Question about Bosch Nexxt WFMC330SUC
Plastic cover over the glass is broken
Bought a Bosch Nexxt WFMC330SUC at Lowes. The "helpful" employee broke the clear plastic that is over the door. Since no other units were in stock, the assistant manager offered a price break and a replacement part. It never came, and the assistant is gone. The manager says no part is or will be ordered. (Big run-around.) So, this plastic looks like it would pop out and replace easily. But I can't find out how to get the part or if it is really this easy. Or do I have to pay a repair guy! Please help!
  • Bill Sander Jul 05, 2007
    This was a mishap that was not covered by warranty.
    I had to buy the complete door unit since the plastic cannot be removed and replaced on its own.
  • 175 Answers
If the unit is brand new, most companies offer a 30 or 60 day cosmetic warranty, so you should be able to call your local authorized bosch service company and have them out to repair it under warranty. At the very least, your owners manual should give you a number to call for service, and they should be able to order you the part and tel you how to install it. Hope this helps.
Posted on Jun 20, 2007
SOURCE:
Broken plastic base for CBL25
FIXYA does not know who might have a broken JUG .
Dec 03, 2017 | Breville CBL25 Moda Bar Work Top Blender
My bosch nexxt 100 series washer will not start. The spin, wash and finish indicator lights flash simultaneously when try to start.
Make sure dial is switched to 'off'. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. If if doesn't work, do it again.
To get the clothes out if you are having trouble, open door manually. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off. The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Click helped if helped.
Mar 07, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a Bosch WFMC330SUC that does not end the cycle, it just keeps starting over. I assume it is a bad control board, but they are $300+ and I'd probably replace the machine instead. Any suggestions?
Hi wwwylie,
First check the Drain Pump filter, as the last 2 cycles of a machine is Drain & Spin, and if the Drain pump cannot drain the water, the filter may be clogged and the cycle won't progress to spin.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 16, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch washer wfmc330suc still wont drain after pump replacement
check all hoses clear including the sump hose ..if this has non return BALL fitted remove it.Check wiring to ensure voltage present at the pump, you wil need a multimeter to do this one...Good luck
Mar 24, 2011 | Washing Machines
Door Fell Off and broke off the hinges Not the hinge itself but the white plastic part of the door that attaches to them How can I fix it
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number. You could also try the Bosch site direct.
Good luck,
John C
Mar 21, 2011 | Bosch WFMC2100UC Nexxt Essence Washer
We have a Bosch Nexxt 100 Series Washer. The door lock is stuck and will not unlock. We have a load of clothes in the washer but are unable to get the door to unlock. I have tried unplugging the unit,...
Getting the door open is the easy part. Finding out why it won't open might take a little doing -- though replacing the door latch is also easy. To get the door open, Take an awl or something pointy and place it in the hole on the small round cover in the lower left front of the machine. Now use this to turn the cover, unscrewing it from the machine. Once the cover is off, you should see a plastic rod hanging down. Pull this rod and it will unlock the door. You can now remove your wet clothes from the machine and investigate the cause of the problem.
Jan 31, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
I get an E 13 message. I've detached the drain hose but it was clear. Can't open door or try running any other program. I have a small rug in the washer and I fear it's the cause of the trouble. Please...
To remove the drain pump access cover, insert a pointed object (or tool) into the hole, push in to release the latch and rotate the cover clockwise.
If you have a wet dry shop vac attach it to the end of the drain hose to remove any water.
Then remove the drain pump plug and clear out the area keep the shop vac handy as water will still come out of the plug.
Once this is clear you machine will start.
There is also a white plastic zip tie like cord you can pull in order to open the door
Jan 09, 2011 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
I have a bosch 500 bexxt series washer and the front plastic insert on the door has come loose. It seems to have plastic male pine that look they should snap into the door but the top three are loose/out....
Welcome to FixYa.
I think if you can remove the cover and than re-install it may remedy the problem.
Try this...With the aid of a small screw driver, knitting needle, or anything small enough to fit in the small hole in this cover...
It will push in a tab, it doesn't take much force.
Rotate the hole (clockwise) to 6'oclock and it should come free, the edges of the cabinet, not the cover, are very sharp so be careful.
Now with it off you can observe the notches and how they should line up, place it back in place and turn it counter-clockwise.
If nothing is broken on the plastic cover it should resemble this...
Let me know how you make out or if you have any problem.
Thank you for choosing FixYa and Good luck.
Regards,
Macmarkus :)
Sep 08, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt  WFMC330SUC Logo
126 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
