Question about Onkyo TX-SR601 Receiver
Reciever turning off.
I have moved my equipment interstate and on setting everything up my receiver will not stay on. It will play for 10 minutes but when the volume is moved up the unit will turn off with a 'protect' message on the display. This will continue to happen with a shorter time between it turning off until it is immediate. The receiver will stay on after pressing play but with speakers connected it will turn off straight away. It has turned off by moving connecting wires, turning the volume up or down.
    Problem Solver:
  • 15 Answers
You have a short in the speaker wiring. Simply put, the pos and neg (red/black ends) of your speaker wire are most likely touching somewhere. The receiver has a short protection circuit that keeps you from blowing the receiver or your speakers. Either try re-cutting the ends of the speaker wire, or if that doesn't remedy the issue, buy new speaker wire.
Posted on Jun 19, 2007
My reciever standby led light stays on after I reset it then clicks off the reciever.How do I reset the reciever so it does not turn off?
hi :good morning i have a fisher receiver i set the timer off by mistake,now the stanby red light stay on and the receiver give no sound at all,what sould i do to set the timer back on ?
Apr 10, 2011 | Fisher Audio Players & Recorders
Possible short . reciever turns off after 5 minutes or so ..
Still sounds like a thermal issue. Does the unit FEEL hot just before it dies? Make sure it gets a lot of clearance for ventilation and don't run too much auxilliary equipment from its rear power outlets.
May 24, 2010 | Kenwood VR-407 Receiver
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
I have a KLH 700watt home theater reciever that wont stay on!!
Sounds like it is overheating. Try one or all of the following:
Remove anything that may be stored on top of it. Unblock the vents.
Connect speakers with a higher sensitivity rating.
Move it to an area where it has more airflow around it, ie; not in a closet or cabinet.
Disable any bass-boost and equalization, or tone controls.
Set any crossover settings for any subwoofer you may have connected, to a higher frequency.
Decrease your listening volume.
Dec 30, 2009 | KLH R7000 Receiver
Describe your How can I set my garmin nuvi 350 to
If you have set it to fastest, as opposed to shortest, it should take you on interstates for the most part.
Oct 25, 2009 | Garmin Nuvi 350 Car GPS Receiver
The reciever will not stay on. Despite beingt on charge it will not stay on
Do you have a route planned?? I have the GO630 and there's a powersave feature built in that turns it off when not in use, though it will stay on if I have a route set or if I'm moving in the car and it's tracking my location.
Oct 06, 2009 | Tomtom GO 910 GPS Receiver
Audio system turns off
Wires are touching somewhere (speaker wires)... Usually, the wires neg. and positive wires running to one speaker are touching... The receiver automatically detects this and emergently powers off...
Dec 03, 2008 | KLH R5100 Receiver
I have a STR-D665 FM-AM Reciever. It worked fine before I moved but now after about 5 minutes of play it will click and flash "Protect". Is there a way to reset this? Do I have something wired incorrectly?
When you moved did you put somethink on it so that it does not have good ventillation through itself to keep it from overheating? Or set it down in a way that it does not have ventilation room under it? Some papers set on top of it or a pillow under it would block good cooling ventilation through it.
Nov 28, 2008 | Sony STR-D665 Receiver
Onkyo TX-DS575 turns off after about 10 min.
it could be a failing speaker causing the fault. Disconnect one speaker and run it to see if the problem persists and repeat with a different speaker until all speakers have been disconnected and the unit run to failure. If it stays ok, with a particular spkr off, it's the speaker. If it shuts down no matter which ones disconnected, it's probably a crack on the PCB which expands as it heats and causes shutdown.
Dec 16, 2007 | Onkyo TX-DS575 Receiver
Vsx-d506s problem
It may be a PROTECT MODE. Check is your other equipment properly connected to receiver.
Oct 09, 2007 | Pioneer VSX-D506S Receiver
Onkyo TX-SR601 Receiver Logo
192 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
