Question about Ricoh Aficio 1085 Laser Printer
Aficio 1105 restarting during copying
The copier aficio 1105 restarts while copying. Problem with soft? or what? If you look at the monitor you'll see that the copier is not counting the pages for a few seconds and then it's count very fast before restarting. What can be done?
  • 3 Answers
Replace nvram
Posted on Jan 23, 2009
Send me link viedo ?how to fix this code?help me
SC 120 Scanner home position error 1
The scanner home position sensor does not detect the off condition during initialization or copying.
If restarting your printer does not fix your printer you need a tech to replace some. Could be a bad sensor or bad BICU board.
Aug 15, 2016 | Ricoh Aficio MP1600L Printer
How do i fix the error code sc 322 of my ricoh 3045 copy machine?
Have to open the Laser unit and clean the laser diodes carefully.
Dec 28, 2015 | Ricoh Aficio 3045 Digital Copier: 45cpm....
How to restart Ricoh SP C231n?
hi there, try to do the following:
- make a program mode (SP 107)
if you dont know SP mode, press clear/resume button then 1, 0, 7 then clear/stop button for atleast 5seconds.
*the monitor should appear 1.system 2.copy 3.
then press 1, then press 7,8,0,7 then #
*the monitor should appear COUNTER RESET then press 1 to start, let it finished then turn off and on your machine.,
*the SC-542 should disappear
note: if this will not fixed the problem, there maybe a problem with your FUSING UNIT, check it!
Nov 29, 2012 | Ricoh Aficio SP C232DN Laser Printer
Ricoh aficio 1105
What is the problem with copier?
Sep 17, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Sc:101 problem has been occured , plz..... advice me how to troubleshoot
Please be specif wich model? ie RICOH Aficio 1018.
But generally in most cases that is shading correction problem. You need to unscrew two screws and remove copy glass. Beneath copy glass you will see white stripe that you need to clean and dry. Put all backi in and restart copier.
If that doesnt help call service!
Hope that helps!
Aug 19, 2010 | Office Equipment & Supplies
Installed XP printer driver for Ricoh CL7000 5c
during the installation you have to select this option, by default the duplex option is not selected. Uninstall the software, restart your pc and install the software again, and select the duplexing option. I hope this helps
Sep 03, 2009 | Ricoh Aficio CL7000 Laser Printer
Copier restart issue
if the copier is shuting down and restarting while copying it sounds like it is over heating.you need to check that the fan at the fuser unit is working.check the rest of the fans aswell..lets know how you get on
Dec 03, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh aficio 1045 error e990 please help it
Error 990 can be cuased by many things. Most of the time it is related to the Hard Drive. you could try replacing it.
Nov 05, 2008 | Ricoh Aficio 1035 Copier
The 391 code problem
SC 391 is image storage address error. Development BIAS leak. Charge AC output error.
Should be checked out by a technician. It could be a few things going on with it.
Sep 01, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 1085 Laser Printer Logo
136 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
