Question about Car Audio & Video
93 honda accord radio
You wouldnt know a website to go to or maybe u know how to get the plastic trim that wraps all the way around the center console to around the gauges and then the last air vent on the left?
    Scholar:
  • 103 Answers
Posted on Jan 16, 2009
How to replace pollen filter on Honda accord type v year 2000
The two filters are located below the glove compartment. In order to reach it you need to pry out the lower center console, where the lighter socket is located. This will reveal a couple of hidden screws that hold the plastic underdash right below the glove box. Pry out this plastic trim piece.This in turn will reveal a structural beam that blocks access to both filters, it has only 4 screws. The filter themselves have no screws, just pull them out.
Jun 15, 2011 | 2000 Honda Accord
Changed battery in 1995 honda accord,now i need radio code
You'll need the serial number from the radio which may require you to take the stereo out of the car. Before you take the stereo out, while the ignition is off, press and hold the 1 & 6 on your deck. While holding the buttons turn the car on (make sure the deck is also on) it may flash two codes on the screen. If that's not the case, use a plastic tool to carefully pull the black plastic trim from around the stereo. Once that's off there will be a few screws to remove. Then write down the info from on top of the stereo (I like to take a picture). Call your local Honda Parts department. Give them the serial number and they will give you a code. Sometimes they will ask for prof of ownership.
Jan 22, 2011 | 1995 Honda Accord
The window of my honda accord lx 1993 goes down but it doesn't go up what should I do.
check switch or take door panel off to see whats going on w/it................
Dec 28, 2010 | 1997 Honda Accord
How would i take my fectory radio out of the car?
Radio & Tape Player
  1. Disconnect the negative battery cable. If so equipped, disable the Supplemental Restraint System (SRS).
  2. Remove the floor console and the front console panel. On 1984-85 cars, if access to the back of the radio may be gained through other means, such as removing the "pocket" from the console, the console need not be removed.
Radio mounting on 1990-93 Accords
4. Remove the ashtray and ashtray holder.
5. Remove the two screws holding the radio at the rear of the unit.
6. Carefully push the unit out the front of the dash. When access
is gained, disconnect the multi-pin connector and
the antenna cable from the unit. Remove the unit.
7. Reinstall in the reverse order. Take great care not to damage the dash trim and instrument visor. Make certain the connectors are firmly and squarely installed. If applicable, be sure to enable the SRS.
Mar 06, 2010 | 1992 Honda Accord
How do I remove the radio on a 1987 Honda Accord LXi
Radio & Tape Player
Radio mounting on 1986-89 Accords
  1. Remove the ashtray and ashtray holder.
  1. On 1986-89 cars:
  2. Remove the coin box, air vents and ashtray lighting bracket.
  3. Remove the dashboard switches on the left and right of the steering wheel.
  4. Lower the steering wheel to its lowest position. Remove the dash visor. This is a large, one-piece assembly which includes the center dash trim. It's plastic; don't break it.
  6. Carefully push the unit out the front of the dash. When access is gained, disconnect the multi-pin connector and the antenna cable from the unit. Remove the unit.
Dec 07, 2009 | 1987 Honda Accord
Plastic trim that goes around ac/radio. I need a replacement.
A junkyard is definitely the best bet. You may have to find one where they will allow you to remove the trim yourself, as many do not want to be bothered.
Nov 18, 2009 | 1992 Honda Accord
Replacing gear shifter light bulb
As a warning, this is a little difficult and requires some patience. I just had to do with to my 2000 accord, and I'm betting the process is very similar for your '98 model. Before starting, you're going to want to get a Phillips head screw driver and a pair of pointy needle-nose pliers. The first thing you'll want to pop off it the driver's side fuse box cover. Under that you should see two screws towards the bottom that hold on the plastic trim that covers the underside of the steering column. This was held along the top with a few pins that should pop lose with a little effort (not too much force though!). There is one screw holding this piece in on the other side (holding it into the center console) but you wouldn’t need to remove this, you just need to get behind this piece of trim. Behind it, you should see two screws holding in the piece of trim that covers the side of the shifter. Take those out and it'll give you the little bit of wiggle room you're going to need. Lastly, pop off the black trim around the shifter. All you'll need to do is put something flat under it and gently pull up, working your way around it. This should pull off relatively easily. You should see the two wires leading to the bulb that will be located right in the middle on the driver's side. What you'll need to do is wiggle you're hand up under the side of the plastic side trim and grab the bulb. It will take a quarter turn to loosen it. Put the new bulb you have in the socket, wiggle it back in its proper place (don't forget to give it a quarter turn again to lock it in) and you should be set. Make sure you test the bulb before putting everything back together! I’m sure something doesn’t make complete sense in here, so if you need any clarification on anything in here, let me know!
Jun 02, 2009 | 1998 Honda Accord
Replacing hazard swith for Honda Accord 1996
u must remove the center console....remove the ashtray..(pull it ) remove the plastic trim piece around the shifter , should just pop off ,,,held on by clips...u will see 2 phillips screws under that piece., the 2 screws that secure the trim panel that ur hazard switch is attached to.....remove those screws and gently pull the panel off , u may have to unplug the clock and otherm necessary connectors includeing the hazard switch connector to remove the panel..u should be able to remove the switch with a screwdriver..reinstall everything back the way u took it off...be sure to plug the cig lighter back in...
Apr 08, 2009 | 1996 Honda Accord
How to remove the radio
The '94 to '97 Accord is not the easiest radio to remove. Start with the rear console. Two screws on the sides, then open the console pry open the plate at the bottom and remove those screws. Pull the parking brake up. Remove the cup holder insert.  Three more screws to remove. Now the console will unhook from the front console when you pull it up and to the rear.  Remove the ashtray and the screw behind it. Two more screws for the trim plate. Now the radio is exposed. Remember to disconnect the battery so you don't fire the airbags.
Dec 29, 2008 | 1997 Honda Accord
1999 Honda Air bags controller module
in frt of the center console bolted to the floor i think to get to it you have to pull the center console out the trim piece to the left of the console and the glove box comes out there are two screws on the trim piece that surrounds the radio and heat control pull out the clock and there is a screw to remove the clock stick a small screwdriver under it pull down and the clock should come out gently pul on the trim pull alittle harder at the top the clips grab a little harder there pull out the radio if you have a anti theft radio make sure you have a radio code if you dont have a code write down the serial # on the radio you can call a honda dealer they can run the # and give you the code use the preset buttons to enter the code once you pull out the radio you can see the air bag computer it has torx screws that hold it in the brackett raise the ctr console lid you should see a cover lift it up there are 2 screws the trim around the gear lever pops off pull up on the cup holder remove it th e trim the top of the console puls up the rest of the screws comes out pull out the ctr pocket the rest is self explain
Oct 28, 2008 | 1999 Honda Accord
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
