Question about Toshiba Satellite P205-S6287 Notebook PC
Lop top dosent boot to bios, after i attempt to up grade them
Ok todayjanuary 16 09 i was doing a up grade for my toshiba P205-s2527 bios all was well until i restarted now it turns on but thas about it,it dosent boot to bios or windows, any one have the idea of what is going on and how to get it back to normal thanks please help me, thanks
This normally happens when upgrading your operating system i.e. from windows xp upgrading to windows vista. But the problems is sometimes it can skip important things or maybe you skipped on something. A likely problem is it doesnt boot after bios because the booting order is incorrect. When you boot go to your bios. im not sure what computer you have so follow the guide on this site and the reply to this with your booting order! ONLY DO UP TO STEP 3! then if not already selected change it to harddrive but remember what it was peviously just incase this wasnt the problem. When set to harddrive try and boot again and hopefully it will work. If not then i suggest phoning up the company and asking instead of sending it to the shop as it will cost alot and they will take your computer from you!
Posted on Jan 16, 2009
  • konnpyuuta Jan 16, 2009
    hi its me again can you tell me if you computer is an Intel or what it is because i also have another solution, as other factors could result in boot up failure. If intel then you can go to bios and press F9 this will restore factory settings which will undo any changes and may work also!
PXE - Post Executable Environment also known as Pixie Boot.
this is used to build a PC from scratch on a network.
if this is a personal laptop you do not need to have this activated to turn off go into BIOS and change the boot order so the HDD is first and the network boot is last.
if you are trying to build a PC using PXE make sure you have an image server for it to contact and that your bios is up to date and supports the PXE boot
Dec 22, 2013 | Toshiba Computers & Internet
To resetting the bios for toshiba A205-s5825 notebook
To reset the BIOS read the information from this link .
In case of your HP laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 16, 2010 | Toshiba Satellite P205-S6347 Notebook
Toshiba Satellite P205-S6237 won't Boot up after full shutdown
i think there is some issues with the OS because i noticed you can't shut it down properly so maybe the files needed in order to shut down had been corrupted but one more theory, the bios settings make sure that everythings configured properly there by checking the power options on the bios setup(the blue screen)so try setting it to default and change the boot priority to HDD,CDROM,FLOPPY.
Jul 14, 2009 | Toshiba Satellite P205-S6237 Notebook
Need to unlock phoenix bios password for toshiba satellite a135-s4527
remove the keyboard the mobo battery is there you need to unsolder one end of it, lift the leg, and turn it on that way for it to clear.. you will have to resolder once done.. have the skills or find someone that does... and you're set..
Jan 16, 2009 | Computers & Internet
Master reset of my toshiba satelite
Put in the restore CD and hold down C while booting, this will allow you to boot from thh CD and select how you want to restore the computer. Alternatively, you can attempt to boot in safe mode with command prompt, and type "chkdsk /r" without the quotes, and press enter., post your results.
Jul 17, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Toshiba p205-s6237
I would boot into Safe Mode and run this utility to check your registry and startup.
You can try the original OS cd and repair the installation of the OS.
Last Resort
If that does not work then see if you can roll your computer back to a date prior to the problem starting.
May 19, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Bios password
Remove the case, find the BIOS reset jumper and short it for a few seconds, or remove the bios battery for 5 s, put it back and that's it !
Jan 16, 2008 | Toshiba P205-S6267 Notebook
Toshiba Satellite P205-S6287 Notebook PC Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
