Question about HP (122226-001) Fan Controllers
When i login my system it says cpu fan error. i replaced with the working cpu fan of same model and processor but still the problem arises
  • 36 Answers
I'm not entirely sure from your description what you did, but one thing i've noticed is that unless your replacement fan uses the same on board power connection that your original one uses, your PC will think you don't have one installed.
as long as its functioning properly, you can disable this error message in the BIOS.
hope this helps
Posted on Jan 16, 2009
Dear sir, my motherboard is amd athlon 64 socket 939.when i on the system then system is running but processor fan is not rotating.Finally after 25-30 minutes it automatically turned of and displays cpu...
It sounds like the cpu's temperature is raising over the safety level set in the bios so it switches off and displays the error!
to solve this either:
Your cpu cooler fan needs replacing
or
Your current cooler fan isn't connected to the correct socket on your board (check you're user manual, usually a .pdf you can download from manufacturers site)
or
Just try connecting your current cooler fan to the cpu and see if it turns on at all. If not make sure you replace it with one that is compatible with your system that can fit in your case
If the temperature has raised to a significant level the thermal paste could probably use replacing also, so get some thermal paste remover and thermal paste, and read in your motherboard user manual how to replace the cpu heat sink safely.
Sep 26, 2013 | AMD Athlon 64 X2 3800+ Dual Core Processor...
CPU Over Temperature Error
Hello
This error mostly comes with the failure of processor fan, overheating of processor shuts down the system due to processor's protection. You need to check the fans and replacement is recommended.
Hope this helps
Jan 31, 2011 | ASUS P5PE-VM Motherboard
CPU Running Fan not recognized by motherboard M7VIG 400
Check out
1.the heat sinker is tightly fixed on the processor.
2.check and clean the dust in the processor ad the coolingflood on top of the processor
Jun 30, 2010 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
When i boot up the laptop i get a message 'Main Fan Error' the fan runs on start up then stops just before i get the error message. Fan will not restart... Joseph
This message means that the fan on your CPU (processor) is failing or has failed. This is not good because if the fan on the CPU fails your CPU will overheat and cause your machine to lock up and become non-functional till it cools down and then the same cycle will repeat till the fan is replaced.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 11, 2010 | Gateway (8008625) Cooling Fan, Heatsink...
My dell precision 470 1st fan is running very fast and loud. I have yygy lights on the front as an error code, indicating a possible processor failure. I removed the processor and reinstalled, still...
Ronwed
Unfortaintly if you have resetted the CPU but still having this issue then most likely the problem is with the CPU. Note you will want to replace the heatsink and fan as well. In addtion info know for sure that you had a thermal event (IE the system majorly over heating) it is possible that the motherboard is damaged as well.
Issken
Jan 11, 2010 | Dell Precision Workstation 470 (204816690)...
Alert chipset heat sink not detected system halted error message
It is NOT the CPU fan! There is a heatsink over the northbridge chipset adjacent to the CPU. The clip that supplies pressure to maintain contact between the northbridge and the heatsink has detached on one or both ends. There are wire loops at each end of the clip which feed into the motherboard. When the clip detaches (solder failure), it pops the loop out of the motherboard. The BIOS recognizes this condition as a heatsink failure, hence the error message.
Jul 10, 2009 | Dell Dimension 4600C PC Desktop
MLTIPEL PROECESS EROOR
sounds like your fan on your cpu is almost taken a dump common prombelm you better change it before it over heats and takes your cpu out ... lala linda
May 14, 2008 | Dell Delta Electronics CPU Processor Fan...
Bootup problem
Your CPU is overheating.
Try and get into the BIOS and increase the fan speed & any aother fan on the system. Don't increase the temperature range, as this will damage the system.
You won't be able to sort out the software problem until the system is running within the hardware limits.
You can also run a office fan to help get the system to cool while making the changes in the BIOS.
May 11, 2008 | Computers & Internet
My 4-pin cpu fan is not running
check the power connection for your mother board and fan
Mar 09, 2008 | Computers & Internet
HP (122226-001) Fan Controllers Logo
69 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
