Question about Apple MacBook Pro PC Notebook
What's the procedure for starting up my Mac Book as a firewire hard drive?
I want to transfer files onto my new Mac Book. Does anyone know how to make it act like a fire wire hard drive so I can just drop file onto it from my old computer?
    Problem Solver:
  • 15 Answers
Restart and hold the 'T' key to boot in 'Target disc mode' How to use FireWire target disk mode. http://docs.info.apple.com/article.html?artnum=58583
Posted on Jun 19, 2007
SOURCE:
I have a sony handy cam DCR - DVD105, I want to know all the ways of being able to connect it to a laptop and extract the files to use in other softwares, like Window's Movie Maker, or Power Direct 09.
How to load Mini DVD to Mac
  • Though Mini DVD can not be played back in Mac slot loading player, we have other ways to load Mini DVD to Mac.
  • Method 1 If Mini DVD camcorder has FireWire or USB; just connect the Mini DVD camcorder to Mac using FireWire, or USB to load Mini DVD to Mac.
  • Method 2 If Mini DVD camcorder has not FireWire or USB; just shop for external mini-DVD drive that uses either a USB or Firewire connector cable, and then connect the external mini-DVD drive to your Mac and install any extra software that came with it. Insert the mini-DVD into the external drive, and then access the files on the mini-DVD as you normally would to load Mini DVD to Mac.
  • Method 3 If Mini DVD camcorder has not FireWire or USB; buy an adapter that converts a mini-DVD to a normal DVD by adding on a circular plastic piece that emulates the full size of a regular DVD. Attach the adapter to the mini-DVD and load it into the Mac's DVD drive to access the files. (Check the specifications of the adapter before purchasing, as several on the market do not work in vertical-loading drives like those found on the MacBook Pro.)
  • Method 4 If Mini DVD camcorder has not FireWire or USB and you don't want to buy a separate external drive or full-size adapter either, but you do have access to a PC, you can transfer the files on the mini-DVD onto the PC, then put them onto a USB flash drive, which will work on your Mac.
more detailed at http://www.bigasoft.com/articles/easy-solution-to-import-midi-dvd-into-imovie.html
Apr 21, 2011 | Sony Handycam DCR-DVD105 DVD Camcorder
I have new mac book pro. I also have an old laptop running 9.2. Return how do I get files off old computer word 98.
This can be done in a couple of ways.
  1. Boot the old laptop and copy the files onto a USB drive.
  2. Using Firewire, you can mount the old computer on your new one as an external drive.
Feb 23, 2011 | Apple Mac OS 9.2.1
I work with OS X (mac) , I can not copy a file bigger that 4 GB into my WD my book. I 've tried to change the format, but i can just chose between : Mac OS Extended ( Journaled) ,Mac OS Extended, case-...
Although Macs are designed to Read NTFS, they aren't designed to write to them and therefor cannot format a windows drive. If you are simply moving files onto the Mac from a windows PC you can format the drive using a PC and the Mac will be able to read and copy the files from the drive. If your goal is to have both windows and Mac read and write to the drive, your best bet is to use Mac OS Extended, then to buy and install Macdisk on your Windows PC. This will allow both to fully utilize the drive.
Any file size limitations you're running into at that point would have to be dealt with through compression or you may need to set up a NAS server that uses either NTFS or Linux format and copy files across the network rather than through a direct port like USB or FireWire.
Feel free to respond back and pick my brain if this advice only gets you half way solved.
Hope this helps FixYa,
Chris
Dec 23, 2010 | Western Digital My Book Essential Edition...
I have reformatted my passport for my mac but now when i transfer photos they are all one at a time. how do i create files for each event?
Use "shift-click" or "control-click" to select multiple files, and then drag-and-drop the collection onto the W.D. icon.
Dec 13, 2010 | Western Digital My Book Essential Edition...
How do i back up a power book g4? What application do I need to do the back up?
Suchisart,
If you want a stand alone backup solution, you can download a free program called "Carbon Copy Cloner" and purchase a USB 2.0 external hard drive. You can use the CCC software to backup the entire contents of your Powerbook's hard drive or just selected files to the external USB hard drive.
If your Powerbook is unable to boot into OS X and you need to recover the files that are on the internal hard drive, you can boot the Powerbook into "Target Disk Mode" and transfer the files via firewire cable to another Mac. To do this do the following.
  1. With both Macs off connect them with a firewire cable.
  2. Turn on the Powerbook and hold down the "T" during startup.
  3. Once the large icon shows up on screen your in "TDM".
  4. Turn on the other Mac and login to your account.
  5. The Powerbook's hard drive should mount on your desktop.
  6. You'll be able to transfer your files from the Powerbook's hard drive just like you would an external hard drive, thumb drive, etc.
Don't forget to vote and leave us some feedback. :)
Thank you,
Scott Computer Services http://www.scottcomputerservices.com
Feb 16, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Read only firewire now- wasnt before
mi disco duro portatil de la marca pleomax model uhd-8g ya no habrá,
siendo un obsequio solo se me entrego la uhd,
tengo documentos del trabajo, y ya no quiere abrir, que hago.
atte. Jorge Rguez. Tepic, Nayarit , México
Jul 21, 2009 | Western Digital My Book Essential Edition...
Mac not recognizing External Western Digital HD.
the problem is that your western digital operates using the NTFS (New Technology File System) which is the standard file system of Windows. Apple macs is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Jun 02, 2009 | Western Digital My Book Essential 1TB...
Lacie RUGGED 250GB not recognized by my PC
I think the migration assistant (in the utilities file in your application folder) can transfer files direct via USB.
Jan 23, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
Oct 29, 2008 | Iomega (33090) 250 GB Hard Drive
How do i transfer files from maxtor
THe "One Touch" devices are usually USB/Firewire... As such it should connect up to the Mac USB OK.. then, it should show up as a "Drive" where one could then, with the right software be able to transfer files to & fro without too much trouble.
Sep 22, 2007 | Computers & Internet
Open Questions:
jBUyzt [email protected] Amazon Prime rEfUnD pHoNe #{+1-85O-8I2-4OO9} USA how to get refund from amazon prime? Amazon Prime Membership Cancellation Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 21, 2019 | Amazon Computers & Internet
SBCglobal MAil HeLpliNe /*-+{1^855^536^5666}#[email protected] +-*/PHoNe NuMbER CUSTOMER HELP This SbcGlObAl mAiL USA phone number is ranked #2 out of 2 because 7,728 SbcGlObAl mAiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbcGlObAl mAiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbcGlObAl mAiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbcGlObAl mAiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbcGlObAl mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbcGlObAl mAiL USA Calling SbcGlObAl mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbcGlObAl mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbcGlObAl mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbcGlObAl mAiL USA's phone numbers against each other. Contacting SbcGlObAl mAiL USA in General While I********** is SbcGlObAl mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbcGlObAl mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbcGlObAl mAiL USA.
Oct 21, 2019 | Best Computers & Internet
See all Apple MacBook Pro PC Notebook Questions
Apple MacBook Pro PC Notebook Logo
73 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
