Question about LG WM-2277HW Front Load Washer
Vibration problem with LG front load washer WM0532HW
I have tried adjusting the feet and it will still vibrate with medium sized load like 2-3jeans and a bath towel. the washer sits on tiled floor on a concrete foundation.
  • Anonymous Jan 20, 2009
    I have the same problem and mine makes all my clothes smell like metal.
  • Anonymous Jan 21, 2009
    RE: vibration problem
    We just bought some anti-vibration pads to put under the legs. It has cut the vibration down quite a bit. Go to gviinc.net - they have them for about $40. Don't buy the ones at Lowe's - they don't work!!
SOURCE: lg wm0532hw front load washer
LG wm0532hw, can not turn on washer, it's not the plug, i try to reset it by unplug for 2min then plug it back. help
Posted on Jan 08, 2008
Coldcut
  • 1554 Answers
SOURCE: Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Posted on Mar 04, 2008
SOURCE: LG washer vibration
My wife and I originally had the same problem, and it didn't help that the washroom was a slick tile floor. First add as much weight as possible to your pedestal. We have ours full of detergents, bleach, fabric softener, etc., and have several of each so that the pedestal is completely full. When mounted on the pedestal, the washer is quite top-heavy, and the added weight in the bottom helped immensely. Second, make sure your washer is level, both the feet resting on the pedestal and the feet of the pedestal itself, and tighten the secondary rings so the feet don't vibrate out of place. Last, I purchased some thin rubber padding (approximately the thickness of leather) from Home Depot in the carpet aisle. Cut some small squares and place one under each foot of the pedestal. This gives the feet some additional "grabbing power" on slick floors.
Posted on Feb 16, 2009
SOURCE: Whirlpool Duet GHW9300PW4 vibration problem.
If you dryer moves away from the washer when the washer is shaking then it's still your floor sorry. The duets are not really known to have bad vibration and shaking problems. If you think the floor is ok then check to see if your inner tub basket can wiggle up or down their should be no play in the basket, you could have a bad tub bearing, make sure your drain pump is pumping out the water fast enough. hope this helps.
Posted on Apr 07, 2009
maintenacemi
  • 95 Answers
SOURCE: LG WM0642H front load washer making a loud vibration-type noise
mc not level
Posted on Nov 18, 2009
Vibrates when it spins
Here are a few quick facts on washing machine vibration.
  1. All washing machines and dryer vibrate. Dryers usually have less vibration than washers because the load is only wet clothes (as opposed to a drum of water and clothes). Front loading washing machines cause high frequency vertical oscillation while top loading washers usually have horizontal oscillation.
  2. Almost all front loading washing machines are not recommended for use on standard joist-construction floors (most common floor type, compared to a concrete slab sub-floor). Manufactures like GE, LG, Maytag, Samsung, Whirlpool, Kenmore, Bosch and more, all recommend installing a pad like Silent Feet under the washing machine to absorb the vibration.
  3. The only alternative to using Silent Feet pads to prevent structural damage is costly upgrading of the sub-floor. This usually involves adding a second layer of plywood sub-floor and adding sister boards to the rafters that support the floor. But even this won't reduce the amount of vibration noise that you hear. Sub-floor upgrades can cost thousands of dollars.
  4. Vibration can also cause appliance "walking" (unwanted movement) usually during the spin cycle. Simply installing a pad designed to prevent walking can solve this problem and mean that you'll never have to reposition your washer after every load again. Both Original Silent Feet and Anti-Walk Silent Feet prevent walking, however for washers that move a lot or stacked units it is recommended that you install Anti-Walk Silent Feet for the best results.
You were not specific in either type or model. I hope the above information helps. Also, the size of the loads plays a great part in how a machine functions. have a nice day
You wer
Dec 16, 2013 | Kenmore Washing Machines
Excessive shaking and vibration when wash cycle is running
Hello, Well if the machine is vibrating it is most likely because the feet on the bottom of the washer are not locked and are screwing themselves back up into the machine. If you have someone help you can slightly tip the washer up and adjust these feet by simply turning them to adjust them down or up. This can take a few adjustments to get the machine level. take a carpenters level and set it on the washer first from the front to back on one side of the washer and adjust the feet so it is level front to back. Then take the level and set it over the control panel to level it side to side(it will take a few times to get them all even and level). when the machine is level you will have to lock the feet by turning the nut that is on the leg up to the bottom of the washer and tighten them down to lock the legs so that they do not work themselves loose again. That should stop the vibration. Good luck and I hope that solves it!
Dec 09, 2010 | Kenmore 43142 Front Load Washer
My GE front loading washer model # WBVH6240HWW just recently started having vibration problems while in the spin cycle. Its vibrating badly and its very loud. What is causing it.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 07, 2010 | General Electric WBVH6240HWW Front Load...
Makes a loud noise in spin
heatman101
Sep 22, 2010 | GE Energy Star WCVH6260F Front Load Washer
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Apr 08, 2010 | LG WM0642H Front Load
Bad vibrations!might be unlevel?
First, check that the shipping bolts were removed to allow the washer drum suspension to fully dampen. If vibration continues, check that washer is not loaded beyond recommended capacity. Finally, install a vibration absorbing pad or mat. I've had the best results from Silent Feet vibration pads from a company called The Vibration Solution. As far as I can tell they are only sold online. Check Amazon.com for the best prices on Silent Feet anti-vibration pads.
Mar 07, 2010 | Frigidaire ATF6000ES Front Load Washer
How to keep the floor from vibrating while in spin cycle
Most likely cause of vibration is that the washer isn't leveled. Use a torpedo or carpenters level and adjust the support feet on the washer to get it level. If it still makes the floor vibrate, you may have a soft floor. You could then try putting a piece of 3/4 plywood under the washer to help support the weight.
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LG WM0532HM is level but make my house vibrate Can anyone help?
Put 5 or 6 bath towels on a quick wash cycle.
During the spin cycle adjust the feet on the washer to smooth out the vibrations. Some times you only have to adjust one foot on the front to make a big difference.
If you have a pedastal snug up the washer feet to the pedastal then proceed above.
The washer came with a flat silver wrench to adjust the feet.
Jan 16, 2010 | LG WM-0532HW Front Load Washer
HAVE A LG TROMM FRONT LOADING WASHING MACHINE THAT SHAKES WHEN SI
has one of the shocks come loose or broken. Open the back of the machine (power-off of course) and on either side of the drum there is a shock absorber. A visual check should tell you if there is a problem.
Apr 15, 2009 | LG WM-2277HW Front Load Washer
Bad vibrations/shaking with LG washing machine WM2032HW
What's the exact model of your washing machine? I'll need this to get you exact part numbers.
If you're looking for a quick and cheap fix that works. Try installing a rubber anti-vibration pad under the washer. I've had the best luck with a pad called Silent Feet. They are pretty hard to find in stores but Amazon.com carries the full line of Silent Feet anti-vibration pads. They will provide you with the best results short of replacing the full shock isolation assembly in the washer. And they cost a lot less.
Mar 03, 2009 | LG WM-2032H Front Load Washer
LG WM-2277HW Front Load Washer Logo
543 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
