Question about HP Fax 1240
Plugged printer in wrong voltage Hello I will really appreciate your help! I have a HP laserjet 2300, I plugged the power cord in 220v and it is for 110v, what sholud i do to fix it. I have knowledge about how to take it apart, does it have a fuse in the power supply? Do i have to replace the whole power supply? Thanks so much for your help!
    Champion:
  • 320 Answers
If you plugged the printer in to any thing higher then 110 volts and i donot knw how you could do this your machine may be fried
Posted on Jan 19, 2009
98.01.01. error on HP LaserJet 600 M602
Try this:
Turn off the machine
Take the toner/cartridges out of the machine
Unplug the power cord from the wall
Wait 30 sec
Plug the power cord back into the printer and wall (Make sure the printer is plugged into the wall and not a surge protector)
Insert the toner/cartridges back into the printer
Turn it on and test
Nov 29, 2013 | HP LaserJet 3030 All-In-One Printer
HP Deskjet 1056 supposed to be dual voltage...?
What does it say on the "brick" on the cord? Look for power specs on the cord transformer.
Dec 10, 2012 | Office Equipment & Supplies
Hp color laserjet cp1215 wont turn on
try a different outlet, especially if you are using a power strip. Sometimes even one outlet in a strip can fail. Not sure how farther you tried other than check the power cord. If other devices work on the same outlet hole you plugged you machine into then, try another power cord. If that does not help then you will need to seek a tech.
Nov 07, 2012 | HP Color LaserJet CP1215 printer...
Plugged 220v Mistake
If the printer is designed for 110v and you have plugged it into 220v then most like you have damaged your printer beyond repair. The cost of repairs may be slightly less than the cost of a new printer.
Jul 07, 2012 | HP LaserJet 1020 Printer
Relocate to new home, plugged in printer and turn on switch- nothing happens. Is there a fuse I can check?
First thing I would Check is that the outlet you have plugged it into has power just to humor me plug a known working device into the same outlet to see that the outlet has power if it does then check that the power cord to printer is plugged into the socket and back of printer tightly also some power cords for printers seperate in the middle near the power converter be sure that is plugged in snuggly, If that all checks out Check inside the printer for damage which may have happened during the move, open all printer access doors and visually inspect all areas inside printer for signs of damage. If that all Looks Good Go Here to get support on this subject.
Thumbs Up if Helpful and Feedback is Appreciated!!!
Jun 19, 2011 | HP LaserJet 3050 All-In-One Printer
Printouts outs coming blank in my hp 2300 laserjet printer
Replace the toner cartridge.
If that doesn't FixYa then chances are the high voltage board is defective or it's fuse is blown.
Check and/or replace the HV board.
Mar 03, 2011 | HP LaserJet 2300 Printer
Will not turn on even tho plugged in
Try a different power cord or test the power cord on a different piece of equipment.
If it still does not work then the printer has a power supply problem and needs to be repaired or scrapped. A new printer may be a better cost effective solution.
Unless you have electrical knowledge I suggest you do not try to fix mains powered equipment. Mains voltage is dangerous.
Mar 06, 2010 | HP LaserJet 2605dn Printer
Power supply hp 1020 lasserjet printer
You would need to order:
Engine power supply 220V to 240V (HP LJ 1020 printer) RM1-2316-000CN
You can call HP Support and order for the above RM... part number.
- Nikhil
Nov 12, 2008 | HP LaserJet 1020 Printer
Hp lj 2300d
You either have a bad toner cartridge or a failed scanner assembly. Here's a free copy of the HP 2300 Service Manual to help you isolate it down. Check the troubleshooting section and it will give you a number of checks. The manual may mention a High Voltage Power Supply (HVPS) section on the DC Controller board but that would be highly unlikely. We have been servicing these since they were introduced and have never installed a DC Controller.
Here's the link:
http://www.feedroller.com/Store/Service%20Manual/LASERJET%202300%20Service%20Manual.pdf
Hope that helps you. :)
Jul 17, 2008 | HP LaserJet 2300 Printer
HP Laserjet 2300: Prints only one copy
can you print the configuration page or selftest?
Jul 11, 2008 | HP LaserJet 2300 Printer
144 people viewed this question
Seeker5211
Seeker5211
