Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune doesn't spin at end
Hi, I have a Maytag Neptune that I've been very happy with. This weekend, it developed a problem where it doesn't empty out at the end of a wash cycle. If I open the door, water pours out. If I select just the spin cycle, it will drain and then spin. Sometimes I need to do 2 spin cycles to get it totally empty. Any suggestions? I'm going to open it up tonight and check for debris/clogs in any of the drain lines, etc.
  • Rene LeBlanc Jun 19, 2007
    Well, I took it all apart. The pump and drain hoses were all clear. I then tested all the vibration sensors, and they were fine.
    I had a side problem where I had got a lot of silt into it when we first moved in, before I added an inline filter to the house, and the softener solenoid was stuck open. I back flushed it and blew it out good with an air compressor. The hose filters were clogged up pretty bad, so I cleaned them and blew them out.
    I then re-assembled it all, and double checked all the connections to be sure none had wiggled loose. I connected it and ran the diagnostics on the different valves and the spin test and they all were fine.
    I've run 2 loads through it so far and they've all worked fine, so I'm hoping it was a lose connection as nothing I messed with really should have impacted what was happening.
    I'll be back if it still happens.
    Thanks
    President:
  • 1,294 Answers
Of course, did you find anything clogging your outlet filter, this is most likely the problem. The outlet filter needs periodic cleaning, according to your usage.
Posted on Jun 18, 2007
SOURCE:
Whybdoes water remain in machine at end of wash?
If the drain pump malfunctions...or is clogged then it will not empty within the time cycle and the unit will time out. the pump in at the bottom of the machine
May 21, 2014 | Maytag Neptune Washer
My Neptune washer doesn't empty all of the water. Is it suppose to hold water?
The Maytag Neptune front load has a liquid counter weight that makes it sound as though it is not empty. This is a normal sound, they all sound like that, even mine.
Jan 26, 2013 | Maytag Neptune Washing Machines
Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Black mold on rubber seal
youust replace it, and start from scratch. From day one you have to maintain the boot with Affresh, whipe out water
Nov 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Squealing sound
hi there,
the squeeling could be either the rear tub bearing or the the hub seal kit needing replacement. have you had a technician take a look at it?
Sep 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Aug 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune washing machine will not lock
Dear raghar73,
ngfam at you service!
The Neptune is discontinued due to to many defects in design!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
Aug 09, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah8700. Will spin at the end of quick rinse cycle but not on any other cycle. Error code I get is SUSP. Washer does drain out.
Hi
My name is Gloria, my neptune washer will not spin on the last spin cycle of any of the washing cycle. A code of uC comes up.
Aug 08, 2008 | Maytag Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
182 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
