Question about Microsoft Metrologic MS9520 Voyager Barcode Scanner
MS9520 Voyager Barcode Scanner not scanning all codes
Dear Sir,
The model above initially sets to factory default. During scanning some of the barcodes it does not translated and missing in the ouput
Ex. barcode 02888224 (Marlboro Red made in Germany) = read as 288822 only
Please assist and provide me the solution to work this scanner in all barcodes.
Hoping for your response.
Respectfully Yours,
Ador R. Castro
4 Suggested Answers
bluegreenash
  • 661 Answers
SOURCE: My RS-232 scanner beeps at the bar code but nothing appears on-screen.
The "Beep" just means that the scanner has been presented with a valid barcode. (nothing more) The scanner has probably not been set up correctly as this is a common issue. the settings need to be set correctly for your environment. you should have a code book with some bar codes in (part of the manual) which can set all the options within the scanner, There is an option to recall defaults here is the electronic manual ftp://ftp.metrologic.com/pub/download/productmanuals/00-02544.pdf
Posted on Oct 04, 2007
penmobile
SOURCE: Metrologic barcode scanner - laser is a dot not a line
This would be a fault with the scan engine. The dot is created when the mirror inside of the scan engine is not oscillating. The best solution is to have the device repaired, hopefully your scanner is still under warranty, or to purchase a replacement. /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Posted on Mar 20, 2009
SOURCE: Microsoft Metrologic MS9520 Voyager Barcode Scanner problem
If it is using the MX009 USB Cable it wont scan with the standard configuration. You will need extra configs such as enable Rs-232 Mode, Enable Xon/Xoff handshaking etc..
These can be found on the www.Metrologic.com website which will divert you to Honeywell website
Posted on Jul 08, 2010
How i can configurate ms9520 by rs232 which command can i use
Scanners are programmed by printing the barcode & then scanning with them. For this one, go to https://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf
print it & scan the relevant barcode.
Dec 16, 2014 | Microsoft Metrologic MS9520 Voyager...
MS9520
Please Reset the Scanner. Manual has the Reset Bar Code
Feb 14, 2014 | Honeywell MS9520 Voyager Handheld Scanner...
Metrologic ms9520 not scanning UPC's
Hello.
The issue is likely due to the programming (or the lack of) of the scan gun. It is entirely possible that the UPC bar code is not configured in your gun as a valid bar code.
You can remedy this by programming the scan gun to recognize the UPC bar code (and any other bar codes you may need to scan). Use the link below to download the programming guides for this scan gun.
http://www.honeywellaidc.com/en-US/Pages/Product.aspx?category=hand-held-barcode-scanner&cat=HSM&pid=9520/40
Hope this helps!
Dec 01, 2011 | Metrologic Instruments Voyager MS9520...
I want scan barcode 39. Hou can i program mine ms9520 voyager scanner. Thank you
http://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf
That is a link to the PDF help file for the MS9520. It has barcodes inside that you scan with your scanner to enable/disable certain features. It looks like you should be able to enable Code 39 barcodes by scanning the barcode found on page 2-2 (actually on page 10).
May 26, 2011 | Honeywell MS9520
We are using a Metrologic MS9520 (keyboard wedge) with QuickBooks. It won't scan barcodes provided by Quickbooks, even though it's supposed to be compatible. We've downloaded about every driver, config,...
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
http://www.posguys.com/download/voyagerprogramming.pdf
Nov 11, 2010 | Microsoft Metrologic MS9520 Voyager...
May 25, 2010 | Microsoft Metrologic MS9520 Voyager...
I have not instruction for default settig where are barcode for default setting
Check metroselect single line configuration guide page no. 2
1) Scan Enter/Exit configuration mode it gives 3 beeps
2)Scan recall defaults it gives single beep
3)Scan Enter /exit configuration mode it gives 3 beeps
Now scanner is set to default setting
Sep 16, 2009 | Microsoft Metrologic MS9520 Voyager...
Incorrect Reading
Try experimenting with the different inter-scan code delays. You can find the programming barcodes in your manual.
Aug 20, 2008 | Metrologic Instruments Voyager MS9520...
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
Microsoft Metrologic MS9520 Voyager Barcode Scanner Logo
429 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
