Question about Rinnai Webstone The isolator EXP tankless water heater Service Valves WRIK
No water flow from hot water tap with a rinnai tankless water hea
We have a rinnai tankless water heater and it is very cold here tonight (4 degrees with windchill which is REALLY cold for GA) - and when we turn on the hot water tap - NOTHING comes out. :(
The cold water tap produces water with no problem - it is ONLY the hot water tap that is dry.
Does anyone have any ideas please?
Thanks!
  • 4 more comments
  • Anonymous Jan 17, 2009
    I have the same problem, I live in North Carolina and it got cold last night and now the hot water is not hot and it just trickles out of the sink and every other faucet in the house.
  • Anonymous Mar 03, 2009
    i have exterior rinnai water heater that is froze up whats the best way to thaw out
  • Lori degenaro
    Lori degenaro Jan 07, 2014
    I have the same problem in South Carolina ! Nothing happens when I turn on hot water, cold water side is fine , what do I do???
  • ohashas Jan 07, 2014
    I heated up the brass fittings in the hot water lines and relatively quickly, i had flow again.
    I had same problem in NC this morning. Went under house and used blow dryer on the brass connections and poof hot water again. Hope this helps.
  • Anonymous Mar 30, 2014
    Hot tap Flow restricted but flicking cold tap on and off solves problem
  • 716 Answers
Its A Possibility The Left Over Water In The Hot Is Frozen. If Your Line Is Exposed Outside Somewhere It Can Easily Freeze Up. Turn On The Hot Water Everywhere In The House And If Accessible Check The Lines To See Where The Warmth Ends. You Can Leave One Off Over Night In Hopes That It Will Eventually Defrost.
Posted on Jan 16, 2009
I also have a Rinnai and live in Michigan and have had it maintained, but I have no Water pressure from the faucet when another faucet is on they are telling me that is rated as the gas comes in the home at 5.8 on your utitlity company and the Hot water heater calls for7.0 it states it on the hwheater go figure.DRS
Posted on Jan 30, 2009
  • 25 Answers
Take the cover off the unit and use a hair dryer to slowly thaw the HE in the heater so it doesnt burst.
Posted on Jan 20, 2009
In temperature screen at 49 degrees to back to front t's appear and boiler stops
PDF]Operation and Installation Manual Outdoor Tankless Water ...
https://www.rinnai.us/.../U287-1932(00)_Outdoor_...
Rinnai America Corp.Temperature controlled continuous flow gas hot water system. .... This water heaterwill attempt to provide hot water at the temperature setting even when the ...
Hot water system temperatures and the code ' Plumbing ...
plumbingengineer.com/content/hot-water-system-temperatures-and-code
Feb 1, 2015 - There have also been incidents where the circulating pump stopped ...before it connects back to the cold water inlet to the water heater. .... Is there a maximum temperature limit for domestic water heaters? ... a means to limit the maximum setting at the valve to 120°F (49°C) or ... Some do and some don't.
[PDF]User's Operation Manual - contents - Navien
Dec 25, 2015 | Water Heaters
Rinnai RL94i - Produces hot water for 3 minutes, then stops
I just had this exact problem. It kept getting worse until we had no water. Our Rinnai tankless hot water heater started the same way though, with hot water for a few minutes and then would shut off with an error code 10. We just had to shut the hot water off and then back on, wait a minute or so and we had hot water back for a few minutes. Our unit would come on with a loud vibrating noise and remain until it shut off with an error code 10 (air flow fault). The solution was to remove the blower fan and blow out the squirrel cage. Ours had moths in it. We also vacuumed out the fan housing. Be careful to mark any wires you disconnect and take pictures before removal. Our unit is now almost silent when it comes on and supplies endless hot water.
Jun 10, 2014 | Rinnai RL94i Tankless Water Heater
Rheem rte13 standby (green) light not on
You might have crossover problem caused by bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
The green standby light should come on when 240Volt power is applied. Page 6 manual.
Both red lights should come on when tankless is activated. Page 6 manual
RTE 13 requires 60 amp breaker and 6 gauge wire
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
http://waterheatertimer.org/pdf/Rheem-TanklessElectricUC_AP15447.pdf
Factory temperature setting is usually default 120 degrees.
Adjust temps page 11 manual
Thermostat calibration is always approximate.
120 degrees is not hot enough to burn the skin.
Exceptionally cold incoming water temperature can cause tankless not to heat enough hot water: install tempering tank to preheat water to room temperature.
Tankless cannot be exposed to more than 11 grains hardness in water. Delime tankless yearly, clean water filter monthly, do not install low-flow restrictions or conserve water since the flow rate must remain high for tankless to activate.
Rheem does not post service manuals for their tankless water heaters.
Call Rheem 800 432-8373
Aug 05, 2012 | Rheem Tankless Hot Water Heater...
