Question about Lexmark T644 Laser Printer
Posted by rhung33 on Jan 16, 2009 Under Window DOS prompt and Unix Sun Solaris 8 Station , using LPR -p command to print txt file to cause Lexmark T644 printer '' Flushing buffer '' and not print Comment posted on Jan 16, 2009no , I am getting the flushing buffer overflow problem during LPR print a pure text file under DOS and unix Comment posted on Jan 16, 2009I am using the following command and got "Flushing Buffer" at printer Windows DOS prompt : lpr -S printer_IP -P printer_hostname test.txt where test.txt is a pure text file created by text editor at DOS At Sun Spac station : lpr -p print_q test.txt Both got the same flushing buffer result printing PS file without any problem
  • Anonymous Mar 19, 2014
    printer doesn't print it says buffer overflow aborting
    Problem Solver:
  • 13 Answers
The printer can't handle the data it received and flush it out of its buffer. Goto Menu->Settings->Postscript Settings and turn "Print PostScript Erro" on. When the same print job prints, you should get a page printed out telling you what the printer doesn't like. You may also want to try forcing the printer into Postscript mode. Your PS file probably contains a PJL to set the device to PS mode before it prints. When the printer expects PCL data and received PS data(or vise versa), you can get this behaviour
Posted on Feb 06, 2009
Need a list of commands
what do you wish a list of commands to ?
for the dos prompt in windows ?
what is your p.c. running is it Windows 8 ,
Apple IOS ? Ubuntu ? Linux, Unix, ?
Jan 01, 2015 | Computers & Internet
Troy 8150 Printer
Yes I beleive you do need the -P
I use this on a HP 8150 I think it is Aust.version of you machine from the look of it
lpr -S 100.100.10.111 -P raw -o c:\temp\output.ps
Getting print q name
Press Menu until INFORMATION MENU appears on the printer display.
2. Press Item until PRINT CONFIGURATION appears on the panel.
3. Press Select to print out a configuration page
2nd page should be listed your print que name
or maybe just type the ip address of printer in browser and look in printers webpage.
Sorry for sketchy answer just trying to help!!
Oct 31, 2007 | Office Equipment & Supplies
Adobe acrobat distriller 3.0
SYSTEM REQUIREMENTS
Perl 4 or later installed on any of the following systems:
IBM AIX 4.2 or 4.3 with IBM?s Y2K patch installed
HP UNIX 10.x or 11.x with HP?s Y2K patch installed
Sun 5.4/Solaris 2.4 with Sun?s Y2K patch installed
Sun 5.5/Solaris 2.5 with Sun?s Y2K patch installed
Sun 5.6/Solaris 2.6 with Sun?s Y2K patch installed
Sun 5.7/Solaris 2.7
18 MB of hard disk space for Acrobat Distiller
32 MB RAM
INSTALLATION INSTRUCTIONS
The Acrobat Distiller 3.02 for UNIX Y2K Patch consists of two files:
-the distill file, which is the Distiller startup script.
-the distill.y2kfix.pl file, which is a Perl script that is invoked by the Distiller startup script.
To install the Acrobat Distiller 3.0.2 Y2K Update:
1.Make a backup copy of the distill file, which is located in the Distiller 3.02 installation directory. For example: cp distill distill.bak
2.Copy the distill file and the distill.y2kfix.pl file included in the archive to the Distiller 3.02 installation directory.
3.Make sure that the distill.y2kfix.pl file has execute permissions. For example:
chmod a+x distill.y2kfix.pl
4.Modify line 1 of the distill.y2kfix.pl file so that it contains the pathname to the Perl interpreter installed on your system.
5.Modify line 16 of the distill file so that the "install_dir" contains the pathname to the Acrobat Distiller 3.02 installation directory.
Oct 29, 2014 | Adobe PageMaker 7.0 for PC
Send a .txt file (zpl language to COM1) to theTLP 2824-Z.
Help!!! I can not print barcode with DOS-command "copy barcode.txt com1". DOS Version is 6.1.7600. The printer zebra TLP 2844 does not recognize the EPL commands.
j.zh
Jul 28, 2009 | Zebra TLP 2844-Z Thermal Label Printer
USB printing through DOS mode
Google for DOS PRINT USB, and you'll find some utilities that do this.
Or, you can include some commands in your batch file.
First, get the device name:
In a DOS window, type NET VIEW ComputerName (or use 127.0.0.1)
Once you know the printer share name, you use it in a batch file.
NET USE lpt1: \\ComputerName\ShareName /Persistent:Y
This captures the print queue to the shared printer.
You must also go into Printer Properties/Advanced/Print Processor and set it to TEXT
Your copy, print and other commands will work.
Jul 12, 2008 | Computers & Internet
How to write program for running the DOS,UNIX and LINUK command using C language
Dear Sagarshinde111,
Thank you for your excellent question on how to run all DOS and UNIX commands on a Frigidaire GLTF1670A Front Load Washer using the C programming language. I do not know specifically about washing machines, but there is a version of UNIX which has been ported to toasters that would be a good starting point. NetBSD is a full UNIX operating system written in C, and all the source code is freely available to use and change under the Berkeley License (which basically says, do what ever you like, but don't claim you wrote it). You can download it from netbsd.org. You will also find in NetBSD's excellent package source repositories (pkgsrc) the C source code for both DOS and Linux kernel emulation.
I am sorry that we were not able to help you in time for your class assignment (due the next day!), but perhaps this will help the next student who is given this rather challenging homework.
Mar 17, 2008 | Frigidaire GLTF1670A Front Load Washer
OPERATING SYSTEM
Hi
as i interpret your question, you are asking for some examples of Operating Sytems? if thats so, here are some:
MS Windows
ver. 3.11, Win95, Win98, WinME, WinXP, Win Vista
Win NT, Win2000 Pro, Win2000 Server, Win 2003 Server
Linux OS, several "flavors" like Ubuntu, Red Hat, Mandrake, Bayanihan Linux (from DOST-UP)
Sun Solaris, Unix Operating System, BeOS
Apple MacOS, OSX, OS 9
almost forgot, DOS, MS DOS and PC DOS
Mar 01, 2008 | Computers & Internet
Cant see screen on laptop think its videowave???
MS-DOS edit command help edit myfile.txt <press enter>. This would bring up a blank edit screen, as long as the file is saved upon exit this will create the file myfile.txt.
Linux and UNIX xset command help The 'reset' flag forces deactivation of screen saver if it is active. The 'blank' flag sets the preference to blank the video (if the hardware can do so)
Read and follow instructions, good luck, please dont for get to Vote/Thank You
Dec 05, 2007 | Gateway 450SX4 Notebook
Printing from Dos Prompt
1. Save your text file (.txt).
2. On the command prompt navigate to that directory
3.Type "Lpr -S 192.168.1.200 -P lp text.txt"
Substitute 192.168.1.200 for your copier's ip
Substitute text.txt to filename.
Or you can: to print from MS-DOS apps.
1. Share the printer on a networked windows computer. Make sure you make the name MS-DOS compatible.
2. At a DOS prompt, type the following command:
"net use lpt1: \\servername\printer_share/persistent:yes"
NOTE Servername=computer name
printer_share=printers share name
Sep 28, 2007 | Office Equipment & Supplies
Lexmark T644 Laser Printer Logo
1,248 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
