Question about Sony Handycam DCR-SR40 Camcorder
ImageMixer software "could not find Handycam." DCR-SR40
I've test the USB connection with another device. It works fine.
I've tried the connection several ways, Handycam on, off. Still no luck.
  • 3 Answers
After camera is on dock and usb is plugged in, turn on the camera. You can open the door to see the status of the connection as an option. This should do it. If the camera is off, nothing will happen when you run the imagemixer software
Posted on Feb 17, 2009
Can I get the video off of my Sony Handycam DCR-40 without the docking station? It broke, so I want to know if I can connect it to the computer directly? I'm not willing to lose the video we've taken, so...
I bought my DCR-SR40 used (just camera) and I have the same problem. Downloaded the instruction manual from sony and discovered the only way to connect to a computer is through the
Sony Camcorder Docking Station
#DCRA-C162
and a Special USB Cable!
Jun 02, 2010 | Sony Handycam DCR-SR40 Camcorder
I have a Sony Handycam DCR-SR40. I can playback
The new laptop does not have the codecs installed . Install any software that came along with the camera. Or download latest codecs and install
Apr 26, 2010 | Sony Handycam DCR-SR40 Camcorder
When I try to capture a video into the imagemixer software, it says it does not recognize the camcorder.
lets see if it's a software issue or not.try to use windows moviemaker as your video capturing software instead of imagemixer. if issue is with imagemixer alone, you may want to uninstall and reinstall and update the software.check website for update: http://support.d-imaging.sony.co.jp/www/disoft/int/pixela/imx/dl/index.html and download the free update for imagemixer ver.1.5 for sony.
if still it's not recognize we can isolate the issue with the camera or connection. if your using usb,make sure you have the usb driver installed properly.you can download the device driver at this website: http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV350 and make sure you don't have the camcorder connected during the installation.also have the usb stream setting (under setup menu) set to on (see:p.221 of your manual). after that the camcorder should be recognized. if your link connection (ieee1394 or dv) it should be a plug-and-play connection. better check computer connections and connected device in device manager screen to see if the cam is listed as an unknown device.if it does, you can be sure nothing is wrong with the usb cable. it can be a connection.issue.try diff ports if available (usb back port at the back is recommended for use, that is directly connected to the motherboard) and check. if the cam doesn't show or you don't have any indication that it's connected.try using a diff usb cable.if still doesn't try using a diff compatible PC.use same procedure.if' it's still the same, unit may require service.hope this helps.thanks:)
Apr 15, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony Handycam DCR-SR40 Camcorder broken LCD flex-wire.
Take it for a service - cost will depend on the amount of work needed.
Sep 12, 2017 | Sony Handycam DCR-SR40 Camcorder
Using sony dcr-sr36 as a webcam
Unfortunately is not possible directly - Your cam do not support USB streaming... But You may use any cheap video capture device like Pinnacle Studio movie box or similar to connect Your camera via S-video cable because Your camera has an analog output. Only one requirement - the capture card must have an S-video input or simply RCA video input. It's easy - connect video out and audio out of Your cam to the capture device and then connect USB of capture device to Your computer.
Sep 19, 2009 | Sony Handycam DCR-SR40 Camcorder
Video memory full on camcord, how to burn it onto a dvd?
First be sure to have installed ImageMixer software that came with the camera. If you can't find the disc go here... http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRSR40&LOC=3 then select your operating system and then select imagemixer to download.
Step 1:
Place camera onto docking station, connect usb cable to computer, open camera door, turn on camera. Imagemixer should open automatically, if not open up imagemixer.
Transfer to Computer:
Select "Viewing and Editing", then select "handycam" tap, click on "▼" (arrow) facing down, then click "movies". Place a check mark on each movie you wish to move to the computer then click "Options" tab (lower left corner) and see where the movies will end up once you click "Import to computer".
Burn to DVD:
Be sure you have a DVD drive that can write to DVD's. Will have DVD R/RW on the face of the drive. Place a blank DVD into drive. Follow Step 1. Then click "One Touch DVD Burn" from the imagemixer menu. Follow any instructions on screen.
Or you can choose to use Windows Explorer and select the drive letter that is your camera's harddrive and move/copy/cut/paste files directly from this location to another.
Feb 09, 2009 | Sony Handycam DCR-SR40 Camcorder
Cable needed to connect SNY DCR-SR40 Hndycm N DCRA-C162 Handycam Station to computer
There are 2 cables,
  1. A-V Connecting Cable P/N 1-831-553-11
  2. USB Cable P/N 1-829-579-41
attached with Handycam Station DCRA-C162. Hope this info is helpful to you.
Aug 12, 2008 | Sony Handycam DCR-SR40 Camcorder
No sound after capture on computer
Can you tell my from the menu on the camera how you connected it to your computer?
Apr 02, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
I have no sound on my sony handycam
Sony got back to me with the answer, so I will post it here for future reference.
If there is no audio when USB streaming with PIXELA ImageMixer version 1.5 software on the Microsoft Windows XP operating system, change the USB capture device setting for sound to USB Audio Device. In the Image Mixer Tool settings, confirm the USB Capture Device settings are set for an available USB Audio Device. This setting is not defaulted to the USB streaming mode.
This would be the icon of an open end wrench in the top right hand corner of the capture environment screen.
Follow this procedure to change the USB capture device setting for sound in the Pixela ImageMixer 1.5 software.
1. In the ImageMixer window, click the USB Device Capture icon.
2. Click the Preferences icon.
3. In the Capturing/Recording Preferences window, in the USB Capture Device Setting section, click the down arrow to select the desired sound device.
4. Click the OK button.
For any request for processing or editing assistance you may visit the PIXELA help file. You may also contact them at the following website:
www.imagemixer.com
Jul 04, 2007 | Sony Handycam DCR-TRV265E Digital...
Sony Handycam dvd201 and iMac G5
Looks like a rip operation. Close the DVD session and try http://www.macupdate.com/info.php/id/14414
Sep 14, 2005 | Sony Handycam DCR-DVD201 DVD Camcorder
Sony Handycam  DCR-SR40 Camcorder Logo
240 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
