Question about Westinghouse Dishwashers
3 loose plastic rings found in primary filter The 3 identical rings are of pliable plastic and are 30mm in dia and 4mm width. The cross section of the outer ring is 'V' shaped. I cannot see where these belong. Are they part of the dishwasher? Thanks Richard
    Scholar:
  • 140 Answers
What you are describing is known as an 'olive' the sealing part of a water union known as a kinko and olive, i would nt worry to much they have been caught by the filter and it is just doing its job ....unless of course there is a leek then you will need to find the unions they came from
Posted on Jan 16, 2009
Hr 3000
Frequently the problem for this is a plastic ring that has three pins in it. Normally the pins break through the bottom of the ring.
You need to take covers off. Strip SDS chuck. Remove plastic cap from end of drill then remove large internal retaining ring. Tap end of drill with mallet and eventually the tool holder will come out.
At the bottom of the tool holder there is a thin O ring (all this does is keeps a plastic gear and springs on the tool holder.) Remove this ring gear and springs can now be removed. You should now see the plastic ring (approx. 30mm long) Examine ring and pins, probably need to replace ring. This is usually the cause of not hammering, I have found changing seals works for weak hammering. Although having stripped the drill to this point I normally change the O rings on the hammer and piston. Rebuild is reverse of stripping be careful with the thin O ring not to snap it.
Mar 15, 2014 | Makita Drills
Lescha Hobby 125 S electric mixer requires new drum main bearing
I had a similar problem on a Lescha Hobby Mix 120 SF. (Sounds similar to yours) The failure seems to have been caused by corrosion of the ball bearings. If you get water into the rear bearing housing when it is operating, and then store the mixer with the opening in the drum downwards, the water collects around one of the bearings. The bearings are a standard size ball bearing with a 62mm outside dia, 30mm bore and 16mm wide. I bought the sealed version from a local bearing supplier (or look one up on the Internet). The original ones fitted are unsealed, which is part of the problem. I also bought two new bearing retaining external circlips for a 30mm shaft. I had a paint round inside the housing with hammerite, and drilled some 10mm dia drain holes around the outside of the housing near the bolting flange. I also store the mixer with the drum horizontal now.
May 27, 2011 | Gazillion Cement Mixer
I need to make an elevation adjustment; the cross-hair adjustment is not enough . Perhaps a more gross adjstment is possible where the ring mounts are located?
the easy way to get a little more ajustment of about 4-5 inches at 100 yds is to,,,cut up a 3 bit's of 35mm colour film to fit under the scope,,undo the rear scope top mount and lift the eye bell off its mount,,now slip the 3 bits of 35mm film under the scope body and reclamp the top mount cap,,,dont forse it up to tight ,,this will lift the point of aim
at least 4 or 5 inches at 100 yds
Aug 24, 2010 | Leupold 54120 2-7x33mm European 30mm Matte...
I have the 12'x30" Intex Easy Set pool, and there is water leaking from the bottom of the pump, Ive tried to figure out why but i cant find the problem...any suggestions?
YOU MIGHT CHECK THE GASKET INSIDE THE IMPELLR CASING AND MAKE SURE THE SCREWS THAT HOLD IT IN PLACE ARE TIGHT ALSO CHECK YOUR SEAL BETWEEN YOUR PUMP AND FILTER. THERE IS ALSO A LARRGE NUT UNDER THE FILTER HOUSING THAT COULD WORK LOOSE. I WOULD ALSO CHECK ALL O RINGS AND MAKE SURE THEY ARE PLIABLE AND IN GOOD SHAPE.
Jul 30, 2010 | Intex Easy Set Pool 15x36
Cub Cadet cc4125 - Worn out, excessive smoke with
It's not worth the expense and time, just purchase a new one.
Jul 04, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Gear needed
Call 1-800-524-0799 at Royal for parts assistance.
Jun 03, 2010 | Royal 15MX Shredder
I have an Ingersoll Rand compressor (RA5E6VA) 5 HP 60 gal vertical tank (only found 3 HP listing below, but it says 5 HP on it) There is a plastic tube between where the pump attaches to the tank (air in)...
that is just a compression fitting. Sometimes just replacing the tubing is enough to get a bit on it. If not you should be able to get another fitting from an indstrial supplier.
Mar 06, 2010 | Ingersoll Rand Single Stage Cast Iron 3 Hp...
When to replace brake pads 2007 xc70. They are at 3-4mm and the dealer syas then need to be replaced
2mm is the limit.........3-4mm is thin, . you dont want wear the pads to metal to metal unless the rotors will need to be replaced anyhow... minimun thickness for rotors is front 23.8mm and rears 10.7mm
Oct 16, 2009 | 2007 Volvo XC70 Cross Country
Rather severe oil leak from the area of the oil filter
I own a '99 Isuzu Oasis, which of course is really and '98 Odyssey with Isuzu nameplate. 214,000 miles, Cranked it up yesterday morning after 20 to 30 degree temps that night....took middle schooler to class approx 3-4 miles from home and approx 1/4 mile from home- noted severe burning oil smell in cabin and smoke from under hood.. Got it home and observed 3-4 quarts of leaked oil on the ground where I had been sitting just 15 mins before. Thought for sure I had ruined the engine after seeing all the oil in the gravel. Could not believe the leak was so severe, considering this car still runs like a beauty and has shown no leaking or other symptoms in the days before this occurred. Got home later that day and checked filter thinking maybe it had loosened. It had not. Refilled engine with oil and noted oil not leaking or dripping but pouring through area at engine block and oil cooler juncture at filter area. Found this forum and a few others on line and followed the plan , AutoZone: loan-a-tool 30mm 1/2" drive socket is all you need to do the job, except of course the oil cooler seal/O-ring which I got at Honda for 3 bucks. Took me all of 45 mins...no need to dettach hoses and leak antifreeze, just unscrew the 30mm nut and remove the old gasket/seal. Be sure to remove all the pieces, Mine was hard and brittle and broken in 3 pieces. What once was rubbery/pliable would now snap like a pretzel due to age/wear. When I buy my next one of these, and I will, because it is the best vehicle I have ever owned ( and I have owned several Hondas and Toyotas) I will preventative replace this seal at approx 150,000 miles.... this was close to being catastrophic failure- Thanks to this forum and others for the advice-plan to put another 100,000 miles on this baby!
Apr 04, 2009 | 1997 Honda Odyssey
Dishwashers Logo
85 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
