Local Disk Problem
When I click Local Disk(C,D,E,F,G) any one of these in my computer it shows a critical message written '' C: is not a valid Win32 Application''. while exploring my computer All the local Disks shows their contents..what should I do sir ?
  • 2,559 Answers
This malicious software is dropped onto the system by Trojan-Dropper:W32/Agent.FLN. It is used to change the DNS settings on a system so that information such as passwords and credit card details can be retrieved.
During installation, this malware creates the following files:
  • c:autorun.inf
    contains the autostart routine for c:
  • c:
    detected as Trojan:W32/DNSChanger.ARNF
It also creates this directory:
  • c:
Once installed, this malware attempts to connect to a website via HTTP POST:
It is capable of changing the DNS settings in the machine to:
Go here and download,update and run this anti malware program.
Please rate this solution.
Posted on Jan 16, 2009
  • 62 Answers
Resycled/ is a worm/trojan.DNSchanger that propagates on local fixed and removable USB drives. resycled/ may infect drives via autorun.inf file it created that runs a command each time the drive is accessed. Malicious files will be copied to a drives attached on infected computer
Follow this link and do what the artical says to remove and fix. Good Luck. Please rate me thanks.
My computer encountered the critical 1191 errors how can I fix it?
What the critical 1191 error? What were you doing and when does it come up?
Will your computer boot up and allow you to use it?
Is this some type of message that pops up on your screen once your system is completely booted up? If so it sounds like a virus or infection. Try the steps below.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode With Networking option (this will give you internet connectivity) and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. Open your internet browser then download and install MalwareBytes and run a Quick Scan.
Go to and in the search box type: "Download cnet Malwarebytes" (without the quotes). Download and install malwarebytes from the sites download.cnet/malwarebytes. When the site opens up click on the Green Download button on the left. Do not click the Red Download button, that's junk. When it finishes installing the Gui Interface will open up with an offer to Accept a Trial Version or Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When it finishes removing the objects click ok and it will sometimes reboot your machine.
If this message is causing your computer not to boot up and show your desktop and icons try running the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 02, 2012 | Acer Computers & Internet
How can I defrag my Dell optiplex760?
How to Defrag a Dell Computer
1. Open the My Computer window. To do this on a Dell computer, click on the "Start" button at the bottom of the screen. Then, click "My Computer".
2. Choose the hard disk drive that you want to defrag. Locate the section entitled "Hard Disk Drives." In this section is a list of hard drives on the computer. For most Dell computers, the hard disk drive you will want to defrag is Local Disk (C:).
3. Right-click on the hard disk drive you want to defrag on the Dell computer. If you want to defrag your C: drive, then right-click on "Local Disk (C:)". A menu bar will appear.
4. Click on "Properties." "Properties" is the last option on the menu bar. This opens the Local Disk (C:) Properties window.
5. Click the "Tools" tab. The Tools tab is the second tab in the Local Disk (C:) Properties window. The tabs are located on the top of the window.
6. Click the "Defragment Now" button. The "Defragment Now" button is in the Defragmentation section of the window. This opens the Disk Defragmenter window.
7. Click to select the disk drive you want to defrag on a Dell computer and then click "Defragment." For most Dell computers, this will be (C:). After you click "Defragment," the Dell computer will first analyze the disk drive you selected and then beginning defragging the Dell computer.
8. Wait for the "Defragmentation is Complete" message. If you have not defragged a Dell computer in a long time, then the defragging process might take a while, even as long as an hour for very fragmented Dell computers. Allow the Dell computer to run the defrag until the process is completed. You will know that the Dell computer has completed the defrag process when the "Defragmentation is Complete" message appears.
9. View the defrag report and then close the window. If you want to view the defrag report, click "View Report." Otherwise, click "Close" to close the window.
Jun 26, 2011 | Dell OptiPlex 760 MT Desktop Computer
Hi , My san disk 4gb cruzer micro flash drive has the LED on when i plug it to any computer but doesn't show up on My Computer , Disk management or Device manager . I have tried 3 different desktop...
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
May 30, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My computer and mobile not showing my Micro SD card drive. please insert disk message is their. THIS IS WRITTEN ON CARD MMAGROGUECA-MB D FD1790GH 042 MADE IN COREA
First check the card. There should be a slide on the left side. This is lock and unlock. Check what poosition it is in. If that doesn't work you will have to go in the control panel and go to system/hardware devices/disk drives. Try to load another driver by clicking on UPDATE DRIVER tab. This is assuming you have a Windows operating system. Not familiar with the Apple solution.
Feb 16, 2011 | Electronics - Others
How do i find out how much free space is left on my hard drive. the computer is moving slowly
click on "My Computer" right click on local disc "C" and click on properties. This will show you in graph form how much spave you have left. Slow downs on computers are more from a shortage of ram memory and lots of temp files clogging up the system.
Feb 11, 2010 | Dell Inspiron 710m Notebook
I have recently bought Spellforce2 shadow wars. But when I reached the level sevenkeeps I began to experience problems After completing the level underhall I have been unable to proceed even though I have...
You should see if you are running out of computer memory, you can do this by going to the Start Menu-->Computer-->(Then right click on Local Disk (C) (Disk name may be different) and click on Properties this should display your Memory, and Free Space.)
If you are running out of memory you may have to uninstall, or delete some programs and files.
If this does not solve your problem repost your question so it appears at the top of the Unsolved Problems List.
Hope this helps.
Jul 14, 2009 | JoWood Productions SpellForce 2: Shadow...
Simpletech pininfarina 320gb show up but don't let me enter
Assming you're using MS Vista or XP Pro try using the Checkdisk tool. In <My Computer> right click on the drive icon, left click <Properties>. On the <Properties> screen left click the <Tools> Tab and use left click the <Error Checking/Check disk> option. Tick all options then <Start> and wait and hope.
May 09, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Partition inaccessibIe - iOGear COMBO ION GHD135C120 Hard Drive
Hi there. you may try changing the drive letter by going to disk management. Right click "my computer"icon and select manage. Go to Disk Management. check the size of the drive you're having problem with. If it still shows that there are files saved, right click the drive letter you're having problem with. Change the drive letter to Y. Try accessing after.
Mar 06, 2009 | IOGear COMBO ION GHD135C120 120 GB Hard...
Local disk access problem.....
You cant access .com in windows server 2003
Nov 11, 2008 | Microsoft Windows Server Standard 2003 for...
E.Machine Local ( D ) Drive
You need to move some files from the D to the C. First I'd check the disk space by right clicking My Computer and choose Manage, then click on disk drives. See if any drive has some space if not you'll need to delete some items.
Nov 03, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
