Question about Radio Shack Pro-97 Handheld Scanner
Cant change the greeting on a pro97
When you turn on the scanner it says radio shack multi-system
  • 211 Answers
The greeting can be changed using the USB programming cable and a software package such as Win97 from StarrSoft. (www.starrsoft.com) This is not freeware, but they do allow a 30 day fully functional trial. The greeting cannot be changed from the keyboard.
Posted on May 28, 2009
Clear a radio shack triple trunking scannrt
If the scanner's display locks up or does not work properly
after you connect a power source or install batteries, you
might need to initialize it.
This procedure clears all information you stored in the
scanner's memory. Initialize the scanner only when you
are sure the scanner is not working properly.
1. Turn off the scanner, then turn it on again. Multi-system
Trunking Scanner appears.
2. Press 0 while Multi-system Trunking Scanner appears.
3. Press 1.
4. Press ENT. Initializing please stand by. appears for about 5
seconds.
Do not turn off the scanner until the initalization is
complete. When the initialization is complete, M000
appears on the top line of the display. Bank 0 Ch 00
appears on the third line.
Notes
Notes
Mar 20, 2013 | Uniden Radio Communications
Radio shack pro-96 scanner screen blinks and loss of audio
3. Press 1.
seconds.
Notes
Notes
Jan 10, 2013 | Radio Shack Pro-96 Scanner
How to unlock my channels on my pro97 scanner
Hi.my name is John. Welcome to FixYa. Press SRCH, press FUNC, then L/OUT, press FUNC then number 6 press number 1 to clear all. Thanks for choosing FixYa....John
Dec 01, 2010 | Radio Shack Pro-97 Handheld Scanner
I have a pro 97 hand held cant get it out of clone mode
Your scanner is designed to automatically enter CLONE mode when a cloning cable is attached, and to exit CLONE mode when the cable is disconnected. If you do not currently have a cable connected, you will need to INITIALIZE your scanner to return it to normal operation. NOTE: Initializing the scanner will erase/delete all programmed data and return the scanner to its original factory settings. Before starting this procedure, be sure that you have a record of all programming information so that you can reprogram your scanner.
To INITIALIZE the PRO-97:
1. Turn the scanner OFF.
2. Turn the scanner ON. "Multi-system Trunking Scanner" appears.
3. Press the 0 (zero) key while "Multi-system Trunking Scanner" appears.
4. Press the 1 (one) key.
5. Press the ENT key. "Initializing please stand by" appears on the display for about five seconds.
Do not turn the scanner OFF until the initialization process is complete. When it is complete "M000" will appear on the top line of the display, and "Bank 0 Ch 00" will appear on the third line of the display.
Once the process is complete you can begin to reprogram the scanner.
Bill B
Listening in since the 60's
Oct 06, 2010 | Radio Shack Pro-97 Handheld Scanner
All channels locked out
how do i unlock my scanner pro97 ?
Jul 01, 2010 | Radio Shack Pro-97 Handheld Scanner
I have a a hand held radio shack triple trunking pro-164.someone thought they knew how to program it , and know it is worse than before. is there a way to clear it out and start fresh?
Radio Shack calls it "Initializing," but to totally reset the scanner to factory settings,
“Multi-system Trunking Scanner”
appears.
2. While “Multi-system Trunking
Scanner” appears, press 0.
3. Press 1.
4. Press ENT. “Initializing please
stand by” appears for about 5 seconds.
appears on the second line of the display.
“Bank 0 Ch 00” appears.
Note: Do not turn off the scanner until
the initialization is complete.
Need the manual for your scanner? You can download/print it here:
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000164_PM_EN.pdf
BillB
Jan 19, 2010 | Radio Communications
Radio Shack Pro 97 Programing Problem
clearing all locked-out frequencies in a search bank
1. Press SRCH.
2. Select the search bank in which you want to clear all
locked-out frequencies.
3. Press FUNC then press L/OUT. Lockout list appears.
4. Press FUNC then 6. Clear entire list ? Press 1 to clear all, any other key aborts appears. Press 1 to clear all locked-out
frequencies. List cleared. appears for about 2 seconds.
Press any key other than 1 to cancel clear.
Let me know how this goes and if you need any further help.
thanks
May 04, 2008 | Radio Shack Pro-97 Handheld Scanner
Radio shack pro97
I have the same issue, was working fine, then the scan works but never stops on any freq. nor does the squelch make any sounds. The only sound is the key tones, I have reset the unit and tried new batteries and a different antena. still nothing? any ideas?
Feb 24, 2008 | Radio Shack Pro-97 Handheld Scanner
PROGRAMMING SCANNER
it depends on what country you live in mick
Dec 27, 2007 | Radio Shack Pro-97 Handheld Scanner
Radio shack hand held scanner Cat. no. 20-315
L live in Haywood county NC and I am running the following Radioshack scanners: Pro82, Pro95 and a Pro97. When will the rebanding take these scanners down. Also will the Pro97 beable to be rebanded as it really is a good scanner.
Nov 10, 2007 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-97 Handheld Scanner Logo
131 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
