Computers & Internet Logo
Joan Harrison Posted on Dec 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My toshiba computer wont come on,it says its in power mode
I came to use computer,but screen is saying its in power mode and wont come on
max carson
Level 3:
  • Master 7,627 Answers
  • Posted on Dec 23, 2012
max carson
Master
Level 3:
Answers
7627
Questions
Helped
1013657
Points
21773
Shut down, unplug, remove battery, plug in, reboot.
My Toshiba Satellite S75D-A7272 laptop has always had a problem with getting it out of sleep mode. Is there a fix for this?
Sleep or standby mode should allow your computer to conserve energy yet respond quickly to power back on when you need it. Most Toshiba laptops should exit sleep mode if you press a key on the keyboard or use the trackpad mouse. If the lid was closed, opening it should also wake up the computer. If none of these methods work to bring the computer out of sleep mode, you may have a power issue or software glitch. Causes Insufficient power can cause this problem, so try plugging in your Toshiba laptop before attempting to wake it from sleep mode. If this does not immediately fix the issue, your problem is more likely a software issue. If your laptop was shut down incorrectly prior to the sleep mode incident, it may be stuck on a blank screen that makes it appear to be in sleep mode when it actually is trying to start up.
Indications Press the power button for a few seconds to see if your computer will wake up. If it does, the laptop was not truly stuck in sleep mode, but rather went into hibernation mode. If your laptop is truly stuck in sleep mode, you may be able to force a shutdown by holding down the power button, but when you power back up it will move right back into sleep mode. In some cases, the power button may not shut down the computer from this mode at all.
Solution The best way to solve your Toshiba's problem is to completely remove all power from the laptop to ensure a fresh restart. Close the laptop's lid, turn over the unit and remove the battery. Also remove the power adapter cord from both the laptop and the wall socket. Open the laptop lid and press and hold the power button for approximately 20 seconds. This will drain any stored power in the backup battery. Wait a few seconds, then put the battery back in, plug in the laptop and press the power button to turn on the computer. It may start up with an error screen; in this case, select the option to start your computer normally. If the error recurs, start the computer in "Safe Mode" to see if a program running on your computer outside of the basic Windows operating system is causing the problem.
Further Help Sometimes this issue also requires holding down a specific key, such as "F8," when you restart. If the basic power drain and restart process doesn't work, you can use Toshiba's support website to look up further information for your specific model. Just click the "Product support" tab and enter your laptop's model information, then read through the support bulletins listed for your particular Toshiba model. Toshiba also maintains a support hotline at Call us : +1 850-610-1013 https://www.instantprintersupport.com/toshiba-printer-support
How to turn off safe mode on lap top
When you boot, you get a menu with "safe mode" as one of the options. Next time you boot, watch the screen closely and wait for that menu. Then using the arrows on your keyboard, scroll down to "repair computer". Further instructions in the link below.
Windows 7 Repair and Troubleshooting
Hi I have a toshiba satellite L455D S5976 It just stopped working will not turn on but its got power I connected a monitor usung rgb cable and its got a yellow saying its in power save mode and to hit a...
you should probably get a new screen fixed to laptop, because until u log in and system boots up properly, second screen will not work,
as u tried turning of laptop forcefully, advance boot options must be up on computer, hence not displaying.
2answers
Toshiba a205 wont enter into recovery mode
with the computer off. start by having it plugged in. now press and hold down the 0 (zero) key. while holding it down press and release the power button.. as soon as you see it power up release the 0 (zero) key. this will restore to out of box state. it will take aprox and hour. You wont have to do anything just let it run the restore..
1helpful
Toshiba Satellite Goes completley off! Black screen, NO POWER!
This problem is likely caused by overheating. The CPU reaches a temp to high and shuts the system down. When you try to turn it on the system is still to hot and it will not let the computer power on. You can try blowing out the fans and heat sink with an air compressor or can of compressed air. If this does not help the problem you may need to have thermal compound reapplied. If that does not fix it it will need a new heatsink/fan/
Windows XP Media - Service Pack 3 download, Wont startup after download shut down.
Keep the battery unplugged but make sure you have the power cord still plugged in, and when you see the toshiba screen press F8 i believe or F1. In there you need to change to the boot order so that the CDrom boots first if you want to try and restore from CD
My Toshiba Satelite A105-S4211 wont log in
I recently ran into a computer doing this.
Try what jmagnu said, hopefully it will work for you (safe mode didn't help me).
I basically had to remove the hard drive from the computer, install it into another computer and run a ton of virus, malware, spyware scans on the drive.
I used a combination of AVG, superantispyware, malwarebyte's malware remover, hijackthis, ccleaner, and a few others who's names escape me.
Best of luck :)
TOSHIBA
Hold the power button in until all lights turn off.
Toshiba Satelite
Can you tell me if your operating system is Windows XP. when it shows the windows screen is it the "boot up screen" showing and returns to the same thing?
Grand Canyon Tech
Grand Canyon Tech
