Question about HP 2133 Notebook PC
Adjust font size DPI to make default as 120 DPI
DPI Scaling Control Panel, is not going back to Larger scale (120 DPI to make it readable) after I have done the custom scale of 144 DPI
Go to settings and set the display settings .
Posted on Jan 16, 2009
What is dpi
DPI is "Dots per Inch"
Setting the DPI size to a smaller number or percentage will decrease all items size on the display, while setting the DPI size to a larger number or percentage will increase all items size on the display.
Typically, the higher the dots per inch (DPI), the better the fonts will look. If you set the DPI higher than 96, and you are running a Windows Aero theme, the text and other items on the screen might appear blurry in some programs that are not designed for high-DPI display in this version of Windows. You can avoid this issue by using legacy DPI scaling (Windows XP style DPI scaling) for these programs.
Oct 16, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Ledttering to small.dont know how to change to larger setting.
First, right click on your desktop and click on Personalize. Alternatively, you can go to Control Panel -> Appearance and Personalization -> Personalization. In the Personalization window, go to the left pane and click on Adjust font size (DPI). If UAC is turned on you will need to make an additional confirmation so that the DPI Scaling window will launch. You can choose the default scale of 96 DPI or a larger one of 120 DPI, which makes the text more readable. If these two options are not enough you can click on the Custom DPI button and choose another size (DPI)
I hope this has helped
Jul 30, 2011 | Computers & Internet
How do I make my text size larger?
This is for windows vista:
  1. Open Personalization by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
  2. In the left pane, click Adjust font size (DPI). 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. In the DPI Scaling dialog box, do one of the following:
    • To increase the size of text and other items on the screen, click Larger scale (120 DPI)-make text more readable, and then click OK.
    • To decrease the size of text and other items on the screen, click Default scale (96 DPI)-fit more information, and then click OK.
    To see the changes, close all of your programs, and then restart Windows.
Source
Jul 19, 2011 | Dell Inspiron 2200 Notebook
My font size is too small
There are a few different ways you may be able to increase font size. One is, if you have a "zoom" button on your keyboard with + and -, you may be able to use this by itself or by pressing "Ctrl" simultainiously with it. Another way is if you have a tool icon, upper right of your screen, may look like a gear, click on that and see if you have a zoom option there. You can also adjust you DPI, by clicking "start", lower left of screen, then on "control panel". In your list(icon), find and right click on "personalization". At the upper left of screen you will see "adjust DPI..". Click on that and you will see "larger DPI" amd a custom DPI tab. You can click on the box for larger DPI or can custom adjust your size by clicking the tab. Pick the size you want and click on apply, then restart system. Using the zoom you can adjust up or down at will, changing the DPI will increase size but, the only way to adjust will be to coinside with the zoom or by physically going back to personalization and changing it.
May 13, 2011 | Computers & Internet
How do I increase and set font size?
If UAC is turned on you will need to make an additional confirmation so that the DPI Scaling window will launch. You can choose the default scale of 96 DPI or a larger one of 120 DPI, which makes the text more readable. If these two options are not enough you can click on the Custom DPI button and choose another size (DPI).
In the Custom DPI Setting window you can select the desired percentage for the DPI increase. You have the following options: 100% for the normal size of 96 DPI, 125% for 120 DPI, 150% for 144 DPI and 200% for 192 DPI.
If you set the DPI higher than 96, and you are running Windows Aero, the text and other items on the screen might appear blurry in some programs that are not designed for high-DPI display in Windows Vistamag-glass_10x10.gif. You can avoid this issue by using Windows XP style DPI scaling. Just check the appropriate option and press on OK.
The change can be applied only after a system restart. Close all the running applications, save your open documents and then press on Restart Now. After a reboot, the font size will be changed.
Feb 06, 2011 | Dell XPS Laptop with Intel Core 2 Duo...
How do I make my font and text size bigger?
If you want to make font and text larger in a Word document, just look at the taskbar and click font pull-down window (usually the default is Times Roman) and pick whatever font you want, then click the pull-down window (usually the default is 12) and pick a larger size.
Or you need to make a display adjustment. Click Start, Click Control Panel, Click Personalization, click Display Settings, choose Resolution up or down which will adjust icon and font size on your computer.
Or click start, Control Panel, Personalization then:
  • In the left pane, click Adjust font size (DPI). If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  • In the DPI Scaling dialog box, do one of the following:
  • Jan 01, 2011 | Computers & Internet
    Screen to big !!! icons extra big and internet screen incompletes
    Hi Jessica, on your "Desktop screen," [right / alt click] to open the shortcut menu, next select one of the choices for the "icon size, ie: Medium or Large. In the same "Desktop" shortcut menu click on "Personalize," in the next window, left "Tasks" area, select and open the "Adjust font size (DPI), change the size in the [DPI Scaling] window, select the "Default scale size (96 DPI)," or you can use the {Custom DPI...} below to change the size, to your preferences. If the suggestions helped, show your appreciation for the services by giving a "Helpful Rating" thank you for using "Fix' Ya."
    Aug 07, 2010 | Computers & Internet
    How can I make all the letters on my computer larger so I don't have trouble reading them or playing games?
    Click START and go to the CONTRO PANEL
    Click on APPEARANCE & PERSONALIZATION
    You will be able to reset the screen size to your needs
    Jul 10, 2010 | Dell Computers & Internet
    Text size is too small on my toshiba laptop using windows vista home premium. Is there a good way to enlarge it?
    If you are referring to desktop font size, right click on an empty portion of your desktop, pick personalize on the context menu, and on the left side of the window, you should see "Adjust Font Size (DPI)". You can change the font size to larger scale (120 DPI) which should make the text larger. For web browsers, most should have an option to change the text size in the menu, but these steps would be different for the various web browsers available.
    Feb 28, 2010 | Computers & Internet
    Cannot read info withoug straining my eyes (even with glasses).
    To make the display better, we can increase the resolution and the font size of the computer.
    Here's how we do:
    1:Increase the resolution: Click on start and then on control panel .
    Apperance and Personalization and then Personalization .click on Display settings and now take the slider to right to adjust the resolution, you may set to high.
    2: Increase the font size: On Personalization click on Adjust font size (DPI) and then click on Larger scale (120 DPI)......click on Apply and OK
    Dec 27, 2009 | HP Tablets & eReaders
    HP 2133 Notebook PC Logo
    293 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
