My laptop is very hot
My laptop P6860FX make the shutdown when it's hot and your performance is bad... i dont know why... sometimes the videogames are slowly and stop...
its chip of video Nvidia GeForce 8800M GTS also put so hot and the air too...
I dont know what I can do it
  • orfelu Jan 19, 2009
    thanks man, and yes, I purchase a one but the problem is the processador and I'm going to change the laptop thanks
  • 404 Answers
Hi!
Sounds like your beating the stuffing out of your laptop? Have you tried a Usb cooling pad and also siteing the Laptop in a cool breathable area?
I had a collegue with the same problem although he was using it in the Laptop bag (Silly Billy) on a four fanned cool pad and well happy!
Good Luck!
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Posted on Jan 16, 2009
Keeps tripping thermal shutdown
Most of the time its just bad (thermo disk) thermal shutdown as you call it. If you dont have any hot water at all just unplug the two wires on that disck and stick them together,this bypass that disk. then have somebody turn on the hot water while you watch the heater for any problems. Let me back up just a little.
Before you do that you must know if its tripping while the water is flowing through the heater if it is then its a weak disk. If it trips a few seconds after the water is shut off then for some reason(usually a bad circuit board) the element is not shutting off and over heating the disk. That means the disk is doing its intended job. Do not bypass the disk ifit trips after the hot water is shut off at a faucet.
Jan 11, 2013 | Stiebel Eltron TEMPRA 12 Tankless Water...
Is my laptop too hot?
Hi and welcome to fixya
Mitchell Baker when the cores are getting at 95c you should stop playing the game . but ! this is not dangerous because your laptop will automatically (shutdown) when the cores will reach 105c
hope that will be helpful
Dec 27, 2012 | Computers & Internet
I'm having problem with my hp dv6000, the hp dv6000 is doing sudden shutdown once if i try to use it for long time it'll shutdown and after the first sutting down it will do like one,two or three...
Hello!
You can have software or hardware problem. First you must know what is temperature of you notebook. Sometime you need open the case and clean cooler.
Sometime the people slop the drink, and that can do problem on the motherboard.
You can also try another charger. Sometime you must format hard disk and make new system.
Jun 24, 2011 | Computers & Internet
Hi. i have a compaq cq40 laptop. dual core 2.1, 2gb memory, win7 starter. it always hangs up. even though i'm not doing anything, it hangs up. so i force shutdown it by pressing the power button or...
That maybe problem with your fan processor . And it also maybe because of overheating in your laptop.
-Do you have using fan laptop?
Exmple:
Sometimes, user with problem fan processor like to use this fan.:
How to know that your fan processor have problem?
at the side left , you will see that hole-hole and feel hot there with your hand.
If you feel it is to hot, than pciture above is the best fan for you.
good luck..
other hand, ask expertise computer, to open and clean your motherboard
Here the link for you to see expert laptop clean fan
Dont do yourself if you don't know how to operate.Please. is about safety and money
May 17, 2011 | Computers & Internet
During work my laptop gets jam, until i dont take the battery out it dos'nt shutdown and after shutdown it does'nt start back.
Your laptop may be getting too hot, or it is not able to cope with the applications that are being run on it. It may need to be upgraded, you might want to concider performing a fresh install of your operating system Windows XP/Windows 7, remember to backup your information. Get your laptop serviced, the technician will remove the dust from the inside of your laptop, this will allow greater air flow through your laptop thus reducing the tempreatures giving you a laptop that will perform at it's optium level.
damnor01
Dec 10, 2010 | Twinhead DURABOOK N15RB Notebook
I have a HP Pavilion DV7 and it keeps shutting down at random times.. When I turn the laptop back on, it starts up normally besides the improper shutdown screen. It has only happened twice, but its been...
some times can be like as thermal shutdown.
you can check it when using get so hot the back side of the laptop.and you can see reduce the output
of air flow from the cooling fan.and that air flow is get very hot.
for that problem, need to service the cooling fan.
other vice need to check the battery. its go bad, via in small power drop pc goes off.
Dec 05, 2010 | HP Pavilion dv7-1240us Notebook
Lenovo Y410 laptop is getting hot and shutdown automatically.
When systems power off suddenly, always suspect - the power first. I would then look at heat and physical connections next as culprits. Memory errors almost always show up as blue screens.
I say try a new power supply and see what it does. Its not a lot of money either way.
Run CPUID Hardware Monitor and watch your temps. You will have to turn logging on or you will lose the data in a crash.
Make sure your CPU heatsink is still connected properly. Things have a way of working loose.
Apr 21, 2010 | Lenovo 3000 Y410 Laptop
Automatic shutdown without notice
its because CPU get hot. check the cpu fan or
clean that, heatsink of cpu fan must be clean and closed to cpu.
Aug 01, 2009 | Acer Aspire 5315 Notebook
Blue screen shutdown on my hp pavilion
you need to perform a repair of operating system using windows cd which came along with the system
log on to microsoft's website and get info how to perform a repair.
http://support.microsoft.com/kb/315265
Jun 09, 2008 | HP Pavilion dv6000z Notebook
Gateway P6860fx Shutdown
for what its worth I have the same laptop..bought it from best buy as you did.I play a lot of 3d games..I play Crysis for hours at a time as well as F.E.A.R. and have never had a shut down problem.I would suggest taking it back to best buy.The only thing I have found to be a problem with this laptop is that its a 64 bit operating system.I have Vista 32 bit on my other computer and have never had a problem..the 64 bit has given me driver problems on a few programs that I use to use.I'm actually thinking of doing a fresh install and put in vista 32 bit.Haven't decided yet..still searching for more info on the 2 systems.
Anyway..I'd take it back.
PS..the fan is working isn't it?
May 22, 2008 | Computers & Internet
Open Questions:
Which 5 Things missing your website? 1. Social Media Links Social media has become the foremost popular and best type of communication. With the recent announcement from Facebook that over two Billion individuals log in daily to use their website, it might be ludicrous to not faucet into this medium to achieve out to a wider audience vector-free-social-media-icons By using a simple to use social integration tool, websites will easily add this feature to share a message with their social circle quickly. 2. Clear decision to Action Buttons As shortly as you get a visitor to your website, it needs to be captivated to perform a relevant action. It may be a Call us Now button or a Sign-Up form for a free service trial, asking the user to act instantly. Netflix It should make sure that these buttons have the proper aesthetic attractiveness and appear at the correct time while not annoying the end-user. 3. Responsive web design The use of smartphone and tablets has quickly increased since 2012. Marketers corporations'and corporations'and firms} are currently paying shut attention to the present platform wherever fifty-eight of companies have a core mobile promoting team. responsive In such circumstances, a responsive web design is crucial to developing if businesses want to achieve profitable customers. A mobile-friendly website will permit you to compete together with your competitors and provides your business the boost to remain ahead. 4. Email marketing check-in Email marketing campaign could seem like an obsolete technique to stay up-to-date with your customers, however, of course, it can produce wonders for your business if used properly. email signup Placing an email subscription type will permit you to interrupt through the middle of promoting your services to an audience with revenue generating results. 5. Testimonials Word of mouth advertising is that the most credible means that of promoting your business. a region on your website containing remarks and comments of clients'the purchasers'the shoppers} you've got antecedently served will instantly gain the customer trust. test The client testimonials may be a way of gaining your website visitor trust by exhibiting a decent log of your past performance. confirm to focus on these reviews on your website somewhere close to your services section to realize effective results.
Feb 19, 2018 | Facebook Computers & Internet
Computers & Internet Logo
163 people viewed this question
David Payne
David Payne
