Question about Motorola Mobility MOTOROKR S9 Wireless Headset for Bluetooth-Enabled Cell Phones - Black/Red
Motorokr S 9 wireless headset automatically switches off
Streaming music from Nokia 6500 Classic. Both phone and headset batteries fully charged. Headset automatically switches off after approximately 10 minutes. Read form Motorola site that this happens only after 1 hour of inactivity. Has it got anything to do with the set up or setting? Thanks.
Replacement from the same batch had the same problem. Sales person then found me one from an earlier batch - no problem with this one. Still don't know what is wrong.
Posted on Jan 17, 2009
Could my battery be the problem why my nokia 6500 classic phone wont turn on aftre replacing the screen
then check it with some other battery which is fuly charged and worked in some other mobiles?
Jun 17, 2011 | Nokia 6500 Classic Cellular Phone
On my motorokr s9 the green light just stay on even when I don't charge it is there a reset button or anything?
This is caused by a power surge. To correct, plug your headset into charge, and then plug into power strip. Trip the switch on the power strip to off. It will cause a drain and turn off your green light and then allow the headset to turn back on.
May 06, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
I get the bluetooth symbol on the Nokia E63 handset but unable to receive calls.
are you using a bluetooth headset? if yes then check whether u have switched on your bluetooth headset & also your phone & bluetooth headset must be reachable, that is, both should be within range as mentioned in your bluetooth headset manual.
Oct 28, 2009 | Nokia E63 Cell Phone
Nokia 6500 classic got wet now dead even after
try a new battery, you may have shorted out old one, if this doesnt work then you shorted out phone, needs to be repaired by a phone tech.
Aug 18, 2009 | Nokia 6500 Classic Cellular Phone
Wireless gear bluethooth to a nokia 6650
switch on the bluetooth on both the devices..and then search for the device in your phone.if it is visible you have to enter a passkey initially and then you will be able to connect it. this is one way, and put on the music player in the phone, switch the option in the settings to hear through wireless bluetooth.if it does not work, then try the bluetooth with a motorola phone.if it works with the motorola phone alone then it might have compatibility problems with nokia. generally motorazr is best suited for the bluetooth u have
Jul 08, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Not switching on
hell there,
make sure that your phone battery was fully charge,
check if your have a failing battery pack on your unit.
better try to use or change another battery pack.
just let me know, for any further instructions.
Apr 29, 2009 | Nokia 6500 Slide Cellular Phone
I cant turn on my nokia 6500 classic
Hey there!! please try to remove the battery and try to turn it on again...
Feb 14, 2009 | Nokia 6500 Classic Cellular Phone
Nokia 6500 classic
It depends on the originality of the battery and period it has been used.if its the original then probably you will have to change the battery.
Jan 02, 2009 | Nokia 6500 Slide Cellular Phone
Nokia 6500 will not pair with Parrot ck3100
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Parrot device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
Dec 28, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
After pairing with my mobile (Nokia N73) I am able the listen to music only for 10 sec
Try pairing your device to another mobile and try listening music with it.If it works, either the settings on you Nokia N73 need to be changed, either is not fully compatible with the phone.As a last resort you can reset to default the settings on your mobile.Upgrading the firmware I do not recommand doing it, even from an official site, cause it can turn be very unstable.
Sep 02, 2008 | Jabra BT8010 Wireless Headset
Motorola Mobility MOTOROKR S9 Wireless Headset for Bluetooth-Enabled Cell Phones - Black/Red Logo
121 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
