Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
5300 AiO prints all colours except Magenta.
Almost new printer did work fine.
First colour A4 print had red-fade after 80 4x6 were ok.
Next re-try on A4 had no Magenta.
Did head clean per manual. Changed cartridges, then
printed calibration sheet. Magenta still virtually absent.
Re-cleaned and got no red except patchy on top left of
next calibratiion sheet attempt.
Diagnostic sheet has red to match down left side of the
capital K at start of sheet.
  • 45 Answers
You need a new printhead.
Posted on Jan 17, 2009
I have installed new HP cartridges (black and colour)but on testing I get no colours except magenta violet and red!! Peter Fairclough
You must set to clean the print head. Yellow ink doesn't work. Try to clean the print head with some hot water, untill you'll see yellow ink came out. Time to time you must print some color files do not dry the ink.
Mar 31, 2011 | Office Equipment & Supplies
The color red is dull when printing
I assume you've checked magenta toner cartridge level, and tried cleaning.
If so, the next thing to do is try cleaning the scanner mirror. On these models the mirror nearest the magenta toner builds up dust the most quickly, hence why it is the first colour to fade on prints. Only use dry swabs (no solvents) and compressed clean air on the mirrors.
Nov 03, 2010 | HP Color LaserJet 2600n Printer
The Magenta colour on my 2605dn is no longer coming out properly (very faint). The cartridge was replaced by made no difference. All other cartridge colours work fine. Tried cleaning and calibrating but...
A faded magenta on this model is probably a dirty scanner mirror.
The printer design puts a fan in an area that blows magenta toner directly at the laser scanner.
The more toner on the mirror, the more faded the print.
You will need to remove the scanner and clean it.
Nov 02, 2010 | HP Color LaserJet 2600n Printer
This printer has stopped printing reds and oranges correctly ? they are faded. Changed the toners & no difference
Print a "Config Report" from the printers menu...If u notice that the fourth square on the left side (fourth being the bottom square) for Magenta (reds and orange) is missing or very faded, this could indicate that the optical mirrors inside the printer have to be cleaned...Design flaw. ESP..if changing toners doesn't work and your your faded issue is with Magenta (Pink, red, or orange) colours are the only faded ones...With this design flaw in the optical mirrors, magenta mirror is the first to be affected!
Hope this helps!!!! I work in the industry :)
Feb 22, 2010 | HP Color LaserJet 2600n Printer
Red colour fades on both left and right sides of the page. Other colours print fine.
It's probably a dirty laser scanner. The magenta is most pron to this type of problem. Here's a link for instructions. http://forums11.itrc.hp.com/service/forums/bizsupport/getattachment.do?attachmentId=297096&ext=.pdf
Nov 29, 2009 | HP Color LaserJet 2600n Printer
Newly replaced original magenta toner not printing
Dear this printer is solve this problem just
chnge the magenta toner scaner ok ........after that is working but ...do not any idea about this just call me :+91-09328015664
and Email:support@compudesk.in
Jul 14, 2009 | HP Color LaserJet 2600n Printer
HP 840c Printer - Print quality problem.
I have no magenta trying second cartridge still same problem
Jan 14, 2009 | Apple HP DeskJet 840c InkJet Printer
Printing colours
The color cartridge is faulty, you need to replace it.
If it is new ask a refund.
After putting a good cartridge do head cleaning.
Sep 03, 2008 | HP Officejet 5610 All-In-One InkJet...
Won't print red
Red is a combination of Magenta and Yellow. Print a nozzle check and observe for Magenta, Yellow and cyan. If the three colours are printed, no problem with the cartridge. Then it must be the problem of seeing colours in your monitor. .
May 02, 2008 | Canon PIXMA iP2000 InkJet Printer
Colour Cast
Updated section
This red issue has been bugging me over the last week. I have now created over 50 A4 prints of my test file and it was after reading a post from Dan P that the answer came to me. I had been trying to correct the over saturated reds by reducing it in curves, levels and colour balance. Of course this was not the way to go, unless the image has an overall cast. The better method is to enter into Selective Colour within Photoshop and adjust just the red only. The values I have used are Cyan + 15 (this reduces the red), Magenta -5 (removes the remaining traces), Yellow +10 (removes the blue and warms up the skin again), Black -15 (lifts the image). Save the settings and reload them on future images. Create an action and use one of your Function keys to apply the Selective Colours. Incorporate the print command within the same action, this way you can be certain that the selective colour will be applied each time you print. This may not be the ideal solution, but for me it will do for the time being, until Canon come up with a new profile. I expect to make colour adjustments on most images and this is just one of those steps.
8500_06.jpg ink.jpg Use the Selective colour adjustment - it works The ink levels after 55 A4 prints - I don't think so final-test.jpg final-reels.jpg As near perfect as I can get it Reels are now spot on Note: The above solution is a work-a-round which cures the excess red, once you apply the Selective Colour adjustment the screen image will not look right. The adjustment is applied to correct the printed version. Like so many things digital (and analog) you have to make adjustments to suit your own preferences. The strong vivid colours produced by the ip8500 will appeal to some, others may want to tweak their settings.
As a final note, I have just looked at the ink levels after 55 A4 prints and wow, this printer only uses the light Cyan and Magenta, the rest of the colours are all unused. I don't think so somehow. Canon, I think this does indicate that you have a problem with the driver and have another look at the profiles while you are fixing that.
Would I buy this printer?
Given that creating a new profile is not a major problem and I am sure a new one will follow very shortly, then yes I would buy it. Using Photoshop I have managed to correct the colours to suit my taste, however, some may like the bolder colours out of the box. The ip8500 features and image quality makes this printer stand out from the competition.
Price - £329
Pros:
Excellent photographic print quality
Lots of useful features
Speed
Separate ink tanks
Compact design
Cons:
The PictBridge port can't be used to transfer images to a computer
Colour needs to be sorted out
Black plastic case that reminds me of a cats coffin.
Print quality 85* Features 97 Ease of use 97 Design 96 Value 95 Rating 94 - highly recommended
* Note that this mark is for image quality and colour quality
www.canon.co.uk
Dec 18, 2007 | Canon PIXMA iP8500 InkJet Photo Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
148 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
