Question about Canon FAXPHONE L80 Laser
Faxphone is not copying or feeding
I suddenly was unable to make copies from my fax; also noticed that the document was not feeding at all. I went to an earlier restore point that didn't help. I re-booted several times, still no change. I don't see any error message in the machine itself. There is no problem with the toner because with the multiple attempts to copy an article from the internet there has been copies made but when I place another document in the feeder it doesn't print at all.
  • Anonymous Mar 26, 2014
    When pressing the start button to start making copies with the ADF the machine beeps. It never did that until today and it had an error E003 earlier and I reset it then it started making the beeping noise.
  • 186 Answers
Try opening the cover where the document feeds in, make sure there is not any objects obstructing the path. If not try taking a rag moist with rubbing alcohol and thoroughly clean the rubber rollers and the square rubber pad on the back side of that cover.
Posted on Jun 21, 2007
Somethimes there is a white line on the fax we sent
Look to make sure there is no whiteout or other dirt on the lense where you feed the parer in..there is a long thin glass inside where you feed the document to be faxed or copied..mine was doing the same thing..just a little speck of whiteout on it..cleaned it and its working good again.
Sep 22, 2010 | Canon FAXPHONE L80 Laser
Tell me how to make copies on the canon faxphone l80
Place the document facing down and press the copy button , then press the number of copies and enter.
Oct 31, 2009 | Canon FAXPHONE L80 Laser
Will not feed to fax a document, but will feed to copy..?
Have you tried to see if you have a dial tone on the fax??? Can you recieve faxs? If not make sure you have the phone cable insurted in to the right connection "LINE" not "TEL" Good Luck
Jun 26, 2009 | Sharp AR-M237 Digital Copier
Scanner feed hangup
NEEDS A SEPARATION PAD AND A BUSHING.IT IS NOT A EASY FIX
Feb 11, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Canon B640 printing problem
The scanner lamp is not working. When making a copy, the lamp lights the source document, so if there is no light, the source document 'looks' black. Your machine will need to be serviced.
Jan 26, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
I have a Faxphone B640. Unable to place into fax/tel mode. can access only manual, answer machine mode and DRP
1. Press Function key - wait for TEL REGISTRATION to appear
2. Use left or right arrows to select RX SETTINGS
3. Press Start/Copy
4. Use left or right arrows to select DRPD
5. Press Start/Copy
6. Use left or right arrows to select OFF
7. Press Start/Copy
8. Press Stop key
Now, when you press the Receive Mode button, it should cycle through Fax Only, Fax/Tel, Manual, and Ans Machine Modes.
May 27, 2008 | Canon Office Equipment & Supplies
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Fax Not working
Copying Documents If you make copies of multiple documents at a time, the number of pages the fax can scan into memory varies depending on the scanning resolutions as follows: * STANDARD and FINE result in the same resolution when making copies
* If MEMORY FULL appears on the LCD when making copies, reduce the number of documents to be copied or reduce the amount of total copies.
  1. Lift up the document tray.
  2. Insert the top of the document, face up, into the ADF (1) until a beep is heard.
  3. Adjust the document guide to the width of the document.
  4. Press <Resolution> to select the resolution.
    You can select [STANDARD], [FINE] or [PHOTO].
  5. Press <Start/Copy>.
  6. Enter the number of copies (up to 99) using the numeric buttons.
    To make a correction to the number of copies, press <Clear> and re-enter the number.
  7. Press <Start/Copy>.
    To stop copying anytime, press <Stop>. If the document does not eject, press <Start/Copy> for a few seconds, then the fax will feed out the document.
  8. The new resolution will remain until it is changed.
Nov 05, 2007 | Canon FaxPhone B95 Plain Paper Inkjet
PAPER FEED
the drum of toner crtridge has expired chande the drum if available,otherwise change complete toner cartridge
Sep 17, 2007 | Canon FAXPHONE L80 Laser
Canon FAXPHONE L80 Laser Logo
85 people viewed this question
Clive
Clive
old marine
old marine
