Question about Microsoft Xbox 360 Controller
Xbox 360 'A' button not pressing correctly
The 'A' button often gets stuck and interferes with game play alot
  • Anonymous May 03, 2009
    i have a similar problem, my "a" button isn't going down all the way and isn't coming up like it's hard to push down
  • 23 Answers
Open up you controller by removing the screws in the back (there's one behind a sticker) and clean up the buttons.
Posted on Apr 27, 2009
My xbox 360 controller was working find when i started to play today, i was playing then all of a sudden when i went to press Left Bumper LB it wouldnt function, its not stuck and it still clicks.. i...
1-try rettting the game's control layout back to default...you might have changed the layout 2-is this problem happening in other games as well? if it does, then we can consider taking the controller for repair 3-there is always ebay and amazon to get you a new controller 4-do you have a wireless or usb adapter to connect the xbox controller to the pc? in windows 7 you can use the gamepad as a gamepad and in "callibration settings" you can test the buttons
go get those killstreaks!
Feb 18, 2011 | Microsoft Xbox 360 Controller
X box controller keeps turning itself off - I have put new batteries in
Connection problems might be caused by one or more of the following factors:
  • Weak batteries or a weak Xbox 360 Rechargeable Battery Pack
  • Interference from another wireless device, such as a microwave oven, a cordless phone, or a wireless router
  • Metallic objects positioned between the console and the wireless controller, such as a chrome faceplate or metal dividers, shelves, or doors on an entertainment center cabinet
    Note All licensed Xbox 360 console faceplates are tested for interference, and do not interfere with licensed wireless devices.
  • There are already four controllers connected to the console.
uparrow.gifBack to the top THINGS TO TRY Solution 1: Restart your console Turn your console off, wait a minute, and then... Solution 1: Restart your consoleTurn your console off, wait a minute, and then turn it on again.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 2: Replace the batteries or the Rechargeable Battery PackInsert fresh AA batteries, or attach a fully charged Xbox 360 Rechargeable Battery Pack to your controller. If you have an Xbox 360 Rechargeable Battery Pack
  • Remove the battery pack and reattach it to your controller, making sure that it is attached correctly.
  • Press and hold the Xbox Guide button. In the upper-left area of the Xbox Guide button, the battery meter indicates your current level of battery strength. You might need to recharge the battery pack, if the level is low.
If you have an Xbox 360 Play & Charge kit
  • Make sure that the Xbox 360 Rechargeable Battery Pack is correctly connected to your controller and plugged into one of your console's USB ports. If you check both of those things but are still having the problem, try the suggestion below.
  • Plug the charge cable into each USB port on your console, one by one. There are two USB ports on the front of the console and one on the back. If the controller works in one USB port but not another, try another accessory in the USB port that did not work with the controller. If the USB port does not work with any accessory, your Xbox 360 console might need to be repaired.
  • Turn off vibration feedback (rumbling) on the controller. If you play games with feedback while charging, it takes longer for the controller to charge and might drain the battery pack faster than it can recharge. Here's how to turn vibration off.
    1. Press the Xbox Guide button on the controller.
    2. Go to the Settings area, and then select Preferences.
    3. Select Vibration.
    4. Select Enable Vibration to clear the checkbox.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 3: Remove objects between the controller and the consoleThe controller works within 33 feet (10 meters) of your console. However, objects placed between the controller and the console might reduce this range. In addition, objects that use wireless technology (for example, a cordless phone) can interfere with your wireless controller. Remove or relocate objects or wireless devices that might interfere with the wireless controller or console. Here are some things that can cause problems:
  • Microwave ovens
  • Cordless phones
  • Wireless routers
  • Chrome faceplates
  • Metal dividers
  • Shelves
  • Doors on an entertainment center cabinet
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 4: Disconnect all controllers and headsetsIf all four rings surrounding the power button on the console are green but the controller has four flashing green lights, four controllers might already be connected to the console. Disconnect all of the controllers, and then try to connect the controller with the problem.
  • To disconnect a wireless controller, press and hold the Xbox Guide button for three seconds, and then turn the controller off.
  • To disconnect a wireless headset, turn the headset off.
  • To disconnect a wired controller or headset, unplug its cable from the console.
To learn more about connecting your wireless controller, please read the following Knowledge Base article: 906947 (http://support.microsoft.com/kb/906947/ ) How to connect an Xbox 360 Wireless Controller to an Xbox 360 console or computer If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 5: Replace your controllerIf your controller still does not work correctly, it might need to be replaced. Please contact Xbox support at the following address: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) uparrow.gifBack to the top Additional supportPlease visit the following Web site for information about how to contact Xbox support: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Dec 05, 2010 | Microsoft Xbox 360 Controller
Xbox 360 wireless controller left analog stick problem
Thats how modern warfare is made, I also had the same problem. Try keeping it pressed for longer instead of letting go early.
Mar 13, 2010 | Microsoft Xbox 360 Controller
My xbox 360 controller keep on running eve tho i don,t press the run buton
The button can get stuck sometime, even if it doesnt look like it. That is y it keeps running. Under the button is another button that it hit s when you push it. You may have to open controller and play around with button a little bit. If controller is still under warranty get it replace by microsoft.
Aug 16, 2009 | Microsoft Xbox 360 Controller
I can't update my rosters or play online in NHL 09 on xbox 360
I know the xbox screws up alot with Nhl, best thing to do is delete any Unused Dynasty profiles, As they sometimes interfere with the Loading of the other rosters :)
Feb 20, 2009 | Buck NHL 09 for Xbox 360
USB guitar for 360 won't play correct notes
try the slots in the front, i never use the one on the back of the system to play games,
my rockband guitar works find in gh3
Dec 02, 2008 | Activision Guitar Hero III: Legends of...
Xbox 360
If your xbox is stuck in standby, you've got some issue. Unless you pressed the "standby" button on your router while playing Halo 3 at a weak attempt to try and cheat other players, and then your xbox 360 became stuck in "standby"mode, I have no idea what you are talking about. Elaborate. And if this occurred after prressing standby while playing Halo 3, you probably deserve having a broken xbox 360 since you were probably trying to cheat against me! As for the guy who's life revolves around Call of Duty, you have to stop playing sometime. Either when the console actually breaks from all the cheezy poofs and mountain dew you place on it or M$ poorly designs the xbox 360's to do this intentionally.
Apr 26, 2008 | Microsoft Xbox 360 Console
My xbox 360 doesn't want to play any 360 games but it plays xbox games.
is this limited addition halo 3?
get a new one or find a place where you can get it fixed but there are not alot of places to get it fixed.im sorry im the barer of bad news.
Dec 04, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Controller Logo
292 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
