Question about Polaroid FLM-3734B 37 in. LCD HDTV
No Sound I have a polavoid Tv and I have no sound on any of the channels I went into menu into Audio and nothing seems to be working.
  • swokie Apr 30, 2009
    I muted my tv and when I unmuted it there was no sound. Sound will not come back on.
    Sergeant:
    Champion:
  • 346 Answers
Press mts button on remote until it display the word stereo
Posted on Jan 16, 2009
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
On one channel...PBS we do not get any sound. Sound is ok on other channels and works on the other tv in the house
This television must have the ability to broadcast channels in SAP. Look for an SAP or MTS or AUDIO button on your Sylvania remote. The audio menu might be the place to find this setting as well. You want to remove the SAP and have the tv in either mono or stereo.
Sep 01, 2011 | Sylvania Televison & Video
Hook up everything right,but can't seem to get suround sound from TV. Went to Bestbuy and brought a Digetal Optical cable and it still dosen't seem to give mr that sound like the home theater sound---help!
On the remote press the surround mode button and set it to Prologic movies or music when you are watching TV to get the rear speakers to work.
Or if you have Digital cable TV with Dolby Digital 5.1 content, make sure you have connected theLG to your TV using HDMI v1.3a. There is an audio return channel on this cable which will stream 5.1 audio signal to the LG system.
Mar 11, 2011 | LG LHB975 Theater System
Can't get sound on channel 4 only. Any ideas? The sound is fine on all other channels and there is sound on channel 4 on my other TV sets. I've tried pushing the mute on the remote to see if it was muted...
You might try resetting the TV to the default (look in the Menus for a Options or Tools menu and a command like Restore Default or Memory Recall). Then exit the menu (and save the settings). Return to the menu and rescan all channels.
I do not know if this will help in your case but it is a simple thing to try. I have a tv (a different manufacturer) that had a similar problem. When my outdoor antenna was pointing directly at transmitter, the closest station gave me no audio on one sub-channel and no video on the other. All the other stations were fine. Doing the reset and subsequent rescan resynched the audio and video for the sub-channels.
I hope this helps.
May 22, 2010 | Zenith TVBR2742Z 27 in. TV/VCR Combo
Philips 32pf732198 no sound on certain channels
Unplug,replug the tv an hour later.Go to ur tv menu reset the Audio setting.The setting will go back to the factory setting,should work solved ur problems.Not than ur Tuner signal board have problems,must change.
Apr 06, 2010 | Philips 30PF9975 30 in. LCD HDTV
No Non-Hd sound
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Lost the sound
Perhaps the service manual can point you in the right direction =>
It's chassis K51A and TXJ2766,67,68,69 are all the same=>
http://www.epanorama.rackhost.net/schematicsforfree/Video/Products/Samsung%20TXJ2766.pdf
Feb 11, 2008 | Samsung TXJ2767 27" TV
Lg lcd 37 inch tv loosing sound
i have the same problem and find that if i freeze then unfreeze the screen it works
Jan 31, 2008 | LG 42LC2D 42 in. LCD HDTV
No sound dell 32in tv
These are the answers straight from the dell manual. Ensure that the audio cables are firmly connected to both the audio input connectors on your LCD TV and audio output connectors on your PC or Video player. If on certain TV channels you receive a picture but no sound, this means that you do not have the correct TV system. Modify the SYSTEM setting. Check if TV volume is turn off of muted Connect the audio cable securely Audio cable is connected incorrectly Verify that the audio source is selected correctly in the OSD
Jul 31, 2007 | Dell W1700 17 in. HD-Ready LCD Television
No audio
try to reprogram the channel. it seems that your tv's sound circuit is fine.
Jan 09, 2007 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Polaroid FLM-3734B 37 in. LCD HDTV Logo
56 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
