Question about Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and
Keeps running I have a delta T13022 series shower valve, and I can't get to shut off or control the hot and cold water.
    Problem Solver:
  • 16 Answers
Sounds like you need to replace the inner cartridge. You can shut your water off at the street meter if your whole house does not have its own external shut off. Be sure to relieve the pressure before popping out the cartridge.
Posted on Jan 17, 2009
When turning shower valve to warm position the pipes start to hammer. the shower valve is a delta 13/14 series.
air in the system find the source of the noise usually a dip in a long run and insert a pipe clamp in two positions 1 ft apart then try again if this fails power flush the system
Sep 14, 2014 | Delta Home
Can't get both hot water running at the same time. Delta Shower faucet
  • The spool and sleeve, the part of the Scald-Guard pressure balance valve that blends the hot and cold water, is not working properly. This can is caused by mineral deposits that build up over time resulting from hard water. To fix this, follow the steps below based on your model.
  1. Shut off water supply.
  2. There are two types of valves. Choose one or the other below depending on your series.
  • 1300-1400 Series: Remove handle.
  • 1700-1800 Series: Remove temperature knob, cover and handle.
  1. Twist and pull sleeve to remove it.
  2. Unscrew brass bonnet nut.
  3. Remove cartridge.
  4. Soak cartridge in a 50/50 vinegar and water solution for 24 hours to remove any mineral deposits.
  • **NOTE** Unless both hot and cold water supplies are turned on, the pressure balance valve will allow only a dribble of water to flow through the valve.
  • I have put up a picture to make disassembling it just that much easier for you.
Regards, Tony
May 23, 2011 | Delta & Single Handle Shower Faucet
The water temperature will not get hot enough
there is an internal cartridge with little valves that control the mix of hot and cold water. Over time the cartridge can get crudded up with calcium or the small valves can fail. Delta's website can provide you with the part you need...
Oct 15, 2010 | Delta & Single Handle Shower Faucet
New Pegasus shower valve that does not get hot water
single water handles are often put back in 180 degrees off, remove the shaft and turn it over
Aug 02, 2010 | Union Pegasus F1228100PBV Series 5000...
We have a newly installed Delta single-handle shower faucet and cannot figure out HOW to get a warm water mix. No matter where we turn the handle, we get different temperatures of "cold."
That is a graduated water mixer valve, and it sometimes has a little white water restrictor blocking flow from your hot water port. See if that was left in by removing the handle with all water shut off to the valve and reattach then try again. This can also happen if you have a tankless water heater because pressure controls heat. Typically a Tankless water heater system will require little, to no cold water to your bathtub valve because of the heavy water flow at the tap. Remember, flow equals temperature. Less flow = more heat, more flow = less heat.
Mar 09, 2010 | Delta & Single Handle Shower Faucet
Shower faucet does not switch to hot.
This has happened to me in the past and had exactly the same symptoms but with a different valve. Before trying the below, it may make sense to be 100% sure that hot water is definitely getting to the valve .. can you get access to touch the hot feed pipe to make sure that it is in fact the valve at fault.
The following could be the issue:
1. The shower valve has a bit of dirt or gunk in it and is unable to allow the hot water through. It can happen with a very small amnount of dirt and is a real pain as it requires disassemble of the entire valve assembly.
2. The valve has failed and needs to be replaced - This was the solution to mine and was also significant in terms of effort.
Hope this helps, if so please leave feedback, if not let me know and I'll try and help some more!
Feb 02, 2010 | Delta T13420 Chrome Classic Single Handle...
Pressure is high can it be adjusted?
Is this a new install? Is this happening with cold and hot water, or just one? Is it just happening with the shower valve open if it's not a new install. it may be the shower valve bad. These can be replaced easily, Lowes $7-14 depending on brand. The water has to be shut off from coming in to the shower. If it is happening with the water running on either hot/cold, the each one has a valve like the shower knob. These go bad and are replaced the same. These release to much water when the rubber seal breaks down inside the valve. Let us know which way it's happening and maybe able to help more.
Jan 02, 2010 | Delta & Single Handle Shower Faucet
Low pressure on Delta 1400 series shower head
The Shower Valve is regulated to give only 2.2 gallons a minute. If you have the shower head off test how many seconds to get an approximiate gallon running in the middle hot/cold position. If longer than 30 seconds either the stem in the valve is clogged or the water lines to the valve are too small or kinked.
Phil
Dec 05, 2008 | Delta Faucet Company RP26755 Sleeve...
Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and Logo
197 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
