Question about Microsoft Windows XP Home Edition
I need to repair windows xp home edition
The Cd that I used to install windows XP in my PC came directly from the manufacturer, Emachines, actually there are two CD's, one for restoring my PC and the other one is used for installing Windows XP Homre edition but it doen't have 'Repair Windows'
I have two problems: one, I can't download PDF from the internet because I get the following message error: FoxitReader OCX.ocx, this error messsage is related directly with the installion of Foxit Reader program that edits PDF so I uninstalled the program but still I had the same problem, then I restored my PC but the problem was not fixed f
Second, When I installed Windows in my PC just three weeks ago, due a virus problem, I noticed three weeks later that a file was missing in the directory of MY Documents and Settings which was the Internet Temporary Files, I know that is in my PC because when I used one of some programs that I have to delete temp files in the results obtained it showed that there were some Temporary Internet Files found, sometimes there are temp files that I cann't be deleted after the scannig process so I have to delete them manually.
Six years ago I ordered Service Pack 2 on a CD from Microsoft, I only paid S&H to get it, I wonder if I could get a copy of Windows XP home edition from Microsoft,without paying a full price for it because I have my XP Home edition serial that I got from eMachines when I purchased my PC.
I need help
Thanks
Carlos Delavega
Thanks Carlos Delavega
    Brigadier General:
  • 5,158 Answers
What version of foxit are you using ?
For the second problem... open a folder... any one will do... at the top in the menu you will see tools.. folder options... then the middle tab which is view... in that window scroll down untill you see show hidden folders and files... mark that.
you temp files folder should be there now.
Robert
Posted on Jan 16, 2009
  • 535 Answers
U need to install foxit redaer in your pc or u need to intall adobe acrobet reader in your pc here u can download acrobet reader & install in your system acrobet reader
Need windows xp home edition to repair operating system
if the operating system is very bad you can restore from the recovery partition which is already existing on your computer.
however, you should be able to go in the computer manufacturer website and install from there.... maybe even get the entire dvd/cd from there. what manufacturer computer is yours?
Jun 15, 2015 | Microsoft Windows XP Media Center Edition...
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
Can i download windows xp home edition on one laptop and then make a cd backup to download on the other laptop that actually needs it
No you cannot, especially if the laptops are different make/model.
You need a Windows XP Home installation CD and the installation code that is printed on the Windows label on the bottom of the laptop.
Dec 08, 2011 | Computers & Internet
Yes expert ntldr missing
It means that your computer is missing a file that windows xp needs to run boot properly or is missing a program that your home edition xp needs. Repairing the OS or windows xp home edition by means of your xp instalation cd will do the job. Just insert your xp installation disk to your cd/dvd rom and select install windows xp home edition. Then select ( repair ), and so on let it finish repairing . Once your system rebooted, let it run without pressing enter or space bar. Just watch and let your computer do the job. This will probably solve your boot problem. But before doing all of this, please check your IDE or SATA cable and also the power cable that is connected to your hard drive. Try to unplug and plug again to ensure a good connection. If this won't work, you can proceed repairing Your windows xp installation or reinstalling a new xp operating system. Have a nice day and i hope i was in any help to you friend.
Aug 18, 2011 | Microsoft Windows XP Home Edition
My windows xp home edition has crashed and i have no recovery cd
Find a friend with either a "retail" Windows XP Home Edition CD-ROM disk,
or with an 'OEM' ("original equipment manufacturer") equivalent.
Use that disk, plus the 25-character product-key on the label on the side of your computer,
to reinstall Windows, or first to try to "repair" your installed copy of Windows.
Or, if you have a "brand-name" computer (Dell, HP, IBM, Lenovo, Acer, Gateway, eMachines)
telephone the manufacturer, and order a replacement "System Restore" set of CD-ROM disks.
Probably about $20, plus $20 for overnight-courier.
Nov 22, 2010 | Computers & Internet
I need to do a windows repair but I cannot find my cd. Can I download one and save it to a disk and install it on a different computer
Ask your friends to borrow either a "retail" Windows XP Home Edition CD-ROM (bought when XP was available in retail stores) or an "OEM" (Original Equipment Manufacturer) version. The OEM version was used by Microsoft-licensed "system-builders" (small computer-stores that assemble computers from the individual components, and then install this "generic" version of Windows).
If you have the "genuine Windows" decal on the side of your desktop, use that 25-character product-key and the "borrowed" CD-ROM to reinstall Windows.
Nov 18, 2010 | Dell Microsoft Windows XP Home Edition
Pcg-fx55v/bp - how can i reinstall my windows xp
If you have the original software from which it was installed from you can use that CD.
All you need besides the CD, is the Certificate of Authenticity (COA) For your installation to actually be genuine. If you do not have the Original software/Installation CD, then that is one thing you need to obtain.
Mar 27, 2010 | Sony VAIO Notebook
I need to restore xp home edition but cant find cd have product key numbers emachines 330
You should be able to reinstall from another XP Home Edition OEM CD so if you know someone who has a computer which came with XP Home Edition preinstalled you should be able to use their Cd, you'll still have to download the drivers for your pc though.
May 19, 2009 | E-Machines eMachines Desktop PC
Installing windows xp
Try first  to use hiden boot cd.With it u can see all files on hdd.When u see winxp files just delte.But i will not take responsibility couse sometimes xp wont boot up...
But i recomneded you to save all your data and format your pc.Make sure that the partition cd must be deltet befor u contiuing with formating ur pc like in this pics:
http://www.imagehost.ro/pict/3003390347268b3728923.jpg
Oct 29, 2007 | Microsoft Windows XP Home Edition
Microsoft Windows XP Home Edition Logo
304 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
