Question about HP LaserJet 1160 Printer
Fatal error light pattern pls help with the hp laserjet 1160
The problem is the Attention, Ready, and GO LEDs are on solid. i already try to solve this problem with the hp support but it still doesn't work. pls help. thanks
3 Suggested Answers
sunnylab85
  • 302 Answers
SOURCE: Problem for HP LaserJet 1160 Printer Fatal
Check if paper is in the printer because that may cause the print to show that light or maybe the hardware part are not properly fit to the printer
Posted on Oct 24, 2009
  • 313 Answers
SOURCE: switch on the hp laserjet 1160, The Attention,
you may have a fetal error, press the button to see the secondary error code
Posted on Apr 06, 2010
Printing is always blair and i cant view what is printer
Here is a full story
HP LaserJet Professional M1130/M1210 MFP - Interpret control-panel light patterns (M1130 Series only) Interpret control-panel light patterns (M1130 Series only) If the product requires attention, an error code appears on the control-panel display. Status-light legend c01993382.gif Symbol for "light off" c01993383.gif Symbol for "light on" c01993381.gif Symbol for "light blinking" Control-panel light patterns Light status Error code State of the product Action All lights are off.
c01993373.gif The product is turned off. Press the power button to turn on the product. Ready and attention lights blink.
c01993380.gif The status lights cycle during the formatter initialization period or when the product is processing a cleaning page. No action is required. Wait for the initialization period to end. The product should enter the ready state when the initialization period is finished. Ready light is on.
c01993421.gif The product is in the ready state. No action is required. The product is ready to receive a print job. Ready light is blinking.
c01993420.gif The product is receiving or processing data. No action is required. The product is receiving or processing a print job. Ready light is blinking slowly.
c01993420.gif The product is in low power mode. No action is required. Attention light is blinking.
c01993418.gif E0 Paper is jammed in the product. Clear the jam. E1 The input tray is empty. Load the tray. E2 A door is open Verify that the print-cartridge door is fully closed. E4 The product memory is full The job is too complex for the product to print. Simplify the job, or divide it into multiple files. E5 The product did not pick up paper from the tray. You might need to clean or replace the pickup roller. H0 The product is in manual-feed mode. Load the correct paper type and size into the input tray. H1 The product is processing a manual duplex job. Load the pages into the input tray to print the second sides. The attention and toner lights are blinking.
c01993375.gif E3 The print cartridge is missing or is not installed correctly. Install the print cartridge. The toner light is on.
c01993429.gif The print cartridge has reached the end of its estimated useful life. When the supply has reached this condition, the HP Premium Protection warranty for that supply has ended. You do not need to replace the print cartridge at this time unless print quality is no longer acceptable. Attention light is blinking, and ready light is on.
c01993379.gif The product has experienced a continual error from which it will recover on its own. If the recovery is successful, the product continues to the processing data state and completes the job.
If the recovery is unsuccessful, the product continues to the continuable error state. Try removing any media from the media path and turning the product power off, and then on again. The attention and ready lights are on.
c01993388.gif E6
E7
E8
E9 The product has experienced a fatal error from which it cannot recover.
  1. Turn off the product or disconnect the power cord from the product.
  2. Wait 30 seconds, and then turn on the product or reconnect the power cord to the product.
  3. Wait for the product to initialize.
If the error persists, contact HP customer support
Mar 01, 2013 | HP LASERJET PRO M1132 MFP
HP2550 problem:The attention light, the ready light and the go light stay on (not flashing). When I hold the Go and Cancel button down, the attention light and the ready light stay on (secondary light...
According to your "secondary" light pattern your printer has a Carousel motor error.
You've already power cycled it to no avail.
The next step is to get the motor replaced.
Sorry, I know that you didn't want to hear that.
Apr 06, 2011 | HP LaserJet 2550L Printer
I have hp laserjet 1160 error orange light error
Hi
Your printer has a problem
and you can see what in your pc
perhaps your cartridge is empty
In case I had help you pls vote me
Nov 04, 2010 | HP LaserJet 1160 Printer
Switch on the hp laserjet 1160, The Attention, Ready, and GO LEDs are on solid.
Apr 06, 2010 | HP LaserJet 1160 Printer
Here is service manual for HP 1160/1320 series ->http://filecom.net/CXW_R.
Solution is on page 34. I hope it will help you.
Feb 27, 2010 | HP LaserJet 1320 Printer
Problem for HP LaserJet 1160 Printer Fatal error light pattern pls help with the hp laserjet 1160
Oct 24, 2009 | HP LaserJet 1160 Printer
Fetal error on HP laser jet 1160
Hi naseeh83: Here your problem. Fuser error. The fuser has a malfunction. Try these steps. 1. Unplug the printer for at least ten minutes. 2. Verify that the fuser connector and thermistor connector are both firmly seated in the ECU 3. Perform a heating element resistance check. 4. If the resistance readings are correct, but the error persists, replace the fuser. You may have to call a certified HP technician to repair this printer. Hope this helps.
Jun 10, 2009 | HP LaserJet 1160 Printer
Printer error
If all the three lights are on, then the issue is with the board (formatter board to be precise). Press the green button to check if there is a difference in the light pattern, the first light pattern is called primary light and after pressing the green button, the format changes to secondary light pattern, please find below the link to check the different light pattern for primary and secondary light pattern.
HP LaserJet 1160 and 1320 Series Printers - Printer Light Patterns (Error Messages) http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00230632&prodTypeId=18972&prodSeriesId=410622
Rgds,
Nikhil
May 16, 2009 | HP LaserJet 1320n Printer
HP Laserjet 1320n Error Lights not in Manual
hi friends......
shivachadra is here.....just i faced this problem "Attention, Ready, and GO LEDs are on solid"
and i got solution in troubleshooting....just vi refixe the connetion of laser scanner........its the error of comunication between laser scanner and formatter....
May 27, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1160 Printer Logo
309 people viewed this question
Ben Johnson
