Question about Plumbing
Cold water tap not working, house heating not as strong.
Our kitchen Cold water tap has stopped working, either no water comes out or just a trickle. The hot water tap works as well as the bathroom taps. We have noticed as well that the heating is not as strong as before.
Last week we had the control box that control the heating (gas) replaced as the last one broke. I dont know if this has any relation to the problem. We had some cold weather last week but this week the temperatures are above freezing so probably not a frozen pipe. Perhaps a faulty tap ?
    Scholar:
  • 35 Answers
Okay let's trouble shoot this problem. The Hot water issue may just be that your Temp. control is not set as high as it was before it was replaced. Find the control on the water heater and check the setting. You can adjust it hotter from there, but it is not recomended to set it all the way to HOT. Just increase it at small adjustments and see if the water gets hotter. The Cold Water Tap issue.....Turn off the Cold and Hot water supply lines to the faucet. Remove the Cold water tap. VERY SLOWLY TURN ON THE COLD WATER SUPPLY and see if you get water coming out of the line. If you get water, then your line is okay. Inspect the valve to see if there is any debris in or on it. Clean and reinstall both taps and turn back on the water. It should work. Now if you turn the water on SLOWLY when the Cold water tap is removed, and no water comes out, Then you know you have an issue with the line going to the cold water side. (Frozen Line, Debris in supply line valve, Broken or Leaking Water Line) I hope this assists you........Joe
Posted on Jan 16, 2009
Why no water will come out of the water heater
Is there a shutoff on the hot water line coming out of the tank? Is this problem only at one tap or all of the taps in the house? Is the cold water supply to the tank turned off? If it is no water will flow since the cold water pressure pushes the hot out of the tank.
Aug 29, 2014 | Water Heaters
Bungalow no cold water coming from kitchen tap
Have you tried your stop tap it is normally under the sink or it could be you taps have single stop devices all you need is a screw driver to turn it and there is a stop tap outside everyones house has that been turned off message me i can help further
Aug 14, 2014 | Washing Machines
Hi, we have no water coming out of ours taps, in the kitchen=no cold at and a small slow dribble coming out the hot which is cold.The bathroom= small dribble of out of cold tap and small dribble out of hot...
water sounds like it is off at the mains which could be in the flat below , need access to there to check, or it been cut off for non payment , heater would not stop main flow , it is off at the main
best I can tell you ,
Jan 29, 2011 | Heating & Cooling
No water pressure
Check all valves are open, cold in bottom, pushes hot out top, and if cold at tap is doing same, take aerator off tap and see what happens. Is same thing happening at all taps?
Apr 25, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Caravan water heater not letting hot water through
pipes are rusted and cloggen from the inside of them
Jun 17, 2009 | Sport & Outdoor - Others
A trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
May 18, 2009 | Water Heaters
Hello, I live in Dubai and have a 5 year old Fisher Paykel IWM12 top load washing machine that just developed an issue. When starting a cycle it "auto senses" the water level, fills up then tells me...
First question that comes to mind is why you would want to have a machine if their is no service support where you live. I assume you have done the basics like taking hose off machine inlet and pointing it in to a tub, turn tap on and make sure there is a good supply of water. Put hose back on machine, fully open tap & start (on cold supply). Lift lid while it is filling. Check that a strong flow is coming in to machine. Then repeat with the hot tap. If water is only trickling in & sounds like it is struggling then more than likely it needs a new inlet water valve.
Jul 15, 2017 | Fisher and Paykel IWL12 Top Load Washer
Cold water only trickling into my washing machine
unfortunately it sounds like you have a stuck plunger in the cold side of your water inlet valve.if the screens are clear and your water pressure is good,thats what you have.
Sep 25, 2008 | Washing Machines
Cold water only very slowly trickles into the washer. Hot water works fine. Cold water has very good pressure and volume at all other sources in the house. The cold water hose at back of washer is clean...
there can be 3 reasons for this I will tell u the easiest way to test this first
Problem1)turn the water off at the blue tap fitting that is proberbly under your sink take the blue pipe off at the washer end and place it into the sink turn the blue tap back on if the water comes out quick then the problem is more then likely your cold water solenoid that is either slightly blocked were it fits to the washer,But if it doesnt come out quick then the other 2 problems are as follows.
Problem2)the blue tap that u turn the cold water on to the blue pipe undue the little screw in the middle of the tap and pull the blue fitting off now with a pair of pliers turn the square metal fitting that was under the blue fitting making sure that the end of the pipe is in the sink if it comes out quick then that is the problem the blue tap fitting is rounded off when ot should be square turn the water of and replace the pipe and turn the water back on the cold water should be better now.
Problem3)the blue tap that u turn the cold water pipe of at the copper pipe is blocked or it has a broken shut off valve inside it this will need replacing these are the only problems that it could be let me know if this is any help to u peter
Jun 09, 2008 | Whirlpool Washing Machines
Plumbing Logo
1,274 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
