gear. That could be why it does not take in the disc or eject it. =D
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Clicking noise
The only way to fix it is to open up the disc drive and reset the the mechanism that sets the disc with the laser. As the system draws the disc in, it also raises the laser unit that is hooked to a gear driven mechinism. Sometimes when dropped, kicked, smacked...etc, the gears can come off of alignment. It's a pain to repair but really not that hard. You really need some patience and a to be carefull not to damage anything. Hope this helps.
Sep 03, 2008 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
