Question about Pioneer CDX-P656 CD Changer
Disk Cartridge Insertion
I am trying to insert the disk cartridge into the changer and it will no go all the way in - i.e. it won't go in far enough to close the door. Does it have to be powered up for that to happen?
    New Friend:
  • 83 Answers
Yess
Posted on Jul 12, 2007
CD's are in my disk changer with no power to pop out the CD's in a 2000 ml320 Benz can u open it with out power?
use a business card or old credit card slid it between the cartridge and the changer to free the lock, the cartridge will pop out free try both sides
Jun 04, 2014 | Cars & Trucks
My 2003 chevrolet silverado says no discs when there are discs installed
Is this a internal 6 disk changer or a external one ,if external then eject the cartridge and remove all the CDs ,now insert the cartridge and if one is jammed it should remove itself into the cartridge when you press the eject cartridge button ,well this works on my jag
Nov 30, 2013 | 2001 Mercedes-Benz C-Class
My BMW X5 6 CD Alpine changer is jammed and will not work. How do I fix it and remove the disk?
If the issue is you cannot eject the cartridge this would be simple.
Slide the changer door open as if ejecting the cartridge. Take a credit card/driver license and insert about 2 to 3 inches between cartridge and chassis. You should hear a click and the cartridge should eject.
Once the cartridge is out check to make sure there isnt a stuck CD in the changer. If there is remove the loose CD. If the CD is stuck in the player itself insert the empty cartridge the changer will cycle through the process. Once it stops you can press eject button and the CD should be in the cartridge.
Feb 25, 2010 | Alpine Car Audio & Video
Error Message
sounds like the lens is dirty -try this out you kow them cans of stuff they use to clean keyboards with its like filtered air or something -try to blow out the guts of the cd changer with one of them cans and maybe it will help with functionality do the same with the cartridge emtied out and then run a cd lens cleaner disc and see if that does the trick-
May 21, 2009 | Kenwood KDC-C669 6-Disc CD Changer
Cartridge insertion extremely difficult
If cartridge insertion is difficult, perhaps the wrong cartridges are being used? Or if you are using compatible cartridges, sometimes they are slightly larger than the originals, which can make insertion difficult
Jan 03, 2009 | Office Equipment & Supplies
Can't get the retaining ring back in on MOEN Magnum Replacement Cartridge
Make sure that the stem is slightly pulled out or open then use the plastic insertion tool that comes with the new cartridge and a pair of pliers to push cart. all the way in. Try the retaining clip again. If still won't go, partially install the insertion tool and turn cart. back and forth til clip goes in. Hope this helps
Nov 30, 2008 | Moen 3175 Legend One Handle Shower Faucet...
KENWOOD 10 DISK CHANGER
Trying hitting the reset button which should be either on the changer next to the cartridge eject or on the controller display. It will be a pin hole to press.
Oct 17, 2008 | Sanyo FXCD-500 RB CD/Cassette Receiver...
My disc is not changing and is stuck ( CHM - S620 by Alpine )
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Feb 16, 2008 | Alpine CHM-S620 6-Disc CD Changer
Ejecting magazine on Pioneer CDX-fm1257
I have very gently taken a pair of needle nose pliers and grasping the edge of the cartridge that holds the disk carefully work it back into the magazine.
Nov 07, 2007 | Pioneer CDX-FM1279 12-Disc CD Changer
Pioneer cdx P1280 error11
pnoman: Your code means an electrical/mechanical failure. Follow this: 1. If the cartridge is stucked try to force it out slowly with a fine screwdriver. 2. Once is out or if already out without forcing it, remove all remaining CD's. 3. Insert a laser lens CD cleaner. 4. Clean it at least 3 times. 5. The unit must be disconnected from the 12V signal to be reset it at least 5 minutes, then reconnect. 6. If problem re-appears repeat procedure once more. If problems still, your laser lens is damaged and need replacement. Probably from $40.00 to $55.00. SithPitt
Jul 04, 2007 | Pioneer CDX-P1280 12-Disc CD Changer
Pioneer CDX-P656 CD Changer Logo
46 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
