Question about Microsoft Flight Simulator X for Windows
No engine Noise outside aircraft
Posted by alexander_ir on Jan 14, 2009
When I activate the button to get an outside view of the aircraft there is no engine noise at all. As you take off you can hear the wheels making a noise on the strip but when the aircraft lifts there is no engine noise whatsoever. There is plenty of engine noise in the cockpit when I change the view to inside. Have you a solution for this?
  • 51 Answers
Thats just the way the design it it does the same for me it isnt wrong.
Posted on Feb 11, 2009
How do you start a plane?
Technically anyone could get in and start a big jet aircraft, but it would have to be pointing in the right direction. Getting a large transport jet going is allot more complicated than just starting the engines. The whole aircraft has a multitude of systems that have to be brought on line even before the start is selected. Failure to do so would have the computers on board sulk until you said good morning to them. The first operation, thus, is to 'power-up' the aircraft, this means to establish electrical power. This can be done in two ways, one being establishing a ground power unit and secondly, the aircraft's own auxiliary power unit, which is normally a little jet engine in the tail of the aircraft. The APU as it's called (auxiliary power unit) will also supply air pressure for cabin air conditioning and to the air starter units used to spin the main engine turbines at high speed to start the main engines, when commanded to do so. This is why the air-conditioning temporarily goes off when the engines are starting, because the APU cannot supply both engine start air and conditioning air at the same time.
After electrical power has been established, the on-board computers will come to life. Some computers are in their own little world and control things that are fully automatic, you only hear from them if they detect a defect in their own self test. Other computers are in pairs and threes, they monitor each other and alert the pilots and engineers via other computers if any detects faults in the others. There are two or three inertial navigation systems that are driven by lazar light. In each unit there are at least three lazars in different orientation. These units can detect the slightest movement and calculate the position of the aircraft by adding that movement to the aircraft's current position. The IRS units are very - very clever since they measure the movement by measuring the shift in the light spectrum when the aircraft moves. Since they measure movement, they have to know the speed the world spins at and the speed of the earth through space, to deduct that from the small movement on the aircraft in order to calculate the position. Allowing the IRS units to come on line is essential and must be done before main engine start. The aircraft must be completely stationary for this to happen.
After all that has been done the main navigation computers are programed for the route to be flown and with other information. The Flight management computers (as they are called on some aircraft) can also acquire their own information, like how much fuel is on board, and in flight the airspeed of the aircraft the angle at which the aircraft is at and from that it will calculate the weight of the aircraft.
So when all the systems are up and running and the computers have done their thing and have been programmed where required we can carry out all the other checks, switch on the galley power and call for a cup of tea and when we have drunk that we are nearly ready to start the main engines.
When ready to start the main engines the air system has to be re-configured to enable the starters to operate, following that the normal procedure is to place the engine start switch in the auto start position, where all the starting functions are carried out automatically. Both pilots monitor the engine start as sometimes things can go wrong like a hung start or a hot start. These sort of malfunctions can seriously damage a multi-multi million dollar engine in a flash and no pilot would want to be responsible for that. As the engine spins up to speed, at a predetermined percentage RPM the captain will select the fuel switch to the run position which will allow the fuel to be injected into the engine for light-up. Following a normal start the air system is then reconfigured once more as part of the after start check list, along with other post start items.
All in all what I'm trying to say is that it is a complicated procedure and not just about turning a key like a car. So if you were to board a dead aircraft on the tarmac and turn the start switch nothing would happen.
So what if the engineer wanted to run an engine for an engine test, would he have to follow the same procedure? Well, apart from loading the flight data into the flight computer, he would have to do everything else, if only to prevent all sorts of warnings that would occur trying to short cut the procedure, since the only warnings he would wish to see is anything that is relevant to the engine start, otherwise engine starting and running warnings may well be disguised by other more insignificant malfunctions. Hope this has been helpful.
