Question about Sony Dictation Microcassette, 60 Minutes (30 x 2), 6 per Pack Micro Cassette
How do I take a cassette tape apart without damaging the tape
How do I take a cassette tape apart & put it back together without damaging the tape. The tape became loose from one of the spools and I need to reattach it on a dictation microcassette
  • Anonymous May 06, 2009
    I have this same problem -- need to take tape cassette apart -- tape came off spool. Any solution?
  • DVR engineer May 11, 2010
    Honestly i wouldnt attempt it on the micro cassette you want to repair first. Chances are you'll break it beyond repair. If you can post your email address i will prepare a short procedure on how to take them apart etc but i would practice first as you have to break the tape to get into it. Also what manufacturer is the tape?
4 Suggested Answers
Kidyubyub
  • 143 Answers
SOURCE: videotape twisted
Underneath, between the spools, you can use a pencil or such other instrument to push in the part that holds the spools in place. Then loosen the tape as needed.
Posted on May 15, 2008
adrakewilson
  • 96 Answers
SOURCE: My cassette tape came unattached from the start
some have little screws, or take a very small flat head srew driver and carefully pry open.
Posted on Feb 17, 2011
  • 713 Answers
SOURCE: My cassette tape detached from the spool. How can
unplug radio get ink pin with top on and try taking it off the main wheel that its rap on.
I took apart a TDK Video Cassette, and I can't put it back together! I have two small metal cylinders left over, and can't for the life of me figure out where they should go! Please Help!! Thank you
The two metal cylinders are guide rollers where the tape goes in and out of the cassette. If you pick up any VHS tape and press the little button that allows the flap to come up, you should see them.
Sep 10, 2015 | TDK E-HG 120 VHS Tape
How to remove a cassette stocked in a vhs machine?
If the VHS tape is stuck inside, and when you push the eject button, it wont come out. Then you need to unplug the VHS player, take it apart so that you can access the inside. See how the tape is stuck inside and start to take it out the best you can. Once you get it out you may have to throw away the tape if it is messed up badly, if not wind it back up. Put the VHS player back together once you get the tape out. Then try to play another VHS tape and see if it works again. If not, it may be a bad VHS player or it may be the tapes. Hope this helps. I have had to take mine apart to take a tape out, so that's how I know
Feb 12, 2015 | Televison & Video
How to open vhs tape and put back it back together?
Open all the screws and raise the top off the bottom part. Avoid touching the outside of the tape. Be careful not to let the tape reels fall out and get tangled when you put the cassette back together.
Apr 23, 2014 | Televison & Video
How to repair a kodak video cassette T - 120 when tape comes off?
Need more info but I had a tape with videos I wanted and the tape was damaged so i bought a new take. took it carefully apart and put the tape in the new cartridge tape holder and works great now.
Apr 23, 2014 | Video Cameras
Defective cassette adapter for iphone 4s. stuck in side of the cassette deck
take the deck apart, get the tape and put it back together or see if you can find someone who fixes decks and ask them to take the tape out
Jun 16, 2012 | Dynex Mp3 Stereo Cassette Adapter Dx-ca103
It is a very old cassette tape which appears to have broken inside the tape. Am I able to repair this? If so, where can I get this done?
I'm afraid that this is one that only you can do, or somebody you know. Repair shops probably would say throw it away, or buy a new one.
VHS tapes are not to hard to fix though. All you need is a small screwdriver, some non-yellowing sellotape and a new or old VHS tape.
The old or new tape will show you how they work/fit together if you have never opened one up, which is perhaps obvious you haven't!
Right here is what to do. On the underside of the tape you will find several screws. Remove all of them. Once done lay the cassette bottom side down on a table. The top part should lift off from the bottom part, if there is a label on the back of the cassette this will keep it together, so you may have to break/cutt the label to remove the top section. If you haven't seen the inside of VHS before do the same thing to another cassette now. OK now you will have to work out where the tape has snapped. If the tape has departed from one of the reels, where the clear (leader) tape attaches you can re-attach it using your good cassette as a guide.
If the tape has broken in the black section, then cut a piece of sellotape the same thickness of the video tape. Trim the two broken halfs of video tape so they are nice and square to each other. I would remove any badly damage area of the tape, to prevent any break. It won't play anyway. You then (using the sellotape) join the two tapes together. Put the sellotape on the back of the video tape and make certain there is no sticky part exposed. Try and avoid contact with your fingers to the front of the tape, though there's no chance of that near the join. Re-assemble the cassette.
I would not recomend this method, unless it's a tape that has unique content on it - such as a family video. Even then I would recomend the tape is transfered to DVD as soon as you have repaired it and never used again.
Jul 12, 2011 | Televison & Video
I have several 30+ year old recordings. Sound quality is fine BUT a few of these tapes have come off the hub and need to be re-attached. Any suggestions ? john30662@yahoo.com
its sounds like you have the real FUNK (the good stuff) music...
John, if you still have the casing for these little cassettes I will tell you how to roll these tapes back onto the hub. you will need some crazy glue and a tiny phillip screw driver...its operation time, unscrew the 1st tape that is off the hub..when you open it make sure that tiny metal w/cotton pad is intack now the tape is already off the hub right (take the hub and push side ways that small piece on wheel like...now straighten out the tape on the other side of you...put 1/4 or 1/8 of in onto the hub ..do not try to snap the tiny piece back in, slide it in sideway on top tape..once this done ...no tape is sticking out right...place the tape through its slots (so it can run smooth) we about to put it back together make sure the metal w/ cotton pad is still in its place.... screw it back together (crazy glue is only for the tapes casing that dont have screws or that cracked)....now continue the process for the rest,,,,yes I have done the same process for micro / regular cassettes/ VHS and the those 8's. like me I still have my tapes too but a suggestion its a little time consuming but you should either put these tapes on portable hard drive (500 gig) or burn it to CD...
hope this helpful
May 12, 2010 | TDK 60 Minute Micro Audio Cassettes...
The tape broke and I am trying to put it back together so I don't lose the dictation
I have done this,carefully take the cassette apart,by removeing the screws,be sure and look at how it is assembled.
Remove both spools of tape.In the break area cut with a razor blade each sides of the spools so you have a smooth surface on the tape.
lay them on a flat surface,pointing towards each other,be carefull not to drop the spools.Put one (little) drop of supperglue on the tape,then put the other end of the tape on top,make sure the alignment is straight and you dont glue the tape to youre work area.Wait about five minutes,then reassemble. Works like a charm for me.
Oct 26, 2009 | Maxell MC-60 Micro Cassette (3-Pack)
I have a broken VHS cassette.
You can remove the 4 or 5 screws at the bottom of the tape, turn the tape over CAREFULLY pull the top off. If the tape pulled out of the end of 1 spool, you have to remove the clip in the tape hub, reinsert the tape and snap the clip back in. Holding the tape door open so as not to catch tape, put top back on and replace screws. Hope this helps.
Aug 08, 2009 | TDK T 120HS VHS Tape
Electronics - Others Logo
1,184 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
