Windows can't start cd-rw code 19
Its because its configaration information in then registry is corrupt or missing
  • rebelyes1 May 11, 2010
    Are you saying windows cant start or the cd-rw cant start?
    Scholar:
  • 108 Answers
Try one of these solutions.
http://support.microsoft.com/default...b;EN-US;314060
This is a zip file download need WinZip or 7zip to extract
http://aumha.org/downloads/cdgone.zip
Hope this helps!
Posted on Jan 16, 2009
DVD player not recognized
If your computer's CD or DVD drive appears to be missing or corrupted and you've received a "Code 19" error message that says "Your registry might be corrupted," you can fix it by following some steps to modify the Windows registry.
Note that while this process isn't particularly complicated, it does require that you are familiar with computers and know how to modify the Windows registry.
If you aren't comfortable doing this, you should seek the help of a qualified computer professional to assist. Click the "Start" button, click the "Run" option and then type "regedit" and click the "OK" button.
Use the navigation pane on the left side of the window to navigate to the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Select the "UpperFilters" key in the right side of the window, then click the "Edit" button and then click the "Delete" option.
Click "Yes" to confirm the deletion.
Click the "LowerFilters" key, then select the "Edit" button and choose the "Delete" option again. Click "Yes" to confirm the deletion.
Close the Registry Editor window and restart the computer to finish applying the settings that should fix the Code 19 error.
Apr 08, 2014 | Panasonic Toughbook CF-W8 12.1-Inch Laptop
Dvd driver not properly installed in registry
Not working my cd drive.
If you are running Windows 7 you can use C Cleaner or Windows 7 Manager to clean up your registry if you don't have them you can download Regcure or Registry First Aid to clean up the reg error then you can restart your computer and see if windows can reinstall your hardware.
Oct 20, 2012 | OEM Systems Acer Aspire 5742g Dvr-td11rs...
I cannot Read and write the DVD as i'm holdin a LG SecurDisc Supermulti writer,so what should i do now
CD/DVD Drive is Corrupt or Missing (Error Codes 10, 19, 31, 32, 39, 41) Note: The solution provides requires editing of the registry.
1.To begin the process, start the Registry Editor.
  • Click Start, click Run, type regedit, and then click OK.
  • On Vista machines, Run is accessible through Accessories.
  • Click the plus sign (+) next to the following folders in the left side of the window pane:
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
2.Look for any of the following names in the right side of the window pane:
  • UpperFilters
  • LowerFilters
3.If any of the items above are listed, right-click on the item and select Delete.
4.Be sure to restart your computer after you have deleted the files in the registry.
5.Open My Computer (XP) or Computer (Vista) and check to see if your CD or DVD drives have returned.
6.In some cases, you may need to reinstall some programs such as CD or DVD burning software, iTunes, or Nero
Oct 17, 2010 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
DVD-RW does not work and is not recognized. It does show up in device manager but the device status lists the following error: Windows cannot start this hardware device because its configuration...
Download and run a registry scan with ccleaner from here.
http://www.filehippo.com/download_ccleaner/
This will remove the corrupt registry entries. You will need to restart your PC afterwards and may get the "new hardware installed" message.
Dec 23, 2009 | Toshiba Satellite A215-S4747 Notebook
Code 19 error indicating corrupted registry. I've tried uninstalling and reinstalling but nothing works. I have the same problem with my memorex DVD ROM/CD RW drive. I think Norton 360 trashed my registry
yeah, if your registry has been trashed. you should use some registry defrag tools to fix it. I know a <a href="http://www.system-tools-software.com/free-registry-defrag/">free registry defrag</a>, you can look for it and have a try. Good luck!
Nov 09, 2009 | Lite On LTR-52327S CD-RW Intenal IDE...
I want to burn dvd using cheetah dvd burner,when i press burn a note says''insert a media writable
Might be several reasons
Take a look on front panel if it says DVD-RW use only DVD-R (RW) blanks, +RW only +R(RW), +/- or RAM both. Check the record speed your blanks might have higher speed than allowed
Also blank might be upside down
Hope that helps
Good Luck
Mar 05, 2009 | Compaq Computers & Internet
CD Rom and DVD Rom won't work
you need to delete lower and upper filters from registry to fix the problem instructions CLICK HERE
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Code 19 and SD R2102 CD-RW/DVD-ROM Burner
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey.
Recommended Solution :
Many third-party programs that control CD or DVD burning (as well as some player applications) install CD- or DVD-ROM filter device drivers into Windows. These filter drivers are meant to allow for low-level hooks into the hardware, to allow for functions such as packet writing (where a CD-R/W or DVD-/+RW can be written incrementally, like a hard disk).
These filter drivers sometimes have problems that can cause the CD or DVD drive to stop working correctly. The device entry for the CD or DVD drive in the Device Manager may show up with an error descriptor that reads "The device could not start." Additionally, there may be an error message that reads "One of the filter drivers for this device is invalid." The devices themselves do not show up in Explorer. Error codes for the device include code 31, code 32, code 19 or code 39, and sometimes the even more ominous warning "Your registry might be corrupted" appears.
Fixing the problem simply involves deleting the filter entries for the third-party device drivers. These entries can sometimes become damaged (which is what produces the "corrupt registry" warning).
To delete the offending keys, open the Registry and navigate to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***\{4D36E965-E325-11CE-BFC1-08002BE10318}. . Delete the keys named UpperFilters and LowerFilters and reboot.
Several of the products made by Roxio are infamous for causing this problem, although in fairness to the company the most recent versions of their Roxio CD/DVD writing software (6.2 and higher) do not have these problems. Users of 5.0 or 6.0 editions of the Easy CD & DVD Creator product, which has been bundled with many new PCs in the past, should upgrade to 6.2 or better. Other programs can also cause this problem, with the same solution.
Note that after you do this, you may lose functionality in the program that uses the filter drivers, which may need to be reinstalled.
It will be highly appreciated if you could take a minute and provide us your feedback..
May 14, 2008 | Toshiba SD R2102 CD-RW/DVD-ROM Burner
Computers & Internet Logo
David Payne
David Payne
