Question about Philips 200S4SS (Silver) 20.1" LCD Monitor
Monitor power problem
My philips 200S tft is not very old, the power light goes off and the screen goes blank the monitor then comes back on after a second or two, with the philips screen then your work. it happens completely random some times loads of times a day sometimes not at all. this is now a brand new pc and it still does it. im running the resolution at 1600x1200 and have a NVIDIA Quadro NVS 285 GFX card in the new pc so i know its not a PC issue. ???? ive run out of ideas?
    Problem Solver:
  • 10 Answers
It sounds like an internal issue, more likely the LOPT components are overheating, possibily due to dust collection causing temporary shorts, or an arcing capacitor. The randomness is due to weather conditions, high humidity more likely to monitor wil shut down, the dryer the weather the moisture in the dust would have evaporated, resulting in nothing happening, and a working monitor. I suggest trying this first:- Unplug the monitor from the outlet, and the computer, open the case, but REMEMBER! the monitor can still pack a punch even when it's unplugged from the outlet, (once the case is open, it is completely safe if you accidently brush against a metal part, but under no circumstances (unless you know what you're doing) remove the rubber cap that's either on the top, bottom, or sides of the back of the screen, doing so can result in a massive jolt of up to 20,000 volts),use a can of compressed air to blow out the dust, making sure you clean right up to the control buttons on the front, screw the case back in place, then try the monitor, if it's still the same, and unless you are a qualified electronics engineer and would like to repair the monitor yourself, I suggest you take it to a repair shop.
Posted on Jun 18, 2007
SOURCE:
I have a gateway FPD2485W tft lcd monitor and i start my monitor and after it shows gateway it then goes black. How can this be fixed
bonannorl, Maybe it can be fixed. You did not give any history of unit. Only "now" stuff. Is unit covered by Gateway warranty? How old is unit? Date of manufacture? Did unit work fine connected to your pc and this black or black n blank screen thing suddenly happen? Is screen also BLANK? Have you swapped-in old monitor to prove PC is OK? Your CCFL back-lit lcd monitor no different than any other brand in it's basic design and operation. Get into my fixya profile and read some of my testimonials and solutions to black or black n blank screen problems to help in your decision to DIY fix or contract out needed repair work. Most likely 2485w has problem with it's internal "switch-mode-power-supply"/"ccfl inverter supply"!! Let me know more info about unit.
12fixlouie on fixya.
Mar 09, 2010 | Gateway Computers & Internet
Monitor goes blank coming out of power save mode
I found this on the Internet...
"Press the "Input" button on your LCD monitor's front panel repeatedly at three- or four-second intervals until your monitor wakes up. If your monitor is set to an incorrect input mode, it won't receive a video signal. After you reset the monitor to the proper input mode, it will receive the signal and wake up automatically."
I have provided a Link with more info for you!
A
How to Get Your LCD Monitor Out of Sleep Mode
Dec 24, 2017 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
Monitor comes on and displays for a second then goes blank.
New monitor? Does old monitor still work? Did the monitor ever work? did the computer ever work? is power light on computer on? is power light on monitor still on?
Oct 15, 2009 | Dell 1702FP UltraSharp 17" TFT LCD...
Monitor goes blank after a second after power outage
what happend is your monitor cought the brown out and the power supply capcitors are not defective and what that means is the monitor needs to be repaired there is no quick fix please rate accordenly thanks.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
SVA Color TFT LCD is white on start up but goes blank.
when i turn the computer on the light on the monitor blinks green but i cant get it to turn on..i have a black screen.
Jan 16, 2009 | Computers & Internet
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Samsung SyncMaster 243T blacklight
indeed, probably the backlight...
Nothing to do about that but repair or replace, sorry...
Nov 13, 2008 | Samsung SyncMaster 243T (Black, Silver)...
Screen only stays on for 2 seconds at a time
just an update...I have fitted a new cable (pc to monitor) and it has been on for 2hrs now so fingers crossed!
Aug 19, 2008 | Philips 19 in. CRT Monitor
Philips 200S4SS (Silver) 20.1" LCD Monitor Logo
468 people viewed this question
Top Philips Computers & Internet Experts
Ekse
Herb Box
Herb Box
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
