Question about Bose Companion 3 Computer Speakers
Bose companion 5
I am a soldier over seas in Iraq. The power source here is 220v and we use converters to step down to 120v. now i have a xbox 360 that i wanted to use for the input. i have the right jacks for it to work. Now when i pluged the xbox 360 to the bose companio 5 aux input the volume was not max but it was loud enough to hear. Then all ove the sudden the sound went out and the convertor fuse blew. the Convertor is rated at 1000W and the 360 pulls 3-600w, bose about 200w. i am thinking it was an audio input power spike that might have caused this. their was a smell coming from the back of the system. the system does not turn on nor does the light to the controller. any one have any ideas on how i can fix this?
  • 2 more comments
  • jemztrk82 Jan 16, 2009
    it is not a power adapter proble, the fuse on my convertor has been replaced and all power going to system are good. now there is a fuse (250v)on the cca inside the system but it is not blown either
    IS there anywhere i can get parts? i am in iraq nd postage is a hastle/
    i am a ET in the military i understand its not the fuse. i am wanting parts where could i get some online? and i dont want to deal with bose if i dont have to
    my xbox 360 isnt the problem every thing else works perfect right now except for the bose.
  • 1,596 Answers
First Off I want to THANK you and Your Fella's For Representing and Puttin iton the Line like you are May GOD be With You ALL
YOU May Have Goten Lucky and Fried a DIOD that will be close to the Cord as its soldered to the Board they are Black W/ Silver stripe Around them. But UOCH let the Smoke out of it is Not very Promising,,Sorry hopefuly you get Lucky
I hope also I have been of good Info for you .
Please Dont forget to Rate me..
Most Importantly STAY SAFE Brothers/ Sisters
Posted on Jan 16, 2009
  • 679 Answers
Try the link>>
http://www.pcmech.com/article/bose-companion-3-series-ii-speakers-review/
  • rockfixya
    rockfixya Jan 16, 2009
    another link >>
    http://www.bose.com/controller?event=VIE...
  • rockfixya
    rockfixya Jan 20, 2009
    please let me know if problem solved.
    Thanks for using FixYa.
  • 685 Answers
Have u tried ebay for the part you need also you could go straight through xbox themselves and get the part u need
    Sergeant:
  • 367 Answers
Call microsoft tell them your a soldier over seas and your xbox died. have them ship you a new one. you may get lucky and they may send you a replacement
Thank you for serving our country. It is people like you that keep us all safe.
  • 54 Answers
It sounds like there were to many volts for your xbox to handle and blew the mainboard. Sadly it sounds like the xbox is shot. I would recommend powering it from a tv instead next time. I would see if you can get the xbox covered under warrenty and dont tell them about what did. You had a power spike and most likely fried the main board. I am dorry and I hope this was some help.
    Guru:
  • 859 Answers
Benimur already gave you the best advice. The issue is not the fuse blowing. It is in how fast the response was before the fuse blew. Are you connected to a battery backup first and fore most between the outlet and your components? A fuse, doing what it does does its job well, but the response time is inadequate. A battery backup in between the wall and the components will resolve this by responding to a spike quickly.
That being said, there is nothing a do it yourself solution can fix, the unit is blown. After it is fixed, then put a battery backup between the wall and your electronics, all of them; not just the xbox, but all your stuff, if you value them.
Regards, and best of luck.
Worldvet
    Genius:
  • 1,913 Answers
I think your system is vibrate and so your speker is sound like huming.
check your speaker in other cpu .or player.
then repair your cpu vibrati or power .
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my understanding, two issues to address:
  • XBox 360, normally the power supply is not repaired, it is replaced. Possible sources are here, here or here;
  • if you are considering a DIY (do-it-yourself) repair, you might be better off modifying a computer PSU (power supply unit) or as shown here;
  • the Companion 5 are somehow "sealed" after the fuse area. Most likely, replacement of main board and power supply. The amplifier section is on the main board also. Unfortunately a service center is required;
  • You can try looking over the country here and the page will display a Bose contact information.
Pls post back result(s). Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Jan 16, 2009
    I understand fully now your concern. To your repairs:
    • there would be 2 possible way the amplifier is powered, either a transformer with bridge diodes and filter capacitors. Voltage going up on the primary would open it, on the secondary a diode could have opened or shorted. The filter capacitor would definitely need to be looked. It is a simple power supply and being an ET you would have no problem with that;
    • the other possibility of the power supply is an SMPS (switched mode) where the 120 VAC input is converted immediately to DC. normal culprits would be the 470uF/200V or something like that capacitor;
    • where to get the parts - any electronics supply store would have the diodes, capacitors and even the amplifier IC. They are pretty standard. Except for the speaker and the sound processor (if one is installed), everything inside should be available. Of course it would depend on where you are and if any electronics shop/stores are near you;
    • the only challenge would be getting access to the inside to pull the power supply and the main board out to enable you to work on it.
  • 10,594 Answers
No fix on do-it-yourself basis. Amp out chip is cooked and unit needs Bose service center guys to fix it.
  • 153 Answers
Fix the adapter
How to change power supply from 120v to 220v
Need more clarification, please.
Is your Printer using 120v and your Source is 220v ?
If So, Simply buy a converter / Step Up Transformer to do that job for you.
Nov 11, 2016 | Office Equipment & Supplies
I just bought a computer speaker but it's 110v and my computer is 220v. can i plug the speaker to the computer without damaging the speakers?
Hi ,
If it says it needs a AC 110V connection , you will fry at least the sub . Don't do it ! Connect the device to an AC 220 / 110 V transformer you can find on the net or in all specialized retail shops .
Best regards
Feb 03, 2011 | Bose Companion 5 Multimedia Speaker System...
I wanted to purchase a Bose companion 3 set from the US through ebay. i wanted to know whether they work on 220V and if not how can I make them work at 220V.
Since this unit dose not come with power adaptor. It has direct plug in in to the port behind the sub-woofer unit and other end to the wall outlet. Is there any way to convert the power supply from UK to US (220v to 110v). For example Desktop PCs have a switch behind every desktop unit to change power from 110v to 220v or vise versa.
Anyone has any idea how to make this happen in Bose Companion 3 system.
I bought it from UK and now moved to US and I want it to work in US.
othervise use waltage adapter to use it
Aug 08, 2010 | Bose Companion 3 Computer Speakers
Does the Bose companion 3 have an internal fuse?
Yes. The companion 3 system can be repaired for $75. Call Bose at 800-367-4008. They will also give you a new 1 year warranty.
Jun 19, 2009 | Bose Companion 5 Multimedia Speaker System...
Companion 3 problem
It is not the pod that isn't working, a 220v power supply would overload the circuitry in the subwoofer. And since the damage is done, a step down converter would be no help at this point. I would take it to a electronic repair shop and have them take a look at it.
Aug 11, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 5 Problems
email support@bose.com or contact a Bose Support Specialist in Germany; or call US support at 1-800-367-4008. Something very odd is happening here. You are using the same laptop, correct? If not, let me know, as there are some things to try. If Bose has a solution, I'd love to hear it.
Mar 19, 2008 | Bose Companion 3 Computer Speakers
Power brick red light
yeah you definitly need to have a uk to usa power converter. you guys run on 220V which would create way more current then needed which is why the power supply blew. I hope you didnt fry any internal parts in the 360. You need to get a power converter that gives you 120V.
Dec 26, 2007 | Microsoft Xbox 360 Console
Bose Companion 3 Computer Speakers Logo
90 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
