Question about ASUS Mypal A730W Windows Mobile 2003
How download a gps catcher manually
When i try to launch a gps catcher i will get a message to install it manually.how to install it manually i have tried as per the user manual but i couldnt
HTC Tytn II - Win 6.1 GPS problem - No satelites
check in the tomtom settings which gps device you are using. i cant remember which typ mine used but you can check and try them all, also mine was on com4 but im not sure if this was standard. if you have the right settings, the with xda-developers.com for radio updates and driver updates. also update your quick gps
Nov 07, 2009 | HTC TyTN II Smartphone
Tip
The iTunes software update for iPod Touch
<p>ITunes is a media management program launched by Apple built to help manage content for all Apple iPod, personal media players, including iPod touch. You can use iTunes to load and delete songs, apps, podcasts and a variety of content on your device and back up your iPod touch. Before installing the software update on your iPod touch, you should update your iTunes software. Typically, iTunes prompts you to update the program when there are updates available, you can also manually check for updates in iTunes. <br /> <p><br /> <p>1. Launch iTunes. <br /> <p><br /> <p>2. Click "Help" from the toolbar menu at the top of the program window and click "Check for Updates". The program will prompt you with a new update, if available. <br /> <p><br /> <p>3. Click the "Download iTunes". Apple Launches Software Updater. <br /> <p><br /> <p>4. Click the box to the left of the "iTunes" and click "Install an item" button. <br /> <p><br /> <p>5. Click "OK" to confirm the terms of use agreement. <br /> <p><br /> <p>6. Apple Software Updater will automatically download and install the update from iTunes. The updater closes iTunes prompts you to restart your computer to complete the upgrade. <br />
on Aug 05, 2011 | Computers & Internet
Activate GPS on HTC TYTN11
HTC tytn II, att tilt,Kaiser ( all the same products) have internal GPS chip installed just near the camera , so you need not buy anything else. Just get google maps app, a internet connection and try to find your self by using locate me feature on google map, the GPS chip will point you on map with very much accuracy.
Oct 06, 2008 | HTC TyTN Smartphone
Unable to install softwares on LG viewty
go to settings then USB connectivity, and instead of having data storage, change to mass storage - u can then drop on external memory card in a folder called other, all those jar games you have downloaded - then go to mystuff, and external memory, other, and the jars will be in there - launch them, and hey presto follow instructions and you will have some games!!!
Jun 02, 2008 | LG KU990 Viewty
PALM TREO 750-TOM TOM NAV 6
hi there
you will need to download the following updates first
http://www.palm.com/us/support/downloads/gps_nav.html
install the updates and you shouldn't have any problems after
hope this helps
Apr 14, 2008 | Palm Treo 750 Smartphone
Mobile XT not excepting my GPS Receiver
Garmin will work with ANY windows mobile device with built in GPS and or a bluetooth receiver. But you have to have the correct software there are 2 versions both will install but only one will work with your model phone for older model phones use version 4.10 or lower for newer model phones use version 5.0 or higher.
Let windows manage your GPS ports do not try to set it manually. If you have a GPS fix option...go out side where you can get a satellite fix easily...launch your GPS fix program...thenlaunch Garmin. It should connect and you will have to do this only once. I know from experience and I've use this on a T-Mobile Dash with a bluetooh adapter with no issues. I'd try a different receiver preferably any Pharos GPS receiver.
Dec 31, 2007 | Palm Treo 700w Smartphone
Missing COM port 1
It is not easy to give you a proper answer. The only thing that I can suggest you is to check TomTom support site. If you use some non Toshiba external device or software the best solution is to check support or FAQ page of device manufacturer.
Sep 08, 2005 | Toshiba e755 Pocket PC
Missing COM port 1
Sep 08, 2005 | Toshiba e750 Pocket PC
Missing COM port 1
Sep 07, 2005 | Toshiba e740 Pocket PC
ASUS Mypal A730W Windows Mobile 2003 Logo
759 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
