Question about Nokia 9300 Handheld
Is there any code to format 9300 handset?
Reply me the code no. to format 9300 handset,n also tell me is there function for T9 dictionary?n in my nokia9300 handset on cover screen i m getting 6 funstions instead of 7as 1-msg's,2-call register,3-contacts,4-profil,5-settings,7-airtel live.....6th function is missing! so how can i get it?
  • SAIFJ Feb 13, 2009
    ya i have same problem
  • sffmailed May 11, 2010
    i put the code and it didnt ask for the security code or anything
    Novelist:
  • 166 Answers
you can reset your handset by any one of the following ways:
Full Reset: (clears everything off the phone memory!! Be sure to back up your contacts!!): *#7370#, and then it asks for your security code (by default it is 12345) and then Yes.
Soft Reset: *#7780#, 12345 and then Yes. (Also works on Nokia S40 phones as a full reset)
Good Luck!!!
Posted on Feb 28, 2009
How can I Install active sync on my 9300 Handset? which software I need to install?
Posted on Jul 19, 2010
How to add words to the t9 dictionary.
Adding words to your phone's T9 dictionary is quite simple.
If you have a newer model phone with newer versions of T9 when you try to enter a word that isn't recognized you should be presented with a prompt that says "Add word" or "Spell".
If you have an older version of T9 don't despair you can still add words. All you have to do in this case is: switch from T9 mode to "abc" mode and spell the word one letter at a time, hit the space key, then switch back to T9 mode. Whatever word you just spelled has now been added to your T9 dictionary.
Jul 24, 2011 | Cell Phones
I want to know how to activate T9 dictionary in my Nokia Supernova 7210 classic.
In write message option hold on the hash(#) button to activate the T9 dictionary; or simply go to options menu select T9 dictionary and activate it.
Jul 22, 2011 | Nokia Cell Phones
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
How do I edit the dictionary on my samsung tocco ultra. I type 'is' and get GP, for 'the' I get Vid. Driving me crazy how do I delete these? thanks
Not a solution same problem. If I type "is" I get 4M suggested. If I type "of" I get Nd suggested. Driving me nuts !!
Jan 02, 2010 | Cell Phones
How do I delete auto text words from dictionery Samsung GT 8300
No, u cannot delete the auto text word from the build-in dictionary function name T9, but u can disable this auto text mode.
When open a new text message, just press the icon ABC to change the mode to ABC, T9 or number.
YBC (/\)
Oct 08, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Get dictionary
go to messages then when writing a text select options scrol down till you see t9 and activate
Apr 29, 2009 | Nokia 6300 Cellular Phone
Samsung SGH-c225 predictive text malfunction
If you have accidentally saved a word into the T9 dictionary (ie, "IS" comes up with "47" or "Get" comes up with "HDU", you can teach the dictionary to revert back to the original word.
What you have to do is..... create a new text message, enter the text that is annoying, (ie, "IS"). When you type the word and it comes up with the annoying one, select the word that you wanted and enter a space, and do it again and again - you can do this in the same text message - it can take up to 20 goes but eventually, the dictionary recognises that you actually wanted "IS".
Nov 13, 2008 | Samsung SGH-c225
Formatting nokia 9300 comunicator
how code format nokia 9300 comunicator
Feb 23, 2008 | Nokia 9300 Smartphone
Turning off T9 dictionary
It's the asterisk key (*) - had the same problem on the E250 I just bought :)
Dec 28, 2007 | Samsung SGH-E370 Cellular Phone
Unable to turn off t9 dictionary
try to hold the # button, or press it a few times durring the text message - it should flip from t9 to standard and maybe even symobls.
or else go into your message, being a new message then go to options - you should see some option change from t9 etc.
Dec 23, 2007 | Samsung SGH-D600 Cellular Phone
Nokia 9300 Handheld Logo
1,358 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
