Question about Philips Magnavox 9P6034C 60" Rear Projection Television
My tv seems to have more red and blue colors in it
The picture is horrible.can hardly see picture in daytime try ajusting the color doesn't help.someone the crt might need drain and replace.how much and where do I go to get it.
  • vexed Nov 07, 2007
    I have a similar problem, if not the same. Except my TV is older. It definately needs the cooling liquid replaced, bacause there are a lot of particles. But what is the liquid called? and where can I get it? can I just use mineral oil?
  • Anonymous Nov 27, 2007
    I have the same problem hard to see picture to much red in the picture making it very dark. Please let me know what to do. Should I buy a new TV. I tried to the color and it doesn't work.
    Genius:
  • 1,153 Answers
You can also check to see if you have bad fluid problems, by looking down in your crt's with a flashlight when you unplug your set and see if you can notice any particles that should not be there. Look at all three and see if there is a difference. It should be clear, if not then you need to change fluid and clean.
Posted on Aug 09, 2007
    Problem Solver:
  • 15 Answers
It sounds as if one of the picture elements (there are probably 3 for R-red G-green B-blue) has gone bad and it is most likely the green one. Sad to say it will probably cost you more to have it fixed than it would to buy a new TV. Most places will not even look at a TV for less than $85 or so, then they will add parts and labor... if they can even find parts.
Posted on Jun 19, 2007
We have a JVC LT-32JM30 and recently for no reason at all, the picture color has messed up, we have tried resetting and adjusting the tinit, etc but nothing works. Everything is a varying shade of green or...
an internal degaussing coil circuit is already installed in the unit to neutralized color pattern...a loose solder connection may have caused this because as it operates temperature increases between the thermistor..
Jul 15, 2011 | JVC AV-27530 27" TV
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
Dec 29, 2009 | Hitachi Televison & Video
I can't seem to correct a tint problem. The tv turns on and the tint doesn't change. A friend says it could be a vidoe card?
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
Nov 08, 2009 | Akai PDP4225M 42 in. Plasma Television
The dark color of my tv was change unspected the dark color now are blue, violet,and other exept black, the dark scense can't see. please help me.
I believe you either have a bad LCD Controller Board or a bad Main Board. The only way to know is to replace one. If it doesn't fix it , replace the other. Or replace both and it should be fixed.
I hope this helps,
Skyassoc
Nov 03, 2009 | Sharp LC-42D43U 42 in. LCD HDTV
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Color looks horrible when playing dvds. when watching tv, the color is fine. help!
U have to use a hdmi cable ok or red green blue coumpount cable ok that way get a better picture thx for using fix ya .
Feb 05, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hitachi Ultravision50vf820
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 22, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 52 projection tv
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
