Question about Tally T8006 Laser Printer
T8006 printer error message "change fuser". Did this but still comes up with same message. cannot find any menu reset to get rid of it(as with changing RC roller). Printer is working ok.
  • David Fletcher Jun 25, 2007
    The solution was to go into the maintenance menu
    and reset the fuser counter.
    You go into this menu by holding down the 'menu' and 'form feed 'keys as you switch on, you then toggle to the appropriate section.
  • 186 Answers
There definitely must be a setting to reset the fuser counter. I cant tell you where to look as I am not familiar enough with that model. Check in the counter menus or the maintenance menus, or a reset menu.
Posted on Jun 22, 2007
What is error code E000 mean
Solution:
Press "Additional Functions",
Press "#", then press the "Right Arrow" button till it says, "Printer",
Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
Then press "Set" again, the display will ask you "Yes" or "No".
Press the "Left" arrow for "Yes", then press "Set".
Now, unplug the power cord and wait 5 seconds and plug back in.
If this don't work, get a new fuser.
Feb 04, 2010 | Canon imageCLASS D880 All-In-One Laser...
I have an x543 Lexmark printer and there is an error message, I have not been able to clear; 122.05 Service - Fuser Error Any help?
i have an x543dn has a fuser error of 122.03 service fuser error, i just reset the factory defaults in the config menu and it cleared that error, to get to the config menu press and hold the tick button and the right arrow next to it then power up the machine and continue holding these until the menu is displayed then scroll through menu until you get to factory defaults select this then select reset base, hope this helps. Kev
Jan 08, 2010 | Lexmark T632 Laser Printer
Printer error TALLY T8006 SVC F4 ERROR how do I solve it ?
I belive the SVC F4 error indicates the fuser fan is not functioning.
Check the fan is connected correctly, also check if the fan is working.
If the fan is not working it may need ot be replaced, alternativly it may be a IOD1 Board or the MCTL board
Jun 12, 2009 | Tally T8006 Laser Printer
Tally T8006 Network set up
You can access the the NETWORK men on the T8006 by powering the pritner ON holding down TRAY
You should then be able to change your IP Get method and network settings.
Exit the menu by pressing the UP Arrow untill you see RESET on the display, then wait wilst the pritner restarts and it should have saved the new network settings.
Dec 28, 2008 | Tally T8024 Laser Printer
Replace Fuser error will not go away
With in 2 seconds you have to hit Menu,*,2,8,6,4
Continue even though you hear the 3 beeps.
When it does into maint mode press 88
That is parts counter reset
Scroll to the part and hit ok.
Press 99 to exit Maint mode
Dec 14, 2008 | Brother MFC-8870dw Wireless Multifunction...
Replace Fuser Reset
For the MFC 8860, I turned off the printer. I help down menu. I turned on the computer. It entered Maintenance mode. I typed in 88 (Parts Replacement.) I scrolled to the fuser, clicked ok. Then, I turned off the printer. When I turned the printer on, it said that I needed to replace my laser. I then turned the printer off, help down menu, turned the printer on, typed in 88 at the maintenance menu (parts replacement), scrolled down to laser, and hit ok. I then turned the printer on and off, and poof, now it works. I find it quite unscrupulous that I had a replace PF Kit1, replace Fuser, and replace laser messages all within one hour...
Jul 15, 2008 | Brother MFC-8860DN Printer
Tray 1 - load ltr (WHAT DOES THIS MEAN!!!)
Hope this helps. Please check the printer properties before clicking Ok at print menu command. Now check the available paper tray handler. Try bypass, tray1 or MP tray.
Check also the default paper on Printer Menu command by pressing appropriate setup button. You can try also placing the paper on bypass try if available. The load LTR message means the machine waits a short bond paper on MP tray or on bypass tray.
Best regards,
Rosener
Feb 08, 2008 | Tally T8006 Laser Printer
Machine Error 76
Machine error 76 is a bad fuser lamp. Machine error 78 is a bad thermistor. Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off.
Sometimes the machines will give a false code and can be reset. Unplug machine. Hold down the Menu key while powering back up. You should still get a Machine error message. Enter the number 9...The display should change to Maintenance 9 then enter 1. The Machine error will return. Enter 99 and then make a test print. If you get either a machine error 76 or 78 you will need to have service done on your machine to have either the lamp or thermistor replaced, and depending on the usage of the machine, it might not be a bad idea to replace the entire fuser.
Jan 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Tray1:A4 SVC L1 ERROR
I too have just bought a 2nd hand printer (Tally T8006) that also worked well until the fuser oil seemingly has to 'swamped' everywhere and which now throws up the same error code as above. Will attempt to 'dry it out' and see if the code clears. Have also recently sourced an original installation CD, will check out fault codes when it arrives - Gazz
Aug 31, 2007 | Tally T8006e Laser Printer
Error Message ('replace belt CG')
To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
  1. Power the printer on while holding down MENU/ENTER key
  2. Release the key when the display shows "Utility Menu Clear FC Roll"
  3. If you have replaced the FC Roller then select this option by pressing MENU/ENTER key. If you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  4. When one of these options is selected Press the MENU/ENTER key and the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute". Press the MEDIA key and the display will change to "Execute"
  5. Press the MENU/ENTER key and after about 10 seconds the display will change to "Completed Clear FC. Roll / Belt CG"
  6. Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Jul 12, 2007 | Tally T8006 Laser Printer
Tally T8006 Laser Printer Logo
121 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Vasil Hristov
Vasil Hristov
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
