Question about Evesham Emedia Ebox (EBOXAPR04) PC Desktop
Bad hard drive back up and replace on evesham ebox
Hi peepes, i'm looking for advice/help to replace a hard drive on Evesham Ebox it was supplied with Win MCE 2005 installed on a Maxtor 320gb hard drive.
Prior to crash I'd run "disk-check" - re-installed OS several times but now will not start at all after several notifications of - " bad hard drive, back-up and replace".
Any help please.
Chris
  • nashyboyslim Jan 19, 2009
    Thanx Lotech, I had already lost evertthing - but hey, I have now installed a new Seagate HD and all looks well so far. Cheers.
    Novelist:
    Champion:
  • 233 Answers
The only thing I can think of is you might hook up the drive as "slave" drive on a working computer and see if it will operate long enough to retrieve your data. But if the drive is dead you may have lost everything that was on it. There are services that do data recovery on dead hard drives but I'm sure it is expensive to have this done. This is why I always back up everything I do to a different device while I am working.
Posted on Jan 16, 2009
Evesham ebox was working fine and now won't turn on. any idea's? i've changed the fuse but thats as far as my knowledge goes.
Give it the old sniff test. If you smell something unusual coming from any of the vents, then there is probably a blown component. The capacitors on the power supply are a common failure point. If you don't mind opening it up and doing a visual inspection, see if you see any small tube like parts that are bulging or perhaps broken open. Obviously, only do this with the device disconnected from power. Speaking of power, double check that it's plugged in well and that other items plugged into the same outlet get power as I have had a surge protector where a single outlet stopped working.
Nov 11, 2017 | Evesham Emedia Ebox (EBOXAPR04) PC Desktop
Hi i have lost my audio driver for a evesham ebox
I cant find any info on your computer, the company stopped trading in 2008, but you can use some software to check everything about your computer.
I use PC Wizard by CPUID, its free and will tell you everything.
Find it here http://www.cpuid.com/softwares/pc-wizard.html
Jul 08, 2010 | Evesham Emedia Ebox (EBOXAPR04) PC Desktop
Need to replace / upgrade my RAM. What type is it ?
The type of ram you will be looking for is DDR SDRAM (186-pin). Each stick can be around 128MB to 1GB. However, you should look inside your computer first to make sure you can upgrade it and know how many slots are available for you to upgrade. If you do have a manual, check the Qualified Vendor List to see if the memory sticks are compatible.
Mar 08, 2010 | Evesham Emedia Ebox (EBOXAPR04) PC Desktop
Motherboard problem
check to see if the radio card is turned on.
Jun 08, 2009 | Evesham Emedia Ebox (EBOXAPR04) PC Desktop
I have an Evesham Ebox and the motherboard has failed. It's details are; K9mgm-2 ms-7252 version 1.2. Do you know if it is possible to buy a replacement? Thanks
It does not appear as if that motherboard is still available for purchase. The only thing I can tell you to do is contact that Manufacturer directly and see if they can replace it. This will likely be very expensive though.
May 13, 2009 | Evesham Emedia Ebox (EBOXAPR04) PC Desktop
Ebox fails to load up
Evesham is no longer in business but the following url is for a company that supports their products..
http://www.tewktech.com/
As a matter of fact, I understand this company has ex-Evesham employees. Good Luck and please rate this solution .....
Mar 11, 2009 | Evesham Emedia Ebox (EBOXAPR04) PC Desktop
Evesham ebox - Sleep function
Hi, Azrul here, from Malaysia. You can disable the sleep function for your HP Media Center m7250n before connecting to tv.
Go to control panel
then go to display
then go to power under the screen saver's tab
then set your power options to never go to sleep at any settings.
Dec 21, 2008 | HP Media Center m7250n (ED842AA) PC...
Pc srceen has gone a red colour is they a reset
As a matter of fact, I understand this company has ex-Evesham employees. Good Luck and please rate this solution ......
Sep 06, 2008 | Evesham Emedia Ebox (EBOXAPR04) PC Desktop
Fails to start and lost Windows Startup CD!
Jun 28, 2008 | Evesham Emedia Ebox (EBOXAPR04) PC Desktop
Evesham Emedia Ebox (EBOXAPR04) PC Desktop Logo
358 people viewed this question
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