I have a Rinnai Continuum Model 2532 natural gas tankless water heater in my home. It takes about 45 - 60 seconds for the water to get hot at the faucet which is closes to the heater. This thing is...
clean filter on the cold side coming in and clean or replace the aerator at the sink, rinnai works on water flow, common problem if your water hardness to high or if you have iron in your water
Oct 04, 2010 | Rinnai Webstone The isolator EXP tankless...
The flow is more than it used to be when the Rinnai was working fine with two faucets flowing probably triple the advertised flow rate now. It still cycles hot and cold every few minutes. Is build-up a...
when your tankless starts cycling hot and cold water, then there is probably scale buildup inside the unit.
flushing the unit will remove the scale and any other debris inside the unit.
you can do this yourself, do you have the instruction book that came with the tankless heater?
it is recommended to flush the unit once a year especially if you have hard water.
it takes an hour or maybe a little longer to flush the unit completely.
Aug 29, 2010 | Bosch & Tankless LP Hot Water Heater
Rinnai gas water temperature keep alternating from hot to cold
A fault often found with these units is due to insufficient water flow. Usually this causes specifically the shower to run hot and cold. Try turning on more than one hot supply; if this fixxes the fault you will need to try and increase water flow. Most new tapware/showerware have water flow restictors built in. These are the cause of many problems with continous flow heaters such as the Rinnai. In taps they are usually located in the spout if it unscrews. In showers try the shower hose. Find them and take them out. Also make sure your mains supply to the house is on full.
There are more technical faults but this is something you can easily try first.
Aug 23, 2010 | Bosch & Tankless LP Hot Water Heater
Rinnai Infinity 26 hot water system set to 55 degrees with remote temp adjuster. Water only luke warm for showers. Burnner working, water & gas pressure ok. Any thoughts ... Stephen
If you aren't getting any error codes, then the heater is probably doing its job. Your problem is probably somewhere in your plumbing system. The most common reason you get this sort of problem is due to cold water mixing in the hot water system. There are a number of causes for a "cross connection" :
-Faulty check valve
-Missing check valve on reciculation return line
-Faulty shower cartridge
-Thermostatic mixing valve set too low
-Faulty thermostatic mixing valve
-Faulty anti-scald valve
The easiest way to confirm a cross connection is to: 1) shutoff the cold water entering the tankless heater 2) open hot water valves around the house. If you still have water flowing at your hot water fixtures, then you have a cross connection.
Jul 09, 2010 | Rinnai Digital Remote Water Heater Control...
Exterior mounted Rinnai tankless water heater not
check to see if you have a blocked line on the hot water side
Jan 08, 2010 | Rinnai Webstone The isolator EXP tankless...
Fluctuating temperatures
Sounds like there is not enough flow in order to keep the burner in the heater firing continuously
Jul 09, 2009 | Rinnai Webstone The isolator EXP tankless...
Runs out of hot water
I wonder if you have this problem below caused by a drop in water pressure from someone flushing a toilet or a washing machine. I would call the company to remedy this issue.
17. What is a cold water sandwich effect? The term “cold water sandwich effect” is a term that is used to describe the introduction of cold water into the hot water supply line during frequent on/off operation of an instantaneous water heater. The cold water sandwich effect, when present, appears as a momentary drop in hot water temperature as it is discharged from a hot water supply outlet (i.e. shower, tub, or faucet). This phenomenon is present in the operation of all instantaneous, tankless style, water heaters, but is minimized with the high tech design of Rinnai water heaters.
The technology built into the Rinnai water heaters is designed to minimize the cold water sandwich effect. Rinnai water heaters are microprocessor controlled and when water flow through them ceases, they remain in a “ready to fire state” for approximately 1 minute. If water flow through a Rinnai water heater begins within the first minute following water flow stoppage, the water heater will fire back up within 1 to 2 seconds. This minimizes the cold water sandwich effect that would otherwise be experienced with a low tech tankless water heater. It should be noted that the cold water sandwich effect cannot be removed completely from tankless style water heaters. The safety standards developed to insure the safe operation of water heaters require a delay in the ignition sequence of all gas water heaters.
While the cold water sandwich effect cannot be completely eliminated from standard plumbing systems, it can be eliminated from plumbing systems that have a supply and return hot water circulating system. Rinnai has developed 2 methods to eliminate the cold water sandwich effect in residential hot water circulating systems.
The first (and preferred) method to remove the cold water sandwich from circulating systems utilizes a small electric tank water heater (powered up) that is used with a dual purpose. The small water heater acts as a mixing tank to eliminate the cold water sandwich effect from the Rinnai water heater and it uses its electric heating element to offset the heat losses from the hot water circulating system.
The second method to remove the cold water sandwich from circulating systems utilizes a small 2 to 6 gallon storage tank installed on the hot water outlet of the Rinnai water heater. This tank acts as a mixing tank to blend the cold water sandwich with hot water and eliminating its effect at fixtures.
Mar 11, 2009 | Rinnai Water Heaters
Rinnai Webstone The isolator EXP  tankless water heater Service Valves WRIK Logo
3,335 people viewed this question
Top Rinnai Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
