Question about Jl Audio 500/1 Car Audio Amplifier
Jl audio 500/1 problem
Low ohms lights on; Transistor Brown, replace it; low ohms light is off now and everything seems to work fine execpt when in low volume, it sounds good. When increase the gain, it hit for 1 second hard, and then goes back and doesn't hit hard no more. The sound quality is good, its just sound so weak that's it. And when installing the amp, it sparks like crazy when putting the neg in and then the pos or vice versa. Usually it sparks one time and then your good. But this time after replacement of the transistor, it's crazy all the time when put back in or out. I think its th transistor that is causing it and Any tip will help. Thank You. Oh, do you know where I can buy some transistor for JL Audio amp spec?
  • bj parrot May 11, 2010
    it sounds like you have a dirty solder joint, " like the solder has made a secondary circuit , or you may have used a pnp instead of an npn transistor
  • 3 Answers
Usually all amps spark a little when hooked up again after a while of no use. this happen cause there are many little capacitors inside to keep the amp running when hitting long bass notes. I think the reason you have been having problem after replacing the transistors is because there not the rite model number or maybe the polarity. You mite have to call jl and ask them if they have any in stock or google the model number of the transistor and buy them and replace them and see if it work. if it doesnt work then it mite be something else inside.
Posted on Feb 15, 2010
Low ohm light on 500/5 front left channel doesn't work.
The first thing is to meter all the speakers with a volt/ohm meter. They should read somewhere between 2-6 ohms. If they meter good try swapping the RCA's and see if there is any difference. But if both of those check out ok than. Unfortunately it would appear that your amp has a bad output channel. What seems to happen is that when the amp is cycled off and on, off and on etc. the solder on the PCB can get brittle causing problems. The only answer i can offer is to send it to JL to repair or find a good repair shop that works on car audio amps. It's getting harder to find a good tech but they are out there. If you send it to JL they have a set repair rate of $180.00 which covers the return postage while the customer pays the shipping cost getting it there. They do an excellent job and pretty much go thru the whole board and replace not only what is wrong but will also perform any mods or changes since date of manufacture.
Aug 12, 2009 | Jl Audio 500/5 Car Audio Amplifier
Jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
Feb 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
JL 500/1 Problem
You need the old transistor. Knowing it's brown is not enough; you need to know its resistance value. It sounds like the resistor you replaced with has too low a resistance value, causing the "cuts" in sound. Find the old resistor and then use this site to find out what you need:
http://www.dannyg.com/examples/res2/resistor.htm
Jan 13, 2009 | Jl Audio 500/1 Car Audio Amplifier
500/1 amp turns on, but small ugly bass comes out speakers
Heat sink is jacked!!! Burned it out. Replace it or send it away to get fixed.... check the pricin on it sometimes cost alot almost as much as new amp....
Nov 04, 2008 | Jl Audio 500/1 Car Audio Amplifier
500/1- Low ohm light
Disconnect the speaker wires from the amplifier's terminal block. If the low ohm light still comes on with no speaker wires connected, the amplifier will need to be repaired.
If the light no longer comes on, check the speakers and the wiring.
Jul 15, 2008 | Jl Audio 500/1 Car Audio Amplifier
Low ohm light on my jl 500/1
If the low impedance light is on, the amp probably has shorted output transistors. If you don't know of a good local repair shop, call 'several' of the local audio sales/installation shops to see who they use. If more than one audio shop recommends the same repair shop, they probably do good work.
May 08, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl audio 500-5
Assuming that you've confirmed that the speaker is in good working order and that the wiring isn't shorted in any way...
There are separate power supplies for the high and low amplifiers. It's possible that the one for the sub output has failed. If that's the case, the output transistors probably failed and that's what damaged the supply.
Generally, I'm willing to help people repair their amps but this is a large, complex amplifier and it should be repaired by a qualified technician.
Apr 18, 2008 | Jl Audio 500/5 Car Audio Amplifier
Low ohm light on with no speakers connect??
This can happen if the amp has an internal fault such as a shorted output transistor.
Dec 26, 2007 | Jl Audio 300/4 Car Audio Amplifier
Low ohm light wont go off
It's likely that the output transistors failed in the amplifier and it will need to be repaired.
Nov 08, 2007 | Jl Audio 500/1 Car Audio Amplifier
is there any sound?
Aug 21, 2007 | Jl Audio 500/5 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
347 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
