Question about Harman Kardon AVR 25 MKII
HK AVR25 MKII goes on and off numerous times on cold power up
When I turn on my HK receiver it turns itself on and off numerous times. This only happens on a stone cold powerup and only the first time I turn it on each day. Once it stops switching on and off it works just fine. It turned itself on and off 154 times today before it began working. Once it is working, if I then turn it off and turn it back on, it works fine. HK said it could be shorted speaker wires and the receiver is going into "protect" mode but I doubt this. The speaker wires aren't moving around. If there was a speaker wire short somewhere that wouldn't fix itself each time I turn it on. They also suggested that it is overheating but it only does it when I turn it on when it is at room temperature. The only other suggestion HK gave me was an "internal" problem which likely will cost more to fix than a comparable new unit.
  • 1 more comment
  • lukievan Apr 26, 2009
    i am having the same problem - when i turn the unit on it starts this
    fast clicking thing where it seems like it is powering on and off very
    fast. Eventually it slows down and finally is 'on' but the time to get
    there is longer and longer.. It's a power supply issue,. ,I'm pretty
    sure, but all the fuses look good. Thanks.
  • poorsparkie May 09, 2009
    Solution #1posted on May 08, 2009
    Asker's Rating
    poorsparkie
    Rank: Apprentice
    Rating: 0%, 0 votes
    The relay on the PWR SUPPLY board clicks once when the PWR switch is turned on then 2 to 5 sec. later it clicks again and 'off' it goes.
    The small transformer ( standby power) on the board appears to be leaking crud (looks like wood glue) all along one edge.
    Can I bypass this relay to see if the power transformer is 'ok'?
  • lukievan May 11, 2010
    btw, i think i've isolated the component that is making the noise - it's a small black rectangular piece that's on the circuit board that the fuses are on.
Posted on May 08, 2009
    The FixYa Pro sent me to http://www.eserviceinfo.com for the service manual. With that in hand he directed me to the problem; which is the output amplifer section. 6 transistors on one side and one big IC STK on the other of the giant heat sink in the middle of the unit.
    After I test each transistor I will replace the bad one and hope thats it.
    If anyone has better ideas E me at brockselectric@live.com
    happy sparking
HK AVR 247 no power up
Could be an open internal fuse or power supply failure.
Sep 19, 2016 | Harmon Kardon Harman Kardon H/k Avr20 Mkii...
HK 3370 power button turns red when pressed device will not turn on
There may be a short on the output side. Try disconnecting all the speakers on the back of the amp. If the unit stays on after that, turn off the amp and carefully reconnect one speaker at a time. Try turning on the amp after each reconnection. This might isolate any shorts that might exist.
Nov 09, 2013 | Harman Kardon HK 3370 Receiver
Does the Harmon kardan avr25 have an hdmi output
Nope. You get one component OUTPUT (monitor) and two component INPUTS (Vid 2/DVD) but no HDMI video output.
If you can input and switch HDMI video directly at your display from your cable/SAT etc. you should be fine, just run all the audio through the AVR-25 through the coaxial/optical digital inputs, L/R analog RCA or the 5.1 direct inputs.
Feb 13, 2013 | Harman Kardon AVR 25 MKII
HK 3370 turned into protection mode after pluging in a playing iphone. Happened more than one hour ago but hk3370's power light is still red. How do I get this thing out of the protection mode?
turn unit off using main power button, hold down t-mon and cd buttons at same time as switching main switch on should power up and show reset on the display for a short time then dhould go to standby this has reset unit and should now be ok
Jan 10, 2011 | Harman Kardon HK 3370 Receiver
Voice of both left and righ speaker is not equal
Can say I've seen this on a H/K. First swap the speakers left to right and right to left if the sound is low on the same speaker its the speaker not the receiver (could have a driver out). Could also be a dirty output relay.
Is the sound good other than it being low?
Is it that way with all inputs?
Jul 17, 2010 | Harman Kardon AVR 25 MKII
My HK 1005 incresases volume to max by itself
I had the same problem; got rid of it by changing the baateries of ma remote control.
Jun 27, 2010 | Harman Kardon DPR 1005 Receiver
My HK 3380 doesn`t turn on...
If the display does not turn on, then you have a power problem. The unit is not completely turning on. Since you opened up the unit, give it a sniff test to see if there is any burnt odor inside the unit. Check the fuses also. Have a look at the transformer board. It may have several fusible resistors sitting high on the board. If they burn open, there is no power to the display/cpu board.
Mar 22, 2010 | Harman Kardon HK 3380 Receiver
HK avr-25 - everything seems to work except sound is not being amplified. What could be the problem?
Check the speaker 1/2 buttons that turn the speakers on and off, they have a habit of getting corroded. Click them in and out about 20 times each.
Play with the balance knob, run it side to side about 20 times. Turn the unit off and do the same with the volume knob.
Ensure mute is off.
Check that the tape monitor is off.
Check that you are on the correct input.
I cannot remember if the MK2 had pre-out to main-in bridges on the back, if it does make sure they are pluged in all the way.
Let me know if this helps,
Cheers,
Kevin
Feb 03, 2010 | Harman Kardon AVR 25 MKII
AVR25 II just shuts down
I would recommend shopping for a new receiver. Sounds like there is a relay, capacitor, and or power supply problem that keeps causing damage to the circuits which if continues could cause speaker damage and issues with equipment that you have hooked up to it. But if you choose to have it worked on again, i recommend purchase of a UPS (uniterruptable power supply) that is capable of regulating to voltage.
Jan 05, 2009 | Sony A/V Receiver
Amp comes on and goes right into protection mode
Turn the reciever on for a second or two and then off before the protect mode shows up on the monitor. Repeat this step about five times and check to see if the reciever does not go into protect mode. If it does go into protect mode try it again. Dont know if this is the proper way to fix the reciever but it worked for me. Good Luck
Mar 09, 2008 | Audio Players & Recorders
270 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