Jan 04, 2017 | Aircrafts
How to know if the aircraft is airworthy?
From a pilot's point of view, every aircraft comes from the factory with a checklist of things to look at specifically before every flight to ensure airworthiness. It's generally called a walk-around inspection, checking flight controls for security and condition, tire condition, engine for obvious problems. propeller, fuel and oil quantities. and many other things. The walk around also includes checking to ensure all required paperwork is there including weight and balance, airworthiness certificate, aircraft registration, operator's manual. etc. I would also check the log book to verify the transponder check was done within the past 24 months and the annual or 100 hour inspection is current. From an A&P mechanic point of view much the same applies, however I would look much closer at the maintenance logs for engine and airframe.
Why do pilots have their microphones so close to their mouths when flying?
Most headset and aircraft mics have noise cancelling because between engine and wind noise it would be difficult to understand the pilot without it. To use the noise cancelling mic it must be very near the lips
Does nissan sunny fb15 have a computer box?
Hi there I am Brandon I am a mechanical n electrical engineering technical technician and 4 generation mechanic I am the man that regular mechanics call when they cant find out the problem the pro... don't have any thing do with the ecu you have a throttle plate sticking and it is been left open that is making it act up
thank you n God bless
Jan 23, 2016 | Nissan Cars & Trucks
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from
Dec 21, 2015 | Office Equipment & Supplies
1998 rear brakes make a noise when backing
Noise after replacing rear brake shoes and! - Toyota ...
Jan 19, 2010 - 15 posts - ‎9 authors Check to make sure the new drums dont have a longer/thicker drum face that is scraping the back plate. ... 1998 Mazda 626 FS-DE/CD4-E .... I experienced rear shoebrake clicking/clacking with an older Saturn. ... plate and to be banged back against the plate causing the clicking or clacking noise. screeching noise from rotors + brakepads after ...
Nov 20, 2009
'95 Right Rear Brakes makin' a "clicking" noise when ...
Jan 6, 2008
Rear Brake Noise
Oct 30, 2005
More results from
Nov 08, 2015 | 1998 Toyota Camry
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - > ... > Copier Technical Discussion > Canon
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from
Nov 05, 2015 | Office Equipment & Supplies
What does exp.sim mean?
In Live View mode, evaluative metering is always used to determine correct exposure, though exposure compensation is available. The Exposure Simulation function will attempt to recreate the exposure level that would be obtained with your current settings on the LCD display. This may raise noise levels of the live view feed beyond what could be expected in the final image, since it must operate with a fast enough shutter speed to achieve its required refresh rate. The aperture also remains open by default, and so the exposure simulation doesn't indicate the areas in focus unless you configure the Set button to provide depth-of-field preview, and then hold it down during live view. Exposure Simulation will attempt to continue even with depth of field preview active, though this may raise the live view noise levels even further. If you pass outside the range where the live view feed can simulate your exposure, the "Exp. Sim" icon near the bottom right of the LCD will blink, as a warning.
Nov 24, 2013 | Canon Cameras
My Channel Plus 3445 has quit sending IR remote control signals to remote equipment. I have tried a new IR emitter. No luck. How can I troubleshoot the system or emitter?
Presumably you'd open up the remote and test it with a volt/ohm meter, but you'll need the device's schematic for that.
A quick way to ensure the remote is working: Look through the viewfinder of a camcorder while it is aimed at the remote'd emitter. You'll be able to view the IR beam to ensure that all buttons work -- and to an extent you can view the beam's strength.
Nov 23, 2011 | Channel Plus Televison & Video
No engine noise when viewing aircraft outside the cockpit
maybe your 're to far away from the engine and you cant hear it, even in real. but i dont think yhats it. check your audio settings.
i cant think of anything better, maybe u just need a patch...
Jan 14, 2009 | Microsoft Flight Simulator X for Windows
Microsoft Flight Simulator X for Windows Logo
233 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
