Question about ASUS P4B533-VM Motherboard
How to clear CMOS on Asus P4B533-VM motherboard
The Asus P4B533-VM motherboard does not have jumpers to help you clear the CMOS but has two bumps of solder that you short with the end of a small screwdriver. My problem is that I can't find those bumps. The area in which they lie should be labelled CLRTC. Can anyone help me find them by indicating a component next to which they lie. Needless to say I've thoroughly inspected the user guide and the board. - Thank you
  • 535 Answers
U have to remove bois battry for the few mints or u have to reset jumper from the moter bordhow to clear CMOS on Asus P4B533-VM motherboard - 65ab895.jpg
Posted on Jan 16, 2009
    Brigadier General:
  • 5,158 Answers
Locate the cmos battey (looks like a watch battery) remove it for about ten minutes. the computer must be unplugged when you do that. be careful when you remove the battery to make sure you do not break the tab that holds it in.
Robert
How to clear cmos in asus a7n266 mb
I had similar mobo and this is what the Asus technician told me. Take out the round battery in your motherboard and flip it around and put it back into the battery slot.(it sounds weird but that is what he said) Hold it there for 20seconds and then put back in the right way it was.
Your cmos should be cleared now. Make sure your pc is switched off when doing this.
Feb 08, 2011 | ASUS NVIDIA nForce Chipset A7N266-VM...
Hi, I messed up my BIOS by trying to update it... I got an asus p4b533 and cant find how to do a CMOS reset. I read about shortening two bumps because this board obviously has no jumpers to reset CMOS....
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine.
Hope this helps
Jan 16, 2011 | ASUS P4B533-VM Motherboard
How to reset the mb?
First remove the cmos battery and put a jumper in cmos port.
Nov 26, 2010 | ASUS P4B533-VM Motherboard
I removed and replaced the 5v jumpers on an Asus p4p800 mb and now USB is hosed. Should I clear the cmos?
Yeah, I would, but READ YOUR MANUAL. There are several jumper settings that can be changed. Just be careful and you should be OK. You will have to run thru the BIOS setting if ya clear the CMOS. Default should work unless you have a RAID or something fancy.
Dec 28, 2009 | ASUS P5PE-VM Motherboard
Asus motherboard( A7N266-VM)
FOr reset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defaults.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Let me know if you need further assistance.
Nov 11, 2009 | ASUS A7N266-VM Motherboard
CMOS PROB
Hello There.
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/P4B533-VM/e988_p4b533-vm.pdf
Section 4.3 on Page 71 details halt on error settings. Select No Error.
That should resolve your issue.
Mar 01, 2009 | ASUS P4B533-VM Motherboard
ASUS A7N266-VM
try to clear (cmos) here is the way:
get to the jumper located near the cmos battery, short it for 3 seconds then return it to its normal position. start the system and load setup defaults.
May 26, 2008 | ASUS NVIDIA nForce Chipset A7N266-VM...
Where do i find the cMos pin??
the cmos clear jumper is near the battery. the jumper is also listed in the manual
Nov 11, 2007 | ASUS A8V-VM Motherboard
ASUS P4B533-VM Motherboard Logo
2,060 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
